Question about Dell AS500 Sound Bar Computer Speakers
My AS 500 Sound Bar speakers are crakeling (PArt # 4y463)
Once turned on, the speakers have a static/crakeling noise. The speaker bar is attached to a Dell flat monitor.
Is it time for new spaekers or do I have a set-up issue?
Thanks for your help
Rob R.
  • 1 more comment
  • lrigneys Dec 27, 2008
    Mr. Emrys:
    Thanks for the help. It turned out to be the Sound Card. I will keep your info handy though.
  • prettybabyba Mar 05, 2009
    The Dell speakers on the computer are making a static sound, and the volume is really low. Everything is plugged up correctly it was working yesterday, but I changed hard drives and now this has happened.
  • Anonymous Apr 04, 2009
    I have the same problem. It is not a connection issue, it is a problem with the audio switching in the monitor itself. Turn the power to the monitor on and off and see if the audio gets better.
  • 51 Answers
Usually, the crackling indicates a connection that's not making a good connection. you can try twisting the plug where it connects to your computer and see if you can get it to make a better connect. Also, you may try cleaning the plug itself. When cleaning contacts with any sort of household alcohol, be aware that it can leave a residue so you'll need to use a clean/dry tissue to dry the plug and remove any residue. -hope that helps.
Posted on Dec 27, 2008
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
Dec 29, 2015 | Samsung Televison & Video
How do i turn off internal speakers to hook up a sound bar?
There may be an internal speaker disable option in the initial set up routine.
Aug 13, 2014 | RCA L32HD31 32 in. LCD HDTV
Level 9 Sound Designs MH-500 Computer Speakers buzzing
I think after reading your question that your speakers cable may be short or join another line. As a result, it become earthing & create noise. So you can test it by a Multimeter. The multimeter indicator point place on X10 or X100. Then you can understand where the problem in your speakers line. thanks
Nov 04, 2012 | Level 9 Sound Designs MH-500 Computer...
My speaker system was humming loudy and now only makes a loud static noise.
you might have to uninstall then restart your computer then reinstall both the drivers and the sound devices
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
or
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 02, 2011 | Altec Lansing AVS 500 Computer Speakers
How do i use my sound bar without an actual computer tower?
the sound bar AS500 gets it's power from the LCD it is attached to, if you are using a portable, connected to an LCD then you can still use it.
If it is an AS500PA then it has it's on AC power adapter, then you can connect it to any computer.
Oct 09, 2010 | Dell AS500 Sound Bar Computer Speakers
Chiming Noise
GET THE SPEAKERS PIN REPLACED AND ENJOY
GIVE ME ALL THUMBS
GIVE ME VOTE
Jan 28, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Static coming from my DELL AS500 speakers
It's the jack on the back of the PC or sound card. Sounds like some solder is loose on the jack.
The cheapest solution would likely be to just replace the sound card, if your comfortable installing them. It's really quick and pretty hard to mess up.
If it's "onboard" sound, meaning the audio jacks are built right into the mother board, you'd likely need to just replace it with a pci based sound card.
Dec 06, 2008 | Dell AS500 Sound Bar Computer Speakers
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Dell AS500 Sound Bar Computer Speakers Logo
741 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
