Question about SanDisk Sansa e250 MP3 Player
Player does not connect using MTP USB mode
When I plug the player to the computer in MTP USB mode, the player either keeps disconnecting and connecting over and over again spontaneously, or it shows up on the player´s screen as connected but the computer does not detect it. The MSC mode works just fine. How do I fix this problem.
  • hilda_b Dec 01, 2008
    I have the same problem-do i recover or reset
  • desimone Dec 02, 2008
    Computer does not see player
  • 8,596 Answers
Uninstall the MTP device in device manager to prevent the annoying problem of continuous pop-ups.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix.
Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61
Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware
NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit
May 17, 2010 | SanDisk Sansa Clip MP3 Player
Is there a way to manually make your mp3 player to charge? I know that having your mp3 player plugged into a USB is suppose to do it but all I'm getting is USB Connected on my screen.
When the player is empty, it will need to charge for 8 hours to become completely full. Using a laptop see to it that the computer is not switching to sleep or hibernating mode, else the power on the USB ports will be switched off.
Since the player shows being connected, the device can be linked
with the cable in 2 ways. The mode can be set in the menu. When MTP mode is not available the player will connect in MSC mode:
  1. MSC mode: the computer sees the player as a removable disk, the player can be seen using the Windows Explorer:Before disconnecting in MSC mode always go through safely remove hardware.Resetting the player may be required when the player freezes: disconnect the player and gently reset the player on the back side with a narrow pointed object, e.g. paperclip.
  2. MTP mode: there's software installed on the computer like Coby Media Manager or Windows Media Player 10 or higher. The software can be used for making transfers between computer and player.
When needing more help, just add a comment in this thread.
Jan 21, 2010 | Coby MP815 Digital Media Player
How do you take music off your mp3 player
The Sansa c140 can be operated in MSC and MTP mode for transferring and deleting music files.
See also setting USB mode for autodetect or MSC mode on page 16 of the manual: link to the Sansa c100 series manual.
  • For deleting files a connection to a computer has to be made in either MSC or MTP mode, see page 10 of the manual.
MSC mode means that a computer will see the player as a removable disk when connected.
It's like exploring the computer detecting the player as an external memory, showing up as a drive letter with about 1 GB of memory.
Before disconnecting the player, always safely remove hardware, the icon in the bottom taskbar on the right.
MTP mode means that a computer has software installed like Windows Media Player 10 and in this software, when started, the player is being recognized as Sansa c140.
Before disconnecting the player, wait for the message that it is allowed to disconnect the device.
How to use Windows Media Player 10 ? See the site of Microsoft:
http://www.microsoft.com/windows/windowsmedia/player/10/using.aspx
Need more help ? Just post a comment.
Dec 27, 2009 | SanDisk Sansa c140 MP3 Player
I want to download an album from my computer to my Insignia mp3. When I plug the player into my computer all I get is the charging screen. I want to get the album from media player.Jerry
When the player connects only with the charging display, there are 3 points that need to be checked:
Battery and cable connection
1. Connecting the player to the computer, the charging symbol should start loading; battery "green" or "partly green" indication. The player should respond with "OK to disconnect" = connection established correctly.
For proper charging and connection put the USB cable plug directly to the computer preferred at the back side: not through a hub or card reader.
MSC mode
2. The player is switched to MSC mode. MSC = Mass Storage Class. In this mode the device is seen as a flash drive also called removable disk, that can be accessed using Windows Explorer.
The Hold switch was in hold position on the top side, before connecting to the computer.
Disconnect the player and release the hold switch. Next the player should be in standard MTP mode. MTP = Media Transfer Protocol used for transferring files with media software.
MTP mode
3. The media software on the computer for transferring files is not installed or not working properly. Update or reinstall the media software.
Manual for Insignia NS-DV2G:
http://insigniaproducts.com/cms/documents/NS-DV2G%20UM%20EN_SP_FR.pdf
When this didn't help the firmware on the player needs to be reinstalled.
For firmware see the Drivers in the Support tab of the next link:
http://insigniaproducts.com/products/portable-audio/NS-DV2G.html
Oct 01, 2009 | Insignia NS-DV2G MP3 Player
Need to mp3 out of mtp mode and into usb mode need help
in the manual it says Turn on the MP3 Player by holding the PLAY/PAUSE button. 2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer. 3. When connected the LCD Display will either say “USB” or “MTP”. 4. Press the “M” (mode) button to switch between “USB” and “MTP” mode. “MTP” mode will only work, when your player is connected to Microsoft® Windows® XP and Windows® Media Player 10. The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional. 5 is this helpful.Take your time sometimes these things don't work because you've missed out one step so go slow and try it two or three times before you give up
Aug 29, 2009 | GPX MW3837 MP3 Player
I downloaded a Sansa video converter and it keeps saying that my Sansa is not connected after i connect it. Can i have some assistance please?
do u have windows or mac system? if mac,
Although MAC OS is NOT a supported operating system, the Sansa player can still be recognized if the Sansa player is only plugged in MSC mode.
MAC computers do NOT support MTP
A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized.
MAC computers supports Sansa players in MSC mode
Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
See answer ID 207 for instructions on how to put your Sansa player in MSC mode.
See answer ID 1141 for instructions on transferring music to your Sansa player using iTunes on a MAC computer.
Aug 01, 2009 | SanDisk Sansa e260 MP3 Player
when i plug the player to the computer USB port , the player either keeps disconnecting and connecting over and over again spontaneously, or it shows up on the player' s screen as connected but the computer does not detect it.how do i fix this problem
Dec 01, 2008 | SanDisk Sansa e200 MP3 Player
MTP Mode Doesnt Work
Try uninstalling MTP Mode in the Windows Device Manager, and replugging the player - set the menu setting in the Sansa itself to "auto" for USB Mode before replugging. Let me know how it works.
Jun 13, 2008 | SanDisk Sansa e260 MP3 Player
Switch from MTP to USB
I had this same problem and was able to solve it. Just go into Control Panel (make sure it's in Classic View)-> System -> Hardware -> Device Manager, right click the GPX icon under Protable Devices and then click unistall. Then disconnect and reconnect the player. Windows will automatically install the drivers and that's it, you can now go into USB mode again. Hope it helps.
Jan 20, 2008 | GPX MW3837 MP3 Player
Rio s10
? Verify that the USB cable is securely inserted into the USB port on both the Rio Carbon and your computer. ? Connect the USB cable to a USB port on the back of your computer rather than to a USB port on the front of your computer. ? If using a USB hub, connect to a powered USB hub. Unpowered USB hubs may not work. ? Remove USB extension cables from the connection path. ? Disconnect other USB devices. ? Both Windows XP Service Pack 1 (SP1) (or greater) and Windows Media Player 10 (WMP10) must be installed for your computer to detect a Rio Carbon set in MTP mode. ? If you do not want to install SP1 (or greater) and WMP10 on your computer you should disconnect the Rio Carbon and change the Transfer Mode setting to MSC mode. Good Luck
May 24, 2007 | Rio S10 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
57 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
