Question about Memorex MP3225 Cassette/CD Boombox
Memorex MP3225 Cassette won't play
Memorex MP3225: Put cassette in slot, closed the door (most times it doesn't want to close all the way, but I keep opening, adjusting tape, then closing - I don't force it, though). Rewind and FF work, but unable to depress Play button. Tried putting cassette in place, leaving the door open, same response (Rewind and FF work, won't play).
Any suggestions?
Thank you!
Michele
2 Suggested Answers
  • 357 Answers
SOURCE: cassette player doesnt play or record, ff or
Hi.
If you hear a faint whirring sound from the cassette player while performing these functions, the motor is fine, but you require a new drive belt/s that need to be fitted at an electronics shop. If you hear not sound at all, the motor has died (possibly belts too), again it will require and electrinics repair shop visit.
For the sake of repairing it, it maybe cheaper to buy a new one.
Posted on Jan 14, 2011
How do I load the tape
I see your picture of a cassette player. Guess you are referring to that. (tapes also come in reel-to-reel, and 8-track). Just push the "EJECT" button (power may need to be applied to some units for the eject button to work). The tape slot will open. Insert tape with exposed tape on the "head" side of the opening, usually the heads are on the bottom of the slot.. You can't put it in any other way and have the door close. The "door" that opens has guides for you to slide the tape into. The side you want to listen to should face you. Either manually close the tape compartment or push the close button (depending on model). If the door doesn't close, you put it in upside down. Push play and enjoy.
Oct 01, 2014 | Audio Players & Recorders
The slot of the cassette in my sony CCD-TR705E video Hi8 doesn't close
Possibly faulty cassette eject mech as the click locking is mechanical before it latches the cassette in switch
Apr 17, 2013 | Video Cameras
I search the user guide manual french or english for my canon es3000 The problem with this camera is : i put one video cassette in the camera and i close the door the door close but the door open back...
From your question, it sounds like you are trying to view a video which has already been recorded on. If that is correct, the video cassette may need to be rewound to the beginning of the tape,
Jan 24, 2011 | Cameras
When i rewind it comes up with press the reset button
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time
leaving the cassette inside and the battery attached.
Solution:
1. Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
2. Push on the right place (marked "push") to close and then close the
cassette housing
3. Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder
for long period without being operated, and store the camcorder in a
dust/humidity protected place.
Hope this can help.
Jun 29, 2009 | Panasonic NV-GS25 Mini DV Digital...
Cassette doesn't load and move down into machine
I had the same problem. With the camera on, keep taking the battery off and putting it back on. Start to close the door and then open it. Eventually you should hear it try to move. Keep doing it and it should move down all the way.
Jun 01, 2009 | Sony DCR-HC38 Mini DV Digital Camcorder
Panasonic dv camcorder keep havin
It happens usually when you don't operate the camecorder for long time leaving the cassette inside and the battery attached.
Solution:
1.
2.
cassette housing.
3.
Advise: Remove the battery and cassette when leaving the camecorder for long period without being operated, and store the camcorder in a dust/humidity protected place.
Hope this can help.
Abdullah
Jul 14, 2008 | Panasonic Video Cameras
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
CD door will not stay closed
the hook that holds the door to the machine is broken or worn off or whatever
Feb 23, 2008 | Memorex MP3225 Cassette/CD Boombox
Memorex MP3225 Cassette/CD Boombox Logo
Top Memorex Audio Players & Recorders Experts
Greg Cann
Greg Cann
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
