One of My Hard drives has suffered complete motor failure, (it wont spin). I have tried the obvious like replacing the controller,and gradually raising, lowering the temp to see if it will free up, no joy. Any help on where I might find some guidelines on transplanting the platters from the drive into an identical one to recover the data, would be greatly appreciated. I am confident I can do this, but would like to read up on it a bit more first.
  • 31 Answers
Ok, your in forensic level territory here - if the platters are damaged physically (head crash) which sounds likely if the platters arent spinnng and you have replaced the motor- you stand little to no chance of recovering all the data - also the flying heads require a 2-micron gap from the surface that demands specialist equipment - if the data is so important I would suggest a recovery specialist - where they disassemble your drive and take it into a clean room where precision controlled drive heads are used.
Posted on Nov 30, 2008
Boot failure insert system disk, but it wont load
You need to check both in BIOS by pressing F key during boot. First check to see if HD is there. If OK, then change Optical drive to first boot, save and reboot.
IF MISSING HD -
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 07, 2012 | Computers & Internet
Tip
Reasons why Hard Drives fail.
A hard drive's file system may become corrupted or damaged due to a virus or software malfunction, but this is not a true drive failure because in most cases you can reformat the drive and reinstall the operating system and everything is back to normal. Hard drives fail due to a malfunction in their mechanical or electrical components.
The following picture illustrates the major components inside a hard drive:
The following is a list of the most common mechanical failures that can happen.
1. The spindle motor can malfunction. The spindle motor works much the same way that cd-rom or dvd player spindle motor works and is located in the middle of the hard drive platters. In a hard drives case, it's job is to spin the platters.
2. The read/write heads malfunction or the actuator arm malfunctions and prevents the read/write heads from reading the data stored on the hard discs (the platters). The picture below shows a closer view of the platters, actuator arm, and read/write head.
3. The hard discs themselves can become damaged by rough handling (dropped) or can in some cases become scratched by the read/write heads if they touch the disc.
4. On the back side of the hard drive case you will see where the cable and power supply plugs in and you will also see where the jumpers are. These contain small pins and can easily be bent or broken.
5. Another problem that can occur is the cables and ribbons themselves become loose and do not make a proper connection or the cable themselves can become damaged. The power cable can also become damaged or malfunction.
Picture of an IDE cable.
Picture of a SATA cable.
Hard drives can also fail due to malfunctioning or damaged electronics on their circuit board.
The most common electrical components to malfunction are Transistors, Capacitors, and Resistors. Power surges are the common cause of these small components to fail, so remember to make sure you are using a good surge protector or a UPS system for your entire computer system. A good policy is to always unplug your computer system from outlets when a storm is capable of producing lightening. It is also important to remember that if any of these failures happen, it will be cheaper to replace the drive for a new one. You can return a hard drive to the manufacturer to be fixed if it is still under warranty. Read your documentation and warranty information carefully if you purchase a new hard drive to upgrade/replace your old one.
The following picture is an illustration of where the hard drive is located inside the computer case. In this case, it is a SATA hard drive.
on Jan 10, 2010 | Computers & Internet
My OptiPlex GX60 is not recognizing its hard drive? Several weeks ago had to restore with install CD. On a restart, wouldn't load, report said no hard drive.
Most likely it is a Hard disk drive failure
Reseat the cable connections, see if the drive is detected, if not, replace the drive
Jan 26, 2010 | Dell OptiPlex GX60 (SFFDELL-C2G) PC...
I am trying to get my cousins acer x1200 going he put a new hard drive in it because he thought his old one stopped working it wouldn?t boot up into window it would boot up until it got to windows then...
Error Stop 0x0000007B can be related to viruses,hardware failure or a device driver issue.
Lets try this :--
Step 1- Insert windows XP disk and try to get into recovery console.(Can follow instruction displayed on the
screen)
Step2 - Once you login to recovery console, run chkdsk /p followed by chkdsk /r.
Exit the command prompt after chkdsk /r completes and restart your computer and see if that works,.
Step 3 - If it doesnt, try running a repair installation with windows XP.
Step 4 - Insert the windows XP disk, press enter to continue setup followed by press R for repair.
Step 5 - Let repair installation complete and restart your machine to check status of your computer.
Hope it helps !
Thanks
Oct 06, 2009 | Acer Aspire X1200-B1601A PC Desktop
Roaring to a grinding like sound coming from hard drive.
Make sure you have backups of your data, and if you don't, and it's functioning, make them now. This is a sound of imminent failure. See link here., here, and here. or here.
If you google hard drive failure and hard drive recovery, you'll find a plethora of links with possible solutions to recover lost data and resuscitate failed drives. Some people seem to have luck recovering info from failed drives by using a hard drive usb caddy, such as described here.
It's a simple enough matter to replace the drive and reinstall your OS, and you'll be able to download all the drivers you need for your hardware to function from dell if you no longer have the cds, but your data is another issue entirely.
I hope you have backups, and if you don't, you are able to make them now. In any case, good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 08, 2009 | Dell Dimension E521 PC Desktop
Completion Code 2? Hard drive failure?
Ok let me try to give my idea,
Are you familiar of running it in DOS(if your OS is windows). Try to boot in cdrom using DOS. Then try to access your harddrive using the command prompt. Make some browsing up to third degree folder. If you can browse. Then probably your HD is good could be data corruption that's why you can't pass even in the safe mode. Then your options are repair, restore, or reinstalled depends on the features of your unit.
Leave some comments so I can give anothers ideas from your updates.
May 03, 2009 | HP Compaq Business Desktop d330 Slim Tower
4 components in failure, now what?
well as for the hard drive,, the laptop im currently on, also warns me of an impending hard drive failure and to back up all data when i start the laptop and ive been using it for several months this way, although i DO NOT keep anything important on here as it can completely fail at any time. As for the motherboard,, im surprized its still workign at all if its cracked so im guessing that wont last too much longer. And as for the fans,, its possible that either your processor is acting funny because its overheating due to the fans not spinning as fast as they should be,,, or your processor could just be shot.
Mar 13, 2009 | HP Compaq Presario SR1720NX (EL435AA) PC...
Hp media center - hard disc failure iminent
I am sure that noone wants to tel you thins but when you go the Hard disk failer iminent that was so you woudl shut it down and transfer everything onto another disk. Once it crashes, such as your has, you cannot recover the data w/o very expensive equiptment or costly contracting out the HD for data recover.      About the only thing that you can do now is replace the hard drive, download a   recovery disk from HP,if one is available, for your model, If you have not already made one, and reinstall the software from the disk.
Feb 16, 2009 | Computers & Internet
Hard drive is not working, waspurched one year ago.
This issue has many various factors on why a hard drive doesn't work the way it should be. Let's discuss it one by one:
First, ensure that all the cables ( SATA/PATA )are properly seated or attached to your MOBO. If the cables were checked, makes sure the molex which gives power to the hard drive is connected.
If all are in place, then a Primary & Slave of hard disk issue is another factor. Lets assume that you are using a PATA or IDE cable. If you are only using one IDE cable as of this moment an issue of setting your jumpers on their proper places. Make sure each jumpers are on the right places, the Master jumper ofcourse that should be on your Primary HDD ( w/c ofcourse w/ O.S. ) and the other HDD its jumper is on the slave.
Another one if the ( PATA/SATA ) is properly seated on the controllers of your hard drive.
Also, you try isolating the cables. Probably, the cables you are using are not working, obselete and needs to be replace.
Lastly, does your hard drive spins? Do you hear any clunking sounds? Then, it only means an issue of hard drive failure had arised and needs to be replace.
Sep 09, 2008 | Computers & Internet
I plugged a Lacie hard drive into my mac book pro and the light on the hard drive and on the power cord was flashing on and off but the hard drive icon would not show on my computer. i unplugged it and...
if your PC still works sounds like the circiut board in the hard drive enclosure may have fried.you can take apart the external hard drive enclosure and install the hard drive into the PC and use as a second hard drive( but be sure to jumper the slave pins on the second drive).Your PC should recognize the second drive and then you can click on my computer and the dbl click the second drive and see if your data is there.
Apr 22, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
