Question about Sanyo DS19310 19" TV
T.V. will not come on
I turn my T.V. off when I left to go to work when i return home it wold not come on. What could the problem be?
    Genius:
  • 1,074 Answers
Your tv has a deffected power supply or related circuit call a tech. to remedy your problem.good luck.
Posted on Apr 11, 2007
I was driving my 2000 Lincoln LS and all of a sudden I lost acceleration. The car would not move with my foot on the gas pedal. I came to a dead stop. I turned the car off and could start it. But, it...
Flow valve in the transmission is sticking most likely.this is usually caused by some other failure creating metal particals that should not be in the system.Good luck!
Apr 27, 2011 | 2000 Lincoln LS
My 05 nissan frontier is not running it drove all day i got home it wold not start it turns over but will not start
Erevything runs out of gas! To make sure remove the gas cap and stick in afunnel with your ear over the end of the funnell shake the car and you should hear the gas slossing around, If you don't put more gas in and try again. Gas costs enough and with so many peaple out of work the gas you just bought before you gaot home may well be in someones elses tank and you've been sucked dry and the gauge sender was damaged and tells you about gas that's not in there.
Aug 28, 2010 | 2005 Nissan Frontier
'No disc' message on Samsung DVD home theatre system
hello,
the problem the disc is samsung DVD home theatre is having is the lense that is weak. if yo replace the lencse then it wold work properly.
Jan 04, 2010 | Kenwood DV-6050 Multi-disc DVD Player
Went to get in my car after just returning home from a 15 minute drive. key will not turn in ignition... lights work on car,
Try turning the steering wheel (hard) right and left while trying to turn the key. Steering lock and Ignition lock kind of work in conjunction. Also make sure vehicle is fully in park.
Nov 06, 2009 | 1999 Dodge Intrepid
Error Code-Traction Active
You have a bad traction sensor, I wold take it to the dealer an have them pul the trouble code to find the problem.
Jun 11, 2009 | 2002 Chevrolet Impala
TV NOT WORKING
TURNED TV ON AGAIN 2 DAYS LATER AND IT WORKED.
Jan 18, 2009 | Sony Televison & Video
Top freezer opens when lower door is shut
This could be the door rubbers, try boiling some water and pour it slowly over the rubber,it would turn soft and wold return to the original state.
now close the door and with a hair dryer set on hot,blow on the rubber untill it seals all over.
let the door stand close for at least 6 ours...
Let me know if it worked..
Good luck.
Sep 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Chirping noise
Sounds like something may be shorted out inside keeping the power supply loaded enough it wont start, dont recommend trying to fix unless you know EXACTLY what you are doing, there are some high voltages inside, I wold Call a TV tech out to repair, Just FYI, these sets from Phillips/MAG usually have CRT fluid getting cloudy causing discoloration/fog to pix around this age and older, between both repairs, some sets start around $1000, just an idea.
Jul 16, 2007 | Philips 60PP9352 60" Rear Projection...
Sanyo DS19310 19" TV Logo
46 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
