Question about Dell 3100cn Laser Printer
Bleeding color When I print anything such as a card, etc... the printer leaves a dragged or bleeding mark in the middle of the printed line. For example, if I print a square box, the bottom line will have a smudged part in the middle of the box. Please tell me what is wrong and what I can do. Thanks
I have a similar problem. I just spoke with Dell support and they said that the problem is the printer drum. Fortunately, my printer is under warranty so they are sending me another.
Posted on Jan 30, 2007
SOURCE:
My epson stylus NX110 is printing blank pages
Printer heads clogged or cartridges are empty or defective.
Feb 10, 2014 | Epson stylus nx110 All-In-One InkJet...
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
When printing from the HP color laserjet 4600DN, its leaving tracking lines in the middle of the page. Any suggestions on how to fix this?
Hello, track lines could be caused by a number of components within the printer.
Is it any specific color? Yes - Change the toner of the color causing the lines.
open the front main door, Inspect the ETB for damage. Inspect the fuser for damage. If any component shows damage it will need to be replaced.
Feb 04, 2011 | HP LaserJet 4600dn Color Printer
Black marks on the printing
You could have a build up of ink on your rollers, and as the paper is pushed through it is leaving marks. It could also be causing your ghosting effect or double lines. By having your printer cleaned by a certified technician it should reslove your issue.
Jun 09, 2010 | Epson Stylus Photo 1290 InkJet Printer
HP 4700n leaves marks on prints
Either the fuser or the copy drum assembly is worn,first replace the drum, if it doesn't clear the problem, it's the fuser.
Aug 20, 2009 | HP 4700N Color Q7492AABA Laser Printer
Lexmark Z53 Prints Lines
please clean wast toner tank it have under photocoductor
Mar 31, 2009 | Lexmark Z53 Color InkJet Printer
#5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Owners manual for kodak 5300 printer
Halbert, you were disconnected from our chat session.
A manual for your printer can be found here at Kodak.com.
Apr 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Bad printing
just for info my printer wasn't printing much of anything black and color. If you hold down the middle button till the light on the top blinks twice it will give you a color test page. it should give you a grid to the right and to the left it should have the letter H and two blocks. If it doesn't you hit the middle button until the light blinks once and that is the cleaning. I have had to do almost 25 cleanings just today to finally get some results. Hope this helps you.
Dec 04, 2007 | Canon PIXMA iP2000 InkJet Printer
Printing problems
Sounds like the heat is set too high.
Aug 18, 2007 | Zebra P210i Thermal Printer
Dell 3100cn Laser Printer Logo
117 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
