Question about 2wire (1000-000057-000) Modem
Error ive...Message after Format of Hard Dr
I am experiencing a problem after formatting my hard drive and trying to install my OS. I keep getting this error message: "standard mode: fault in ms-dos extender. EC=8000, CS=0053, IP=2811, AX=3710, 3X=E160, CX=FFFF, DX=FFFF, SI=0000, DI=89B0, BP=4278, Stack dump: 0354-0000-0070, raw fault: IP=244B, CS=0053, FL=3097, SP=00F2, SS=004B. Please remove any floppy disks from your drives and press any key to restart your system."
I keep getting error code 8002f147 on my ps3 when it tries to update
take out the hard driveconnect hard drive to pc (running windows 7 64bit, but any windows os should work without other software)open up disk management - in win7 it asked me to make a master boot record, so I did.format in NTSF - that's right, NTSF - don't use quick formatshut down pc, take out hd, take usb drive tooput hd back in ps3, put usb stick in ps3boot ps3a screen will pop-up saying the hard disk have to be formattedhold start + Select for 5 sec.After formatting the system will restart and the update will start installing configure your ps3 setup - done
Feb 23, 2014 | Sony Playstation 3 (PS3) Console
Unable to format Seagate ST9500423AS
Have you tried reformatting your hard disk? this happened to me when i tried to us PartionMagic tool. my hard disk stopped working tho' it's still showing up when i plug it in another PC. this is how i get it working again:
i plugged my hard drive to another PC and i used DiskPart to clean it and i formatted it in Windows Disk Management.
it worked for me and i doubt, there was an error partitioning my hard disk so i needed to make it fresh again.
Apr 18, 2013 | Seagate 500GB ST9500423AS 7200rpm SATA2...
On windows install winsetup.dll error
Even with a complete fdisk, thorough format, and chkdsk /f/r ? If so, there is a bad sector(s). Don't think they are repairable.
Nov 29, 2012 | Computers & Internet
I just upgrade to Win 7. Now everytime when powering up the machine, there are two boot options like this: Previous Windows Operation System Windows 7 (with Windows 7 highlighted) Of course I...
If I understand you correctly you had a previous operating system installed on one hard drive and you just now installed Windows 7 but on a separate drive? When you boot the machine if gives you two boot options, the old OS and the NEW OS?
What your going to have to do is format the drive(erase) that contains the old operating system. Format as NTFS.
Try unplugging the old drive, making sure the new drive is set to master and not slave. Boot up the computer.
When you boot up your computer you should immediately get options. One of these options should say "press delete for bios" or press "f6 for settings" You need to go into the bios and make sure the drive with Windows 7 is set to your primary drive in the boot order(hard drive should be first in boot list). We want the computer to boot to the new drive first.
Once you get into Windows you can use a program like partition magic to format the old drive to use as just storage space. You can even use "diskpart' which is an old windows command line utility.
If you reinsert the Windows Disk when you are booting up you will get some recovery options, and if I recall correctly one of these should let you format hard drive space. So, you may be able to do it from there.
Where exactly does the error come up in the boot process? Are you able to boot into safe mode? It may be easier for you to just reinstall Windows 7. If you boot the computer with the disk in the drive, and the BIOS set to boot first to the disk, then during the installation configuration you should be able to have Windows just format the old drive to use as space and install the MBR on the new drive.
-G33k
Jun 11, 2011 | Microsoft Windows 7 Ultimate for PC
I have a laptop IBM thinkpad type 2373 I was trying to install a new OS, and I deleted all the partitions and format the hard drive, but the installation failed. And now I have been trying to start the...
Hi
You need to make the proper format, in order not to see this message.
Tell us please which OS you intend to install, what tool you used to format?
If your hard drive is 250 GB or less, you can format it using OnTrack Disk Manager,
For any hard disk capacity, you can use Windows CD to format.
Please tell us your results
Good Luck
May 14, 2011 | IBM ThinkPad T43 Notebook
Multiple hard crashes. reformated hd. near end of os load, got "hard error" message. Looking for concurrence of HD being shot or could it be other problem. CD
When this happens it is always the hard drive going.gone faulty. I recommend you replace the hard drive. But first, try a full format, from a Boot CD/DVD, that can be used to format, like Partition Magic, or get UBCD, this too has formatting tools, try that one last thing before giving up and getting a new drive.
www.ultimatebootcd.com/
Feb 26, 2010 | Dell Dimension 4600 PC Desktop
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
Hard Disk not formatting
ok..you may want to do a chkdsk..open my computer..then highlight the main drive..right click go to properties. then you will see some options..tools is what you want..click on that tab, and them there will be an error checking option..follow that through, and it will run on restart..
Oct 22, 2008 | Seagate 20PK 500GB BARRACUDA-7200.9 16MB...
Hard disk is read only
format your hard disk with disk manager software. (low level for formating). this software can remove bad sector of your hard disk
Oct 10, 2007 | Computers & Internet
2wire (1000-000057-000) Modem Logo
41 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
