Question about Lexmark Office Equipment & Supplies
Lexmark x5400 got uninstalled,how do i install it back on my compaq presario which supports windows XP.I have setup disc.
  • 628 Answers
Just run the setup program from the disk.
Posted on Dec 01, 2008
I have windows 7 with a Lexmark x5400 printer, model 4425-001, my computer will not connect with printer. i can't get in to change the printer port to"enable bi-directional printer". it...
Try this approach instead:
  1. Uninstall your existing printer software from your computer. From your computer, go to Start menu > Programs > Lexmark X5400 Series folder > Tools > Uninstall.
  2. After the uninstall process, reboot pc when prompted.
  3. When pc turns back on, check if your system is running on 32-bit or 64-bit. From your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
  4. To re-install the printer software, please visit the Lexmark website. Use the link below:
- Lexmark X5470 Driver for Windows 7 32-bit- Lexmark X5470 Driver for Windows 7 64-bit
Simply follow the instructions on your computer screen to complete the installation.
I hope this helps.
Nov 07, 2011 | Lexmark X5470 All-In-One InkJet Printer
Printer isnt working its lexmark x5400 series cant find software thet i had that came with it
You can dowload the software from Lexmark. Go to:
Lexmark X5470 Support
Click on the Downloads tab. Select the file that matches your operating system and click on Download Now. When the download window opens, select Save and direct it to save to your Desktop. Once the download is complete, close all open programs, make sure you uninstall any previous Lexmark software and delete any X5400 printer using Control Panel>Printers.
Install the printer using one of the Setup Guides that can be found on the support link above. (Click on the Publications tab.) When it says to insert the CD, simply run (double-click) the file on your desktop that you downloaded. That should get you going.
Thanks for using Fixya.
Oct 20, 2009 | Lexmark Office Equipment & Supplies
I am not able to install Windows XP on Compaq Presario CQ60-104TU
Recommend removing OLD DOS Operating system First. Then Install Windows XP. XP will NOT upgrade older systems unless it's Windows 98 and Fully Updated. However, can NO Longer do because Microsoft does NOT support any versions other than "2000/ME/XP/Vista".
Jun 09, 2009 | Computers & Internet
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
Windowsn xp
Windows XP installation problem in Compaq Presario CQ40-108TU
Hi, go to this link and read carefully about this article:
http://www.zyxware.com/articles/2008/10/17/windows-xp-installation-problem-in-compaq-presario-cq40-108tu
*Your vote is highly be appreciated. I hope this will help you. Drop me a comment if you still have problems. I will help you.
Jan 05, 2009 | Compaq Presario Notebook
Compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Aug 12, 2008 | HP Compaq Presario v3000z Notebook
Window's xp
what gives you this message? xp setup?
Apr 13, 2008 | Compaq Presario 700 470024-192 Notebook
USB Problem
hmmm external hard drive should work without any problem as windows xp allready have inbuilt drivers for mass-storage.
try to Uninstall the USB driver, goto Device manager and Uninstall USB, then reboot to clean system registry and install USB driver from Windows XP setup disck. and try the external-hard drive, xp should recognize your external-hard drive. If not then install driver for your drive if you have and try. for camera and ipos u need to install drivers and supporting softwares from your manufacturers.
thanks
Iqbal
Mar 31, 2008 | HP Compaq Presario R4000 Notebook
81 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
