Question about Microwave Ovens
Galanz microwave wd900esl30r
Its a pity youare so far away I live in Malta and the microwave keep blowing my house fuse. Can you help please.
Thank you.
  • William Miller
    William Miller May 11, 2010
    If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
    If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
    If
    it goes dead or blows the breaker (or GFI) when you plug it in or open or close
    the door, then there's a problem with a door switch or door switch
    mount.
    Do either of these scenarios sound like yours?
MicrowaveSvc
  • 9098 Answers
SOURCE: Fuses keep blowing out
In case it's still helpful, I'll inject a little sanity into the replies.
If the fuse blows as soon as you hit Start, it's probably a shorted high-voltage capacitor. That's usually economical to repair.
If the fuse blows a few seconds after you hit Start, it's probably a shorting high-voltage transformer. That's usually not economical to repair.
It's not radiation (non-ionizing RF by the way) that's the hazard, it's the voltages.
Posted on Nov 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: I have been "searching" for
See http://www.galanz.com/About.aspx?ColId=110&SecId=114
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Galanz Microwave Oven - Unable to disable child lock
Galanz's website seems to be useless. I tried finding information but kept being told "no data available." So while I can't tell you where to find the manual, here's something to try. Most microwaves get put into lock by pressing and holding one of the buttons for longer than normal, or by pressing one of the buttons several times in a row. Some ovens use the TIMER button. It won't be one of the number keys, but one of the function buttons. So start with a button, press and hold it for at least 5 seconds before you let go. If nothing happens then try another button. If that doesn't solve the problem, then try pressing each function key several times before moving on to the next one. If that still doesn't get it going, maybe a store in your area that sells Galanz will take a look at the book for you. The process should be the same for any similar model.
Posted on Nov 11, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Where to purchase a new fuse for Galanz Microwave
20A ceramic fuses can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Feb 15, 2009
  • 11 Answers
SOURCE: microwave blowing fuses
Sanyo isn't that great of a manufacturer.. I had a microwave from them a few years back that did the same thing.. The wiring inside the microwave is shot.. if you were to open it up, you'd probably see some burnt wires from a short. If you use the microwave over a range, it may be because of grease build-up...
anyhow, its better that you invest in a new microwave, rather than fix it. It will be much more cost efficient
Posted on Jun 02, 2009
Microwave suddenly went dead - completely black. All 'house' fuses are okay. Could it be a fuse in the microwave itself?
Yes! that is exactly the problem, the fuse is a ceramic type "white body with silver ends" located near the high voltage capacitor, unplug and allow 30 seconds for the capacitor to dis-charge before removing the fuse. Keep in mind the reason for the fuse to blow is often caused a defective door switch, or you just might get away with changing the fuse.
Mar 15, 2011 | GE Profile Spacemaker Over-the-Range...
My microwave XL1800 keeps blowing fuses
Now this is not quite clear enough to give an accurate single answer.
Is it the fuse within the microwave or the general house supply fuse that blows?
If its the latter then an electrician needs to create a separate fuse line to reduce the overall load on the fuse, 15amps generally. Many houses have too many plugs being used at once on the same circuit TV, dishwasher, fridge/freezer, electric jug etc all drawing power. Big screen Tv's are the worst offenders.
If it is the fuse within the Mwave, then it needs attention,as a short has developed in the unit and needs to be corrected.
I will assume it is less likely to be this and punt for the first solution ( House fuse box overload)
Please rate my help++++Thanks for using FIXYA
Feb 13, 2010 | GE XL1800 1100 Watts Microwave Oven
Microwave blowing house fuse, but not right away. Sometimes not, sometimes within 15 seconds, sometimes longer. Any idea what the problem and how to fix? Thanks
PLEASE DO NOT USE OR TOUCH when plugged in. Remove Fuse & UNPLUG IT. The ONLY reason a Fuse "Blows" is due to an Active, to Earth fault. This "Could" place the "Mains" voltage on the "Case" of the Unit, if touched while plugged in it could KILL YOU. Please call a registered professional, to attend to this. It may be in the Unit?, it may be in the wiring?
Feb 10, 2010 | Microwave Ovens
Where can I locate the fuse in my Galanz microwave oven model #P60D17L-D5. It suddenly stopped working and I think this may be the problem. Thanks for the help, Joy
I would expect to find it on the floor of the machine (inside of course) near where the cord enters the cabinet
thanks for your interest in FixYa.com
please vote
positive comments appreciated
thank
a
Dec 07, 2009 | Microwave Ovens
As i turn on microwave it blows the fuse. what could be the reason.
try using it at a different location in the house(different circuit) if it also blows that fuse, there must be a short in the unit. do not use. if it works means line in the kitchen is overload, and you need a higher fuse rating or breaker.
Sep 10, 2009 | Microwave Ovens
I got a Galanz microwave Moldel # P60D17L-D5 and cannot find a ceramic fuse anywhere it's 3/4 inch long and 1/8 inch diameter. I've tried emailing the company but no reply's.Anybody got any idea's
The microwave oven use a slow-blow fuse. If you look on the around the end of the fuse, you will be able to tell what size it is. Example (250v 3Amp) Your fuse may be found at Hardware stores in the electrical isle or a Radio Shack. If you found my suggestions to be helpful, please rate my solution. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
Feb 13, 2009 | Welbilt MR755T Microwave Oven
Changing a fuse in a Galanz 700W Microwave Oven
A microwave casing can be removed and almost full access to the electronics with about 6 screws.... make sure to unplug it from the wall first.
please vote on your answers to keep the site free.
Sep 04, 2017 | Microwave Ovens
Microwave fuse mystery
AHD_NZ
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Guest
May 28, 2008 | Microwave Ovens
Microwave Ovens Logo
275 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
