Question about Sony KV-35V35 TV
PIP won't turn off
Hi Folks! I have an old Sony Trinitron KV-35V35 with PIP that no longer has the original remote - we're now using an RCA universal. The problem is this: Somehow the PIP got turned on, and now the remote won't turn it off (the remote works fine otherwise - tv turns on and off, channels/volume work, etc.). Is there any way I can get the PIP to turn off without the benefit of the remote? Thanks!
  • 8 more comments
  • Anonymous May 02, 2008
    our t.v. is fine the pip/pop wont turn off even when we pres the button again for it to turn off
  • Anonymous Sep 16, 2008
    I have exactly the same problem and have no solution as of yet.
  • Anonymous Jan 15, 2009
    I have the same problem
  • tlcurry Feb 03, 2009
    My pip won't turn off and I no longer have the original remote...
    HELP
  • Jacrenval77 Feb 10, 2009
    I have two pip's showing and now I can't get the pip to turn off.
  • loriguth Mar 06, 2009
    pip wont turn off, how do i shut it off, i have a sony big scree
  • oceanawind Mar 21, 2009
    i have a sony trinitron kv 27 and pip wont turn off with remote is there another way
  • adarbashy Mar 22, 2009
    I have panasonic CT-2772SE. The same problem but has not been sloved yet!
  • Anonymous Apr 10, 2009
    it works great, Thanks very much.
  • Xcalbr8r May 11, 2010
    have the same issue but my 36" Trinitron has no "Set Up"or"TV Mode" Button on the front
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Posted on Mar 16, 2009
Thanks ! I have this problem and now solved.
Posted on Nov 14, 2008
We had the same problem for weeks and could not get the PIP off. After reading this solution, I tried it and the PIP went off immediately!! GREAT SOLUTION! Works perfectly! Thanks!
Posted on Nov 12, 2008
Push the buttons on the tv randomly, it worked for me without the original remote.TRY IT! tip the input and setup...
    New Friend:
Specifically on Sony TV model KP-53XBR35 VideoScope XBR, if after you press the PiP button, the screen becomes stuck on a dual screen with one side fuzzy, simply press the DEMO button located on the front of your device, behind a panel that you push in to open. I hope you found this helpful.
Regards,
M.Wright
Posted on Feb 07, 2016
Push the set up button on the front of the tv and the tv mode and it will turn off.
Posted on Jan 14, 2008
  • Jeni Ertmer
    Jeni Ertmer Jun 08, 2014
    I did try this and it went off for about 10 seconds (if that) and then came right back on. Tried turning off the tv and then, holding the volume button down to cut down volume while powering up the set and that did absolutely nothing at all.
It really does it for me works great
Posted on Nov 19, 2011
GREAT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Worked perfect
Posted on Oct 24, 2008
SOURCE:
What is the code for my Sony Trinitron Wega 32" TV using a RCA RCR311 B universal remote?
Try this
http://www.retrevo.com/support/RCA-RCR311-Universal-Remotes-manual/id/402ci569/t/2/
Aug 29, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCU410MS code for Sony Trinitron KV-27EXR15
get a SONY universal remote number RM-U302 it needs no codes just press the SONY item say in your case TV and the remote will self calibrate to your type
Jul 11, 2013 | Televison & Video
I have the 2000 Sony Trinitron model KV 27FS16 tv the picture in picture popped up on the screen cant get rid of it. I don't have the original remote anymore. Please Advise
Hello
To turn the PIP feature ON and OFF press the button marked PIP on the remote contro. Each press will get it vanished and reappear. OK.
May 08, 2011 | Sony KV-27FS16 27" TV
I have a Trinitron KV27FS16 with a stuck PIP. I do not have original remote. I do not have manuals. Only have access to on screen menu
Hello
To access all parameters of your Sony TV, you must have its original remote control. If you haven't one, get it from Sony authorised service center. The number of remote control for KV-32FS120 is [ RM-Y195].
OK.
Jan 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
No listing of 3 digit codes for Sony Trinitron, RCA universal rem
  1. Turn TV on.
  2. Press and hold TV button and Power button until light stays on.
  3. Release both buttons.
  4. Aim remote at TV and press the power button every 5 seconds until TV turns off.
  5. Press stop button at bottom of remote.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Words on screen
OMG! Hope you found the solutions by now? ! Wouldn't be the SAP control would it? Have you tried to reformat the TV with original set-up format? Best of luck, arb711.
Aug 11, 2008 | Sony KV-35V35 TV
Tv remote codes
I have a Zenith universal remote that i want to program to a sony 27 inch Trinitron, what are the codes?
Nov 03, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
Apr 13, 2007 | Sony KV-27XBR45 27" TV
Televison & Video Logo
3,526 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
