Question about Toastmaster A710S Sandwich Maker
Top of grill scorches toast
When using toastmaster it will work fine as a toaster or grill cheese maker then it will start scorching the bread. turn it off let it sit a while then when started back up it will work fine for a few hours.then same results.
0 characters
1 Points
Www prodprotect com applica
I just purchased a toaster oven and it worked just fine, until the on light wouldn't turn on. Any advise to fix light?
Jan 13, 2014 | Electric Grills & Sandwich Makers
How to us the betty crocker stuff n munch?
You actually don't need to cut the bread into triangles because when you push down and it cooks it, it makes creases so that you can easily pull them apart.
Oct 09, 2008 | Betty Crocker BCF1940 Sandwich Maker
Sandwich maker recipes
Found this on another website... not sure where... just had it copied to my word document... but here it is.
Warm up sandwich maker first…. Then spray with cooking spray.
Fruit pies
Two pieces of bread and apple pie filling (2 Tbsp)… cook 2-4 min Sprinkle with cinnamon and sugar when done.
Hot pocket
Ham and cheese
Egg Sandwiches
Egg Bacon and Cheese sandwiches
French toast… batter and cook, sprinkle with cinnamon and sugar? Cover in syrup
Pizza pockets
Cheese sauce and pepperoni
Mexican Fare
Using Tortillas add meat, cheese, or peppers
You can use…
Pancake mix
Muffin mix
Cornbread mix
Stir and pour into the sandwich maker Cook until done a few minutes.
Jun 30, 2008 | Salton Snack n Sandwich SA8 Sandwich Maker
Insufficient heat
I do beleive the heater element has reached end of life and need to be exchanged, you can contact the distributor in your area, or you can contact the manufacturer directly in Europe that will forward you to the nearest tech support center, do not forget to tell them where you live (city is enought) you have their contact in their webpage
Jan 21, 2008 | Flama G1600 Indoor Grill
I'm assuming you mean the power cord. Most of these units use standard power cords. Take it to an appliance parts store to match it. If you can't find the cord you want, extension cords called heavy duty are available. Be sure that the power draw on the label on the cord equals or exceeds that of the unit. Some cords use 'amps'...some appliances use watts. To get amps from watts: take the wattage, divide by volts (typically 120) to get amps. A 1200 watt appliance uses 10 amps. Use the next highest rating.
Jan 01, 2008 | Electric Grills & Sandwich Makers
Toast problem
i also have a gr82 but i don't have a manual and can't seem to find one online. can anyone help me with this?
Nov 17, 2006 | George Foreman GR82
Toastmaster A710S Sandwich Maker Logo
26 people viewed this question
Top Toastmaster Electric Grills & Sandwich Makers Experts
Michael Thomas
Michael Thomas
tina gallow
Are you a Toastmaster Electric Grill and Sandwich Maker Expert? Answer questions, earn points and help others
