Question about Dryers
New dryer smells
Brand new Kenmore Elite Oasis HT 78062 gas dryer: first time drying a load a laundry, after a couple of minutes a burnt smell coming out from inside drum. Clothes were okay, nothing visibly wrong. All shipping plastic was removed, unit was professionally set up by Sears deliverymen. Is it possibly simply initial residue burning off or something serious?
Mike
  • Anonymous Apr 03, 2009
    I have the exact same problem with my 3 day old LG HE dryer from sears. I am calling them tomorrow to find out. Mine is electric though, not gas.
  • Dryers Master
  • 1,769 Answers
If it's just residue, it should go away quickly. If it doesn't, I'd call warranty service out since it's new.
Posted on Sep 07, 2017
    Habit-Forming:
    New Friend:
  • 73 Answers
Some times in a brand new machine their might be packaging that was left underneath I would disconnect vent,unplug and tilt to be able to look under it
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
  • 6 Answers
SOURCE: LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Posted on Dec 28, 2008
SOURCE: my 18 month old kenmore
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Posted on Jan 16, 2009
  • 10865 Answers
SOURCE: Sears Kenmore elite quietheat front loading dryer not drying. Moisture builds up on the window inside.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on May 28, 2009
heatman101
  • 43501 Answers
SOURCE: my dryer smells like burnned its an elite kenmore
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
Why won't it start?
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Dec 12, 2015 | Kenmore HE5 Electric Dryer
Burning smell in dryer
Have you checked the motor? Plenty of lint and dust gets indie it. If you can remove if and use compressed air to blow it out. Also don't overlook the fact all the spade connectors will also collect lots of lint and dust which is quite flammable. Also check the tensioner and guide wheel they get pretty dirty and when they heat up the lint can start buring.
Aug 11, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
My dryer smells like burnned its an elite kenmore oasis and it doesnt dry very good
heatman101
Sep 06, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
I have an elite kenmore dryer and it doesnt dry and it smells like burnned
heatman101
Sep 06, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Bath towels smell sour
I started adding 1 cap of bleach with 1 cup of water to all my loads in the bleach dispenser and this stopped the smell problem with my sweaty clothes.Sour towels i fixed with using Win high performance sports detergent plus my usual dose of he detergent along with a 2nd rinse.Keep the lid open when not in use always.
Dec 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Front Load - smell of burning rubber while in use
I've never had a smell problem like this before, but I have had the rubber lining to the door "shred", leaving eraser shavings all over the laundry. This happened with my first HE3t and I complained at SEARS and they just sent out a brand new replacement. About a month or two later, the same thing happened. I had SEARS come out and replace that rubber seal, and haven't had a problem since.
Although I can't answer on the smell, I highly suggest you keep an eye out for shavings on your laundry. Also, with the door open, at the bottom you can pull back the rubber seal slightly and expose the drain to be sure nothing is clogged or getting caught in there.
Oct 10, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
499 people viewed this question
Top Dryers Experts
