Question about Philips GOGEAR SA6045 MP3 Player
Phillips 4gb Go gear playlists
How do you make a playlist on the Phillips Gogear 4Gb mp3 player without doing it on the player it self? Can you make it on the computer first? I have the same problem, I don't know how to set it on the computer, but the playlist button on the side is for adding whatever song you are currently on to the "playlist on the go" that is already in there... I don't know how to add any more playlists, and I can't take the songs off of that one to reset it either! It's very agrivating...
  • 2 more comments
  • Anonymous Dec 21, 2008
    Same here, haven't figured it out yet.
  • Anonymous Jan 06, 2009
    mlkl
  • hmcox Jan 08, 2009
    The media player thing doesn't work I tried it may times!! I just don't think you can add any more playlists to this mp3 player. Mine even says there are no playlists at all! Even though it asks if I want to add a song to the playlist on the go!
  • garybgary Feb 23, 2009
    As above, but when I synch the play list to the GoGear it is not visible on any menu within the player. I've checked in the folders,music,playlists and data sections of the MP3 ...no playlist visible. Interestingly though if any track on the new playlist is already on the GoGear it duplicates it in it's original location. ie it will appear twice when I select an album.
Ok heres what ya do.
connect to laptop/computer.
go to "computer"
find the player -- open it
internal storage -- open it
playlists -- open it
right click any of the playlists and click properties.
click the references tab.
go back to the folder called music in the device.
click and drag the songs into the window called references.
when finished click ok.
should work!
Posted on Sep 22, 2009
  • dwinterslals
    dwinterslals Feb 22, 2012
    This solution was easy , direct, and most of all it worked. a big TY to jasonjbrown.
  • 3 Answers
To create the playlist for the Philips GoGear:
1st Open Windows Media Player (v10 or v11).
Create a playlist and title it. Next, click the SYNC tab at the top of WMP.
Next, drag your newly created Playlist over to the "Sync List".
Once you see your playlist listed in the Sync List window, click the "Start Sync" button at the bottom of the Sync Window.
All done.
Posted on Dec 26, 2008
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To create a playlist using the Philips GoGear 4GB MP4 Player:
Open a “New Folder” on your desk top
Drag the tracks to your new folder
Once the track is inside your new folder, place the cursor over the track and right click your mouse and select “Rename”
Now depending in which order you would like this track to appear on your list, type a number.
For example
1 - Elvis - It’s Now or Never
2 - Lady Gaga - Pokerface
3 - John Lennon - Imagine
Once you have completed your playlist, close this folder, then right click and select “Rename” to give your folder a title.
Finally, connect the Philips GoGear 4GB MP4 Player to your PC
Select “My Computer”
Open the folder marked “Philips”
Now drag your new playlist folder to the “FM RECORD”
Disconnect your Philips GoGear 4GB MP4 Player from PC
The End
In order to find your new playlist using the Philips GoGear 4GB MP4 Player
Switch on
Scroll until display reads “Recordings”
Select “Recordings Library”
Select “FM Recordings”
And your new playlist should appear ready for you to enjoy.
I hope this helps.
Posted on Dec 30, 2009
You have to install Rhapsody off of the CD or from a download and use that to manage your music, and playlists on the GoGear. It would seem Phillips and RealNetworks have a thing with each other, and it's as if the GoGear was designed to work with Rhapsody from the get go. (Or vis versa)
One major quirk though: if you create a new Playlist on the GoGear directly by right clicking it in Rhapsody, it will forever be named 'New Playlist' on the GoGear itself regardless of the name you give it inside of Rhapsody. Renaming the Playlist on the GoGear inside Rhapsody doesn't actually rename it either. I would strongly advise not using this function at all. It can lead to minutes or even hours of frustration, because any subsequent new list you create will just be 'New Playlist' on the GoGear and it will overwrite the last one you created.
To prevent hassle, just create a new Playlist in the Rhapsody player under the Playlists tab, then transfer that over to the GoGear by right clicking on it. Simple. =)
Posted on Aug 12, 2009
You just need to be in the FOLDER view to FIND the playlists on the player. Drag the songs into a folder, however you create the folder. The point is that you'll need to use that back arrow key to the left of the player and get in the mode where your folders are ( videos, pictures, radio, etc). Click the FOLDER view and you'll see the folders you created, wherever you put them.
Posted on Mar 04, 2011
  • Terrimd Jan 22, 2013
    Who knew that the playlist isn't labeled 'playlist' its labeled folder with the title I gave it! Thanks for the great (and simple) solution!
Plug in your device to the computer. Choose the open device to view files option. on the left menu, double click on internal storage. Right click on the music file and choose create new playlist. This method will create a new playlist with ALL of the songs on your device. You then can go in and delete the songs you do not want on the playlist. Remember, you can press control and click on the songs you do not want - they should be highlighted after that. You can highlight a LOT of songs then hit the red X to delete them. Goes suprisingly quick depending on the amount of songs you have ont he device.
Posted on Jul 29, 2012
SOURCE:
My phillips gogear vibe says that there is no music anymore
Try resetting the MP3 player: locate the little reset hole (it is quite small) and give it a poke with something blunt like a unraveled paper clip.
Oct 21, 2012 | Philips 4gb gogear vibe mp3 playr
Phillips go gear vibe 4gb mp3 says drm license expired owned it for only one month
Philips gogear vibe 4gb says its full then it says to delete some content. I deleted every thing and it still says that.
Mar 07, 2010 | Philips GOGEAR SA6045 MP3 Player
How do i put pictures on phillips go gear vibe 4Gb mp3 player?
hi my philips gogear 4gb vibe wont download pictures off my computer. but when my daughter plugs up her new ipod, it downloads them. can you please tell me why this is and how i caqn get pictures on mine? thanks
Feb 04, 2010 | Philips GoGear SA178 MP3 Player
I can't seem to get my playlist folder to download
make a new folder on your mp3 player when you plug it in
Jul 31, 2009 | Philips GoGear SA178 MP3 Player
Creating a playlist in transcend T.Sonic 840 4gb mp3 player
connect the device to computer.....go to my computer, open the device, find folder with tracks/ files are, make a new folder (name it)dump all the files you want in the folder (this your playlist) turn off and on to update device
May 30, 2009 | Audio Players & Recorders
I don't know how to reset my playlist
go to your playlists and over playlist on the go press the menu button and it says clear playlist on the go then just push that and you'll be set
Nov 30, 2008 | Philips Sport Personal CD/MP3 Player
The Playlist feature only creates a "Playlist on the Go" from the player itself - you cannot transfer playlists to the player from your computer. A real let down, I know.
-Tha Mp3 Doctor
Oct 21, 2008 | Philips Sport Personal CD/MP3 Player
Menu
These directions only apply to the Philips SA6045/37:
It's not going to be easy, because you will have to do two undesirable things: 1) Set your player up for auto-sync, which will result in the player adding unwanted media files to your player without your consent - and possibly overloading your player; and 2) You will have to roll back to Windows Media Player 10.
If you ask me, it's not worth it, but here's the procedure:
  1. Playlists can only be synchronized to your player via “auto sync”. Autosync will automatically synchronize your Windows Media Player library content and your player content each time you connect your Player to the PC. If you use the “manual” sync option the tracks in the playlist will transfer to your player but the playlist itself will not.
  2. Hook up the Player to the computer, allow a few minutes for the Windows Media player to recognize and detect the connection of the Player.
  3. Click on the Sync tab.
  4. Click on “Sync settings” or “Set up sync”
  5. In the pop-up window, select the playlists that you want to sync
  6. Click “OK”, the sync will start automatically
Note: playlists never show up in the device panel under the sync tab of Windows media Player even if they are on your device. Check on your device whether you can see the playlist.
-Tha Mp3 Doctor
Sep 12, 2008 | Philips GoGear Flash MP3 Player
How to save playlist into go gear
This GoGear REQUIRES that you use Windows Media Player 10 - you must uninstall your Windows Media Player 11 and rollback to version 10.
Once you have done that, the instructions with pictures are in the manual which can be found at: http://www.p4c.philips.com/files/h/hdd6330_17/hdd6330_17_dfu_aen.pdf
-Tha Mp3 Doctor
Sep 10, 2008 | Philips GoGear HDD6330 MP3 Player
Im trying to change the playlist of my Philips Go Gear 4gb
You will have to delete the playlist, change the items you want to change in Windows Media Player, and then re-load the playlist onto the GoGear.
Mar 14, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
18,867 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
