Question about Sony Ericsson K800i Cellular Phone
My phone won't turn on...
My battery was low and when I got home from work (about 1hr later) I found that the number pad keeps lighting up white, vibrating and the screen was also white then it pauses and does the same. So I took out the battery and replaced it, then when I turned it on, the keypad just lights up white and the phone vibrates, but it doesn't turn on instead after a pause the keypad lights up and the phone vibrates again, it keeps doing this. When I try to recharge the battery it does the same. I tried to do an update through Sony Ericsson's website, but it failed saying there's an error. Now when I try to recharge the battery the phone doesn't even light up nor vibrate. Is it a problem with the battery or my phone? Please help!
    Brigadier General:
  • 7,752 Answers
You need to take the phone to a mobile service center and have them fix it for you....it needs a new battery and have the mainboard diagnosed
Posted on Nov 30, 2008
    Scholar:
  • 162 Answers
Your phone's software is courrupted you can call Firmware insted of software. it's not a hardware issue.
1999 Windstar drives fine for awhile then something starts to happen the abs light comes on the trak light comes on the lights won't go hi and low no backup lights the turn signal won't turn o
Just as a precaution, please check the brake fluid reservoir on that model. There is a sensor at the base of the master cylinder which can leak brake fluid over the wiring circuit, and cause the electrics to short out. In some extreme cases this has caused fires in some vehicles. This is why Ford had issued a recall to this particular model in the states at least.
Nov 13, 2012 | 1999 Ford Windstar
My htc sensation won't turn on it has a white screen
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 26, 2012 | HTC Sensation 4G
Phone will not turn on with white light
5.Wait 10 seconds.
Step
Thanks
Aug 01, 2012 | Motorola Mobility RAZR V3
Hi, i have a blackberry bold 9000, i went out of town for a day and forgot my charger at home and my phone was running low on battery, later that day it died. When i got home to charge it i would show the...
Dead battery. Try that first.
If that's not the case. the battery contact terminal might be bad. Which is common.
Chances are, it's just a fried battery that needs to be replaced
Sep 10, 2011 | RIM BlackBerry Bold 9000 Smartphone
I left my iphone 4 all working but battery was low. i heard a text message comes in and i saw it on the home screen but didnt open it. a few minutes later wen i decided to check it it was turned off and i...
Hold the power button/lock button and the home button at the same time for about 10 seconds and then let go of the home button only it shuld turn on if not keep trying it and when it does turn on click the home button twise a bar will pop up at the bottom with all the apps u have running hold one of them until the start to shake go through and click the minus on them u probly have alot running which is why your phone shut off keep 10 max in the bar. I hope this will fix your problem please rate and let me know. Thanks
Apr 13, 2011 | Apple iPhone Smartphone
My phone won't start on!
Nokia sometimes has a glitch where if the battery is too low it will not start properly again. Let it charge for some time when turned off - a couple hours, so it has enough battery power then remove the battery for 5-10 minutes, put the battery back in and try start it. What this does is re-sets the phone so it can start again. Also if there are problems during use that solution usually fixes it as well. What is happening is due to a low battery it tries to resume where it left off and cannot load itself properly to do so. Letting it go completely dead with no battery for a few minutes lets it drop it's old info and reload it's info to work again.
Oct 19, 2009 | Nokia N75
My 2002 won,t start. Can hear a click sound.
check the battery under load at a local parts store. Sounds like a dead cell. Also check the cable connections to the battery for corrosion. The starter could be bad but That would be a last check unless it has been dragging. If the battery and connections are ok the starter solenoid would be the culprit. Sometimes you can free them with a light tap with a wrench or LIGHT tacking hammer. It will still need to be replaced, though. Hope this helps.
Dec 25, 2008 | 2002 Land Rover Freelander
Home page
I was talking on phone in the car. Made a quick call. Everything work fine. Than the screen went blank white. I can't see the screen of any application. I take the battery out to see if it would reset the phone and turn it back on. It went straight back to the blank white screen. I try another solution. I use my home phone. Call my phone. It signal as it was off mode. Straight to answering machine. Red light flashes....I then, hold #1 to get voicemail. It did work. So my service is good. So my problem is how can I solve the blank screen issue? Has it happen to anyone before. Battery strong and it's not low on battery level. Thanks for any suggestions.
Dec 10, 2008 | Verizon Communications BlackBerry Pearl...
My camera went dead, with new batteries...
The MPVR uses a rechargeable Li-Ion battery. It sounds lilke you've got a different model. It's hard to make any suggestions without knowing which camera you've got.
Nov 15, 2007 | Aiptek MPVR Digital Camera
Won't take charge and key pad flashes
Hi There, My friend you may have gotten a faulty phone, and i'm quite positive that u did...The phone may have suffered some water damaged and it was not listed by the seller. Maybe u could send the seller back a nice message. Hope this helps. Sam !
Jun 21, 2007 | Motorola Mobility RAZR V3
Sony Ericsson K800i Cellular Phone Logo
98 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
