Question about NEC Computers & Internet
My Dad bought a NEC 1700v Monitor about 5 years ago. Its a good monitor and the picture/color is still good but it blacks out after it shows desktop for about 10 seconds. To get it to come back on, can either turn it off and on again or re-apply video settings but it continues to turn off again after another 10 seconds. I've tried it with other computers/laptops and different monitor cords and don't believe that is the problem. I read some reviews on this particular model and this seems to be a common problem. Bad wiring/circuit I'm guessing is the problem (read maybe even badly placed capacitors?). Is there anyway to replace a few of the components that might make it a quick/cheap fix?
  • ZHam Nov 30, 2008
    I also read that the inverter boards in this model usually are the source of the problem. Would it be worth it replace it? If so, where would be the best place and how can I go about finding the correct part? Thanks for any input.
    Novelist:
    Champion:
  • 233 Answers
This is a CRT monitor right? Do not open the case! There is high voltage stored in a capacitor somewhere in there and you could get zapped. You can buy good used monitors at Goodwill or a computer re-cycler for $20.00. If yours lasted five years you got your moneys worth. Did this monitor work correctly on other computers? If it did maybe you have a problem with your graphics card or something in the computer itself. Try a different monitor on your computer. If everything is OK with a different monitor then you know that your computer is good and that is not the problem.
Posted on Dec 29, 2008
Px42XR3A, NEC monitor lost picture of any type after showing a series of color bands from all sources. No other set in the house is affected and the sound through the receiver is just fine.
The picture board on your monitor is bad, since the power or button is on and sound and other things are fine, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | NEC-Mitsubishi Nec Display Solutions...
Recieved "No Signal Imput" after relocating computer and monitor
You need to check VGA cable connections at both ends, check video card to make sure it is seated properly in to the PC slot, etc. Try this monitor with other PC as well.
http://s807.photobucket.com/home/budm/allalbums
Apr 22, 2010 | NEC 17" 1700V TFT LCD Monitor 1280X1024...
I want to use a NEC Multisync 1700V monitor as an external display for my Thinkpad T400. However I get no image when I hook up the laptop and change the display scheme to display on my laptop screen +...
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
Mar 25, 2010 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
NEC multiSync 1700V as external monitor for Notebook Toshiba U205, Operating System Window Vista Home Premium. It displays only part (80%) of the picture compared with notebook's monitor.
Hi, if the 17 inch lcd screen is not a widescreen then the problem with the screen is possibly nothing more than the aspect ratio or resolution, which ever way you wanna look at it. All laptops have a widescreen type of ratio, so you will have to be either willing to change the resolution when you switch screens or setup different profiles, which you should beable to do through control panel, appearance and then personalization, you will then have access to it.
Nov 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
I hooked my new computer up to my NEC Multisync 1700V moniter. When I power the moniter up the GREEN light comes on until I get a "no Signal Message" and then the amber lihgt comes on.
hi, hook up your old one and change the refresh rate to 60 or 70 hertz, go 2 display properties, then the settings tab, then advanced,then monitor. and set it as i said. turn off computer after you change settings. hook up the nec, you then should be good 2 go. good luck! and please rate this solution. if you need further help, reply.
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Bought a new computer. Getting no signal from my multisync 1700V
check the device manager and see what it says for the monitor...I know you can press CNTRL+ F5 for monitor selection , try this if everything is good in device mngr
NEC plasmasync 42pd3
A Plasma Screen never need 're gassing'.
If you have verified the connections and leads are correct the the up converter is possibly faulty and in need of servicing.
Take it to an authorised NEC repair shop.
Jun 10, 2017 | NEC PlasmaSync 42PD3 42" Monitor
One of the primary color is absent
Hey Kuld.. Just asking... since both, your TV and your monitor have the same color issue...??.... have you been to the optometrist lately... (My Dad had this color issue with his eyes!).. he was red color blind..
Good luck,
Jun 20, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Computers & Internet Logo
80 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
