Question about Troy MIG100 90-Amp. Wire Feed Welder
Mig gas pressure
I have been mig welding for about 20 years. I have my own fab. shop with several employees. One employee that I have had for 1 year is a great welder & great at fabrication. I have one problem whith him. He is determened to run 35 PSI gas pressure. Now unless I have a high draft, I usualy run 15 PSI or 15 to 20 on a flow meter & never have a problem. No matter how many threats I make, when my back is turned, he has the pressure turned back up. I feel that this is a waste. I can't find a good instruction manual for gas pressure settings. If I can't get it through his thick head about gas pressure settings real soon, I will have to fire him. Any solutions?
  • 15,935 Answers
15 PSI is the absolute MINIMUM flow rate you should use on ANY project.
35 should be the max required without physical shielding. If he is good at what he does, he may feel the need to stick with what he knows for good shielding/penetration/ and quality. You are the boss, and he should be supbordinate to your requests. If all else fails, comprimise on 25, and lock-tite the adjustment knob!
Also, your welding supplier may have a handy dandy reference chart for regulator settings based on material and wire you are using.
http://www.millerwelds.com/resources/improving-your-skills/mig/
Research a little here for guides and reference materials.
Posted on Dec 22, 2008
    Problem Solver:
  • 7 Answers
Btw PSI is not flowrate.
Posted on Oct 28, 2009
How thick of metal will this unit weld
Hi:
Your unit will be capable to weld up to 3/16" using FC wire and 1/8" using gas wire.
Aug 06, 2011 | RTO Flux Wire Welder Dual Mig 131 Ti 1 Gas...
Welder work OK with flux wire, cannot get penatration in MIG mode
Are you using combination argon/co2 gas? You need a flow regulator and should have it set for about 10cfm. Note that this is different than a pressure regulator. The problem you note is a result of inadequate or improper gas.
Mar 10, 2009 | Campbell Hausfeld WG2060 Mig/Flux Versa -...
How to control welding spatterin MIG?
different gas mixes will give different amounts of spatter, pure co2 doesnt spatter too bad, flux core spatters like crazy, and 75/25 has light spatter also
Mar 03, 2009 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Suggested oxygen pressure
first of all good luck welding aluminium with a mig no disrespect intended but your gas pressure with change depending on the place you will be welding at 20psi is a good starting point
Oct 03, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Mig Question
MIG stands for Metal Inert Gas welding, many times called Wire-feed.. Also referred as GMAW (Gas Metal Arc Welding). The "Metal" refers to the wire which is what is used to start the arc. It is shielded by inert gas and the feeding wire also acts as the filler rod. A semi-automatic process, it is fairly easy to learn and use.
Aug 27, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Mig problem
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Aug 27, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
TIG MIG Difference
Aug 27, 2008 | Radnor A35HP 350A Water Cooled 25' TIG...
How to TIG Weld
TIG stands for Tungsten Inert Gas welding. Also called GTAW (Gas Tungsten Arc Welding) and Heliarc® which was Linde's trade name for the TIG process when it was introduced many years ago. The arc is started with a tungsten electrode shielded by inert gas and filler rod is fed into the weld puddle separately. A slower process than MIG, it produces a more precise weld and can be used at lower amperages for thinner metal and can be used on exotic metals. TIG does require quite a bit more time than MIG to learn. It is similar in technique to gas welding.
Aug 27, 2008 | Radnor Model 105Z55 Push On Smooth TIG...
Troy MIG100 90-Amp. Wire Feed Welder Logo
2,166 people viewed this question
Top Troy Welding Tools Experts
Bill Boyd
Are you a Troy Welding Tool Expert? Answer questions, earn points and help others
