Question about VMware ACE for Windows (ACEENGWC) for PC
At start-up, I must restart Remote Service from services.msc
Each time I start VMServer, I get an error message (511) and must restart the remote access service manually even though it is set at automatic. Windows error reporting says that VMServer took too much time to initialize
Spoke to one of my client's IT people; he gave me a script to read into registry that solved the problem.
Posted on Dec 01, 2008
Remove error106
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
or
NTFS Partition
1. Click the Start button, point to Settings, click Control Panel, and then double-click Services.
2. Select the Event Log service and click Start up. Change the Start up Type to Disabled, and then click OK. If you are unable to log on to the computer but can access the registry remotely, you can change the Start up value in the following registry key to 0x4:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog
3. Restart Windows.
NOTE: When the system starts up, several services may fail; a message informing the user to use Event Viewer to review errors may appear.
4. Rename or move the corrupt *.evt file from the following location:
%SystemRoot%\System32\Config
5. In Control Panel Services tool, re-enable the Event Log service by setting it back to the default of Automatic start up, or change the registry Start up value back to 0x2.
FAT partition (Alternative method)
1. Boot to a MS-DOS prompt using a DOS bootable disk.
2. Rename or move the corrupt *.evt file from the following location:
3. Remove the disk and restart Windows.
When Windows is restarted, the Event Log file will be recreated.
hope this helps
Jul 03, 2012 | Computers & Internet
Tip
Windows Defender 0x800106ba Service Error on Automatic Startup
Some times even when the Windows Defender service is set to automatic you still might see the Error below and even when you have tried this site http://support.microsoft.com/kb/931849 which tells you to remove the program and then use the windows installer cleanup utility form HERE and start again you still get the same error
This is a method is bit drastic I suggest that first you update manually the definitions from HERE then download my Windows Defender FIX from my Public SKYDRIVE then restart you PC it should now fix the above error it will re-register all the DLLs that are needed to allow the error to go
on May 01, 2010 | Microsoft Windows XP Professional
I am having problems connecting VPN Connection on my Windows 7, it says there need to be a machine certificate installed before i can connect using L2TP/IPsec. error code :766
"Error 766: A certificate could not be found. Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate."
"Error 766: The L2TP connection attempt failed because the security layer could not authenticate the remote computer."
Cause: Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate. You will see this error message when such a certificate is not available.
Typically, this error is generated on a remote access server that has active L2TP ports configured, the remote access service started but there is no certificate in the computer certificate store. This generates an event log message that tells the administrator that L2TP ports will not be able to accept calls until a certificate is acquired and RRAS is restarted.
Resolutions: 1. If you use PPTP VPN, select Automatic in Type of VPN.
2. If you use L2TP, check the remote access server and make sure there is certificate in the computer certificate store.
Sep 18, 2010 | Computers & Internet
Hi i purchase nokia 5235 mobile. airtel service
These are the ways you can activate your GPRS and Airtel Live settings:
Send MO to 2567 from your Airtel mobile (2567 is a toll free number).
You will receive settings for Airtel Live, Airtel mobile office i.e Airtel GPRS and Airtel MMS.
Save the settings you want to use.
If you want to surf only limited site then I will recommend Airtel Live, specially when you are using Free GPRS trick that will be useful for you.
Else you can go ahead and save the settings for Airtel mobile office and Airtel MMS.
Now to activate Airtel GPRS you need to send GPRSACT from your Airtel number to 511( which is a toll free number). Do remember Airtel GPRS is not a free service and you will be charged.
But there is unlimited downloading on Airtel GPRS service (the paid one).
You can also deactivate it by sending a message GPRSDEACT to 511.
Though Airtel Live is activate by default but in case Airtel live is deactivated you can activate it by sending LIVEACT to 511 and to disable it LIVEDEACT to 511.
Jun 28, 2010 | Nokia Lands Phones
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
    Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
    May 10, 2009 | Canon PowerShot SD1000 Digital Camera
    Error 321 'ethernet not connected' on LINKSYS WRT54GS
    Dont go with the error , i came across such instances on a few occasions while users were installing it from CD . (Sounds lamme?right)
    Try doing the set up manually , by accessing the web Gui of router .
    ***FOLLOW THIS********
    The GS comes set to 192.168.1.1 as its factory default and with its built-in DHCP server enabled. So all you'll need to do is plug in a client that's set to obtain its IP address information automatically, maybe do a DHCP release / renew (or reboot your client computer), and enter the default password into the login box that pops up. If all goes well, you'll get the main Setup screen.
    The Internet Configuration Type selector automatically refreshes the browser screen to present settings appropriate to the choices of Automatic Configuration - DHCP, Static IP, PPPoE, PPTP and Heartbeat Signal (for Australian users) Internet connection types.
    MAC address cloning gets its own page in the Setup section, as does setting up either dynamic DNS service from dynDNS.org or TZO, setting up static routes or disabling NAT features and converting the GS to a non-NAT router.
    The interface is generally quick, with quick mini-reboots needed to get the changes you make on each page to take. Multiple admin logins are allowed, with no warning given when two or more admins log on. Once you're logged in, there's no idle timeout, and you just need to remember to quit your browser when you're done, because there's no logout button.
    Enabling Remote Management for the first time still pops up a message telling you to change the router's default password and you can now enable secure (HTTPS) admin access. You can also change the default remote admin port from 8080, but can't restrict access by IP address or domain. Also of note is that you can't reboot the GS from the Admin interface.
    Let me know if you require any more assistance.
    Apr 18, 2009 | Linksys Wireless-G WRT54GS Router...
    Won't scribe
    1. Clean Drive: commercial cd/dvd cleaner + air compressed can with narrow pipe inserted into device to reach lens.
    2. Update you sw from http://www.lightscribe.com/ (Control panel, diagnostic tool, application)
    3. be sure service is started: as Administrator go to Control panel/Administrative tools/Services
      double-clickon Lightscribe Service, and if it says disabled change it to automatic,then "start service" in the left pane if is already started and set toautomatic stop and restart it you don't have to reboot to see results.
    It worked for me on HP6710b with internal drive and with liteon external burner
    Oct 23, 2008 | QPS Que! Fire CD-RW Burner
    Pc restarts automatically and unexpectedly
    Good Evening Sunnyseber :
    Hope that you are wellJ
    You did not indicate the type of Operating System.
    This document pertains to HP and Compaq computers with Windows Vista. If Windows Vista suddenly starts without warning, or restarts when you try to shut it down, it may be because your operating system is set to automatically restart when certain system errors occur. This feature of the Windows Vista operating system can be disabled. Use the information below to disable the Automatically Restart option. NOTE: In addition to the steps in this article, updating video card drivers is known to resolve many of the problems that can cause the computer to restart. Step 1: Disabling Automatically restart option to view error messages You can prevent the computer from restarting by turning off the Automatically Restart option:
    1. Click Start c00971562.gif .
    2. Right-click Computer , and click Properties
    3. Click Advanced system settings .
    4. Click the Advanced tab and select Settings in the Startup and Recovery section.
    5. Remove the check mark next to Automatically restart under System Failure .
    6. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
    7. Restart the computer. NOTE: The computer will no longer restart automatically when a problem occurs. Instead a blue screen appears with more useful information. You can now search for a resolution using the text from the error.
    If I can be of further assistance, please let me know.
    And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
    Have a wonderful evening.
    Sep 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
    Enet service
    The eNet service is an Acer-specific connection management program. For some reason the service has stopped running. You can check its status through control panel.
    Go into Control Panel and from there into Administrative Tools. The Services list is there. You might need to check that it's set to start automatically, and that it is running. If it's not running, start it and set it to start automatically. If it seems to be running, restart it and see if you get any error messages. If you get error messages, post a followup comment on this ticket and I'll try and help further.
    May 27, 2008 | Acer Aspire 5100 Notebook
    VMware ACE for Windows (ACEENGWC) for PC Logo
    268 people viewed this question
    Top VMware Computers & Internet Experts
    matt
    matt
    CarlosIjalba
    Tproverb
    Level 1 Expert
    Are you a VMware Computer and Internet Expert? Answer questions, earn points and help others
