My ps3 switches on but no image is displayed - Computers & Internet
  • 60 Answers
Hi any lights  what cable are you using hd
hold power button
Posted on Dec 05, 2008
My playstation 3 will not play in 1080p. It used to work, but when we switched cables, it wont work in HD.
When you switched cables, you mean you changed the cord running from the PS3 to the TV? HD content requires an HDMI connection from the PS3 to the TV. It is possible that when you changed cables, you replaced the PS3's HDMI cable with Component Cables which can only deliver in Standard Definition and not in High Definition (720p, 1080i and 1080p).
Apr 29, 2011 | Sony Playstation 3 (PS3) Console
My first generation ps3 (20g) will not display image on tv while trying it with hdmi and av cables. I;ve tried holding down the power button for the 10 sec and all that, but It wont display image, although...
Have you tried it on a different TV, you need to narrow down weather it is the PS3 or the TV. If it doesn't work on another TV the PS3 GFX card will be faulty.
If you normally use HDMI try and use a different cable or try it on a friends (borrow one) just to prove yours is good.
Let meknowhow you get on. Not sure you can replace the RSX GFX in the gen 1.
Good Luck
Oct 17, 2010 | Sony Playstation 3 (PS3) Console
The image on the tv is constantly turning off, the lights on the ps3 are green and blue. The ps3 is connected with an hdmi clable. how can fix the image problem?
This is sometimes caused by what is known as the "High Definition Handshake". When your PS3 is connected via PS3 it tried to detect the optimal settings for your TV. If it cannot perform the handshake you get the symptoms that you are describing.
When the screen is going on and off, unplug the HDMI cable and plug it back in to perform the handshake again. If this does not work try resetting the display settings by turning the PS3 off into standby mode (red light on). Press and hold the power button. It will beep once when you first press it and then again 5 seconds later. Release the power button when you hear the second beep.
This will reinitialize the display and hopefully sort your problem.
Hope this helps and thank you for using FixYa
Sep 12, 2010 | Sony Playstation 3 (PS3) Console
I got an receiver that does hdmi switching and it was working fine, i have not used it for a while. i turned it on and i get no image just sound
If your getting sound and no video i would think somehow the ps3 is not on hdmi video settings try this power down the PS3 and when powering it back up hold down the power button til it beeps this resets the video to default and then you can adjust it or go into display settings and check how it is set up.
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
My screen stays blank when I turn on. Lights blue and green come on but screen stays blue
If your display settings aren't set to automatic this can occur. Example: if you have set resolution to 1080i and are trying to play it on a display that has 1080p you will get a blank screen or no signal message. you will have to connect your PS3 to the last display you had an image on and change the "display setting" to "automatic" for your PS3 to work on all displays. when you choose a specific resolution to the "display settings" it will only work on that specific resolution. hope this helps.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
No image/sound when sony ps3 is connected to onkyo 875
I've had problems with my Onkyo receiver too.
Firstly i suggest going into the Onkyo setup menu. Make sure that in "source settings" i think that's the menu option) that the input e.g. dvd is set to receive HDMI. then go into the settings for DVD and ensure that resolution is set to auto, then go into the monitor out settings (option 1 on main seyup menu) and make sure that main monitor out is set to HDMI and auto resolution.
hope this helps,
Aug 13, 2009 | Onkyo TX-SR875 Receiver
Ps3 starts and the green light is on but no image omes up on my
Try connecting the PS3 to your TV with a scart cable first and go to the appropriate channel. The problem you are facing is probably because the default output is not HD. So you must change it to HD you can do this by going on your PS3 display settings, whilst your operating on standard definition, AV1 or something like that. When the you are on display settings plug the HD cable in the PS3 while still being on AV1 and then plug the cable in, this may prompt a message saying that a HDMI device has been detected and you can change to HD, if this message appears switch to the HDMI output and then select yes and automatic on the PS3 for optimal settings in HD. If the message does not appear then select the HD output yourself after plugging the HDMI cable in and then change to the channel and do the same.
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
Jun 24, 2008 | Onkyo HT-SR800 System
Shadowing on screen
You should get a good surge protector. Sometimes some areas have a spike in the power. That will cause interference in the TV signal coming from your PS 3. Try out different surge protectors that should solve your problem.
Jan 23, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
