Question about Maytag Atlantis MDG6400AW Gas Dryer
DRYER TIMER NOT MOVING
Dryer timer is not moving on all settings exept 0 to 30 minutes. That works fine. I replaced the timer and still the same result. H E L P !!!! Rob
You need to replace a t-stat. the one with 4 terminals on it. i believe its the adjustable t-stat
Posted on Feb 04, 2007
Timer on Maytag dryer will not move.
Sounds like timer motor is bad. Most likely will have to replace timer.
Nov 06, 2017 | Dryers
White knight tumble dryer timer sticking at 80minutes and not moving to cool clothes
Have had the same problem with the timer sticking on the model and the same time interval, now don't trust it's safe to use at any setting over 60minutes
Jan 06, 2013 | Abbaka White Knight 44AW Electric Dryer
My dryer doesn't dry
The timer is responsible for initiating the actions of the entire drying cycle. if it is not moving, this will confirm timer failure. replacing this failed timer control module will fix this issue.
To clarify, its the timer that is malfunctioning. the heating assembly is fine.
Jun 17, 2009 | Maytag Dryers
Dryer works but timer won't move; therefore I have to set my own timer and remember to check the clothes.
There is really no fix to the timer. You will have to replace it. I suggest using www.repairclinic.com . You can buy this item at a cheaper rate than a service call. Always remember to disconnect power prior to changing out parts. Good luck.
Apr 18, 2009 | Kenmore 62602 Electric Dryer
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Re: no heat and timer not moving
  If the timer is set for a auto dry cycle,  the timer won't advance if not heating.  You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Oct 22, 2007 | Roper RES7646KQ Electric Dryer
No heat, timer not advancing
If the timer advances in timed cycle but not automatic, you have a bad heater thermostat.
Apr 10, 2007 | Kenmore 62622 Electric Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
300 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
