Question about GE Monogram ZISS420DRSS Stainless Steel
Ice Maker Quit Working
I have a GE Monogram s/s built in model number ZISS420DRSS that is apx 5 years old. The ice maker just stopped working. I have it connected to R/O water and the water through the door is working. Typically, I hear a noise from the freezer when the ice maker is filling and dropping ice but no ice for the past few days. I have taken out the ice maker to see if there was any build up or possibly anything on the surface I could fix but appears not. Any suggestions on possible cause of issue?
  • jlubno Nov 30, 2008
    Thanks. I don't really want to get into technically why the i/m needs to be replaced but curious what could be wrong with the i/m. The light is on when in the "on" position and the it appears to be making some noise when I turn it off and then on. What would be a symptom of the water valve being out? Does the i/m trigger the water valve to open/close somehow and since the i/m is not filling with water, something it wrong with the i/m?
    Sergeant:
    Champion:
  • 311 Answers
Replace the whole i/m - it is bad. Takes 5 minutes to do. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
  • JEFF SIEGEL Nov 30, 2008
    I/m fills only when it cycles. All I know is if it does not cycle it is bad.
I have GE Monogram Side by Side. Purchased back in August 2006. It has been pretty good except for the ice maker. After the first year a leak ruined our new wood floors. Recently the ice maker has...
The green light flashing is a fault code, usually for a no, or long fill situation, GE has nixed this electronic ice maker and returned to one that looks similar but is non electronic, while your ice maker is probably at fault you may actually have a separate issue causing the ice maker to display a fault code, such as a spent water filter, or low water pressure, or even a bad water valve on the fridge it's self. IM6 is the current replacement ice maker kit for previous ice makers. Pleazer Appliance...
Apr 17, 2014 | GE Monogram Side by Side Refrigerator
GE MONOGRAM ZFS826DRC SS ice maker not working
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Mar 06, 2011 | GE Monogram ZISS480DRSS Stainless Steel
Water overflowing in ice maker tray on a GE
make sure your refrigerator unit is level first . If it is , and you have eight square faced plastic cover on the front of the ice maker itself that can be removed by un- snapping it, remove it and see if there is a small screw with a spring underneath it or positive or negative arrow's on the unit where the screw is located. Regardless, if there is a screw all by itself turned the screw 1/2 turn Counterclockwise. this will decrease the amount of time the water valve is open during the ice bin filling cycle.
Mar 13, 2010 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram icemaker is not working. The green light on the ice maker is blinking every second. I turn the ice maker off then turn on after a few second. The light stays green. After 10 minutes, I...
Your model uses a electronic ice maker. If the tray has srinking cubes and if you fill to top with tap water, let freeze and if it does not drop the ice the problem most ikely is the icemaker mode=> WR30X10093 The ice maker has a thermistor or thermostat built in and communicates with the circuit board inside to tell when it is time to cycle. You can try the water test and let me know but this is a typical failure with that type of ice maker. If this solve you ice maker problem please rate me. If not explain what you tried and we will try the second test. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Feb 11, 2010 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram fridge over freezer model has stopped making ice
water valve dripping like a faucet and making a big old ice cube in the fill tube? Ice cube hung in the ice maker? bad water filter? A wittle bit of all of the above?
MONOGRAM MANUAL
IM6 notes
Bonus
Jan 12, 2010 | GE Refrigerators
Ice maker will not dump ice there is ice in "tray" but wont dump
I.M 6 electronic Ice makers are non servicable, replace the ice maker. throw the other in the trash can.
If ice is in the ice maker then you know it got water but didnt dump the ice. its the ice maker.
Oct 26, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Intermittent rattling noise in refrigerator
Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
Hope this helps.
Jun 27, 2009 | GE Monogram Refrigerator Built-In...
Drive Mechanism Doesn't Turn
pull the ice tray out and have someone push the ice botton,look to see if the auger arm in back is moving and the ice tray auger is moving ,let me know what you find-mike
Oct 09, 2008 | GE Monogram ZISS420DRSS Stainless Steel
GE Monogram ZISS420DRSS Stainless Steel Logo
307 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
