I WILL ANSWER THESE QUESTIONS IN ORDER,
1. STK 392-110 IS A REGULATOR. REPLACE THEM WITH SAME NUMBER THAT CAME OUT. DIFFERENT TVS USE DIFFERENT REGULATORS.
2. YES. MY PARTNER IS A DUMMY AND HE CAN DO IT
YOU WILL NEED SOLDER, SOLDER BRAID,(USED FOR REMOVING SOLDER) HEAT SINK COMPOUND (THATS THE WHITE PUTTY THAT YOU WILL SEE ON THE REGULATORS) AND AN OHM METER.
3. YOU SHOULD REPLACE THE RESITORS THAT ARE BAD. CHECK THEM WITH THE METER ( THEY SHOULD READ THE SAME VALUE THAT IS PRINTED ON THEM. EX; 1.8 OHMS SHOULD READ 1.8 OHMS ON THE METER. (THEY MAY BE THE SAME AS THE FIRST REPAIR BUT, CHECK ALL OF THEM) REPLACE WITH EXACTY THE SAME VALUE.
4. ON THE COVERGENCE MODULE THERE MAY BE A SMALL BUTTON THAT BRINGS UP THE GRID ON THE SCREEN WHEN THE TV IS ON. IF NOT ; YOU SHOULD BE ABLE TO BRING THE GRID UP WITH A JVC FACTORY REMOTE . (GO INTO THE MENU)
5. THERE MY BE A MANUAL FOR THIS BUT I HAVE NOT EVER SEEN ONE.
I HOPE THIS HELPS YOU, PLESE BE CARFULL. EVEN SIMPLE SOLDERING TAKES A LITTLE PRACTICE. DONT WORK ON TV WHILE ITS PLUGGED IN.
THE DUDE
