Question about Dell Inspiron B130 Notebook
I have a Dell Inspiron B130. I have brought 3 chargers. The computers has to always be pushed in or wiggled around to actually be charging. I think that it is the input prong. It seems to be loose and have a shortage in it. Can this be fixed because Im tired of buyig new chargers.
  • Dell Master
  • 32,281 Answers
The problem is not the chargers, it is the power connector on the laptop. Yes it can be fixed, laptop need to be dismantled to get access to this connector and a new one to be soldered in.
If you can't do it yourself the cost of fixing it may be expensive and if the laptop is a fews years old, it might be better putting this money towards a new laptop.
Posted on Nov 30, 2008
Dell inspiron b130 Laptop
Try to remove the battery, turn the wifi switch off just connect it to the power socket and try to turn it on again, if this does not work, I think you need to take it to pc hospital
Jun 02, 2017 | Dell Inspiron B130 Pentium M 1.7ghz...
Hi, I have a Dell Inspiron 1501 laptop, model no. PP23LA. My problem is that the system does not recognise the power adaptor/charger & will not charge the battery. The laptop will run with the power...
If the battery is not charging, the problem is most likely the battery...not the charger. Check around to see if you can get a battery replacement I think would be your best course of action. If you have a friend with a model laptop with the same battery you could always "test out the scenario" before purchasing one.
Good Luck
May 19, 2011 | Dell Inspiron 1501 Notebook
The light for the charger turns on but the computer won't turn on
Does the battery charge light come on? If not, then you either have a bad AC adapter or the motherboard is defective.
Feb 08, 2011 | Dell Inspiron B130 Notebook
Dell Inspiron 9300. Problem occurs when I try to charge it. The screen says it can't determine the adapter type and the battery does not charge. I can wiggle the charger cable around at the connection to...
The same exact thing is happening to my Inspiron 9300. Did you get it repaired? After reading lots of forums, changing AC adaptors and ordering a new battery, I came to the conclusion that it is the plug on the laptop that is not working.
Nov 17, 2010 | Dell Inspiron 9300 Notebook
My Inspiron B130 laptop wont charge. i have to wiggle the charger around, and sometimes that doesnt work.
Either the plug on the laptop is bad, or the charger cord is faulty. If you have a friend that has the same charger you can use it to find out which.
Laptop chargers do go bad...
Aug 04, 2010 | Dell Inspiron B130 Notebook
Bought a new power cord because I had to keep moving cord around to get battery to charge, move and would lose charge received new power cord and still have to move cord around to keep getting a charge...
First thing you need to do is STOP trying to wiggle the cord to make it work. You could damage the motherboard.
The power jack needs to be replaced. It's a pretty standard repair. You can try finding a local laptop tech from Craigslist or visit your local shop.
This type of repair usually runs 70-100 out the door (depending on where you live)
I don't recommend you trying to fix it yourself.
Apr 03, 2010 | Dell Inspiron B130 Notebook
My Dell Inspiron B130 will not turn on
The battery is critically low, indicating that it is not getting a charge from the AC adapter. If the system will not power on from the AC adapter, then the motherboard power connection is suspect.
Motherboards are about $100 on EBay
Feb 01, 2010 | Dell Inspiron B130 Notebook
Red Battery light flashes when computer is turned off
The reason the battery indicator would flash is because its reaching the end of its useable life. Meaning that it will become harder for the battery to keeps its charge until it finally doesn't keep a charge at all. best thing to do is when your not using your laptop unhook the charger to it so its not always charging the battery.
To fix the problem though you'll have to get another battery unfortunately.
Jun 02, 2009 | Dell Inspiron B130 Notebook
Dell inspiron E1505 won't charge or power on period!!!
Sounds like you might have a bad dc power jack. ifyou wiggle the jack around where it plugs in on the computer, does the powr light come on?
Mar 30, 2009 | Dell Inspiron E1505 Notebook
Charger
If the port is suffering from a bad connection, you have to re solder it to the motherboard. I recomend you take it to a shop unless your an expirenced computer tech. Or you could replace the motherboard, but if your gonna do that, you are better off buying a new computer. I hope this helps. Good luck.
Jan 18, 2009 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
60 people viewed this question
Alun Cox
