Question about Pioneer CDJ-200 CD Player
CDJ 200 without electricity fuse blow off?
I brough my CDJ 200 Pioneer to turkey (I bought them in USA) and I forgot to have a converter so I Can use them, so I plug the power cord straight into the wall, and of course theres no power, I was reading that ''hopefully'' It can be the fuse, but is there any option to change that fuse to a high voltage so they can work in 220 V not 110 V?
thanks a lot
  • Anonymous Jan 17, 2009
    I made the same mistake, yesterday night. Can you tel me if after chaged the fuse, your CDJ200 works again ?
  • 905 Answers
No you cannot do that , the device works on 120v( 117v around me) , but it cannot be changed like that , you would need a trans former that breaks down the voltage to 120v
changing the fuse will not change the circuitry in the device
Posted on Dec 01, 2008
Hi! I had removed the ffc cable then after i inserted them back, now this pioneer cdj 200 wont turn on.
CHECK THE YELLOW COMPONENTS, SOME aRE FUSES, THEY BLOW IF YOU DO ANY LITTLE MISTAKE
May 20, 2016 | Pioneer Audio Players & Recorders
Power problem, CDJ wont turn on propperly as it is from the US and i live in Birmingham UK
The step down adapter should work fine as long it supplies the voltage and any other ratings shown on the turntable power supply indication pannel. However the problem might already have happened. If the fuses were before the power entered the mains transformer of the unit, then if they were set to blow above the USA voltage then things could be OK. However if the the fuses were in the secondary output from the transformer then the mains will have caused possible damage to the transformer. Maybe even elsewhere.
Jan 15, 2013 | Pioneer CDJ-800 Turntable
Hello i need some help,i have pioneer 800 mk2 cdj i buy from usa but im live in london so difirent pawer supply here i bought the converter but try connect and its not showing nothing maybe the problem...
You can have a fuse problem only in you plug it diectly to 240V, the UK voltage. Check that the converter is a step down transformer, 240 to 110 volts. The system should work with 110Volts. If everything is ok, then you blew the system´s powersupply with the 240Volts. that is difficult to solve.
Dec 08, 2010 | Pioneer CDJ-800MK2 Turntable
Cdj 200s bought from america not working. they have american plugs on at 120v. i have tried an america to uk travel plug and 240v to 120v stepdown transformer but this has not resolved issue....... would...
Yes, fuse may be blown, first check out the fuse of CDJ,
if it does not work. Install a physical 120v American transformer
also change the switch of 240v to 120v from back of CDJ
thx,
djajay
Feb 07, 2010 | Pioneer CDJ-200 CD Player
Pioneer CDJ-200 CD player will not read discs?
You need to be a bit more specific. It might be a formatting issue, in which case, you need to convert your music that's on your cds. The songs must be in "CBR or Constant Bit Rate" format. Most songs come in Variable Bit Rate format, which the 200's aren't able to play. Get a music converting application, I've used dbPoweramp's converter for quite some time, had to buy an MP3 license, but it was worth it. Unlimited conversions = more fun with the tables :) good luck!
Dec 24, 2009 | Pioneer CDJ-200 CD Player
I bought pioneer cdj's 200 in the USA. Unfortunately it was used in SA without a correct adapter. I think it blew my cdj's because the 210 adapter was not used. Is there anyway i can fix them?
u could have bloo the trancformer,but check the fuse inside the unit first, & the plug coz u never know unless u test it.
if it still doesnt work then the trancformers probobly gone.
http://www.donberg.ie/warehs/groupbe.htm
Aug 04, 2009 | Pioneer CDJ-800 Turntable
I bought two cdj 800 from the usa and they wont power up
nothing to do with hz.adjust country voltage&turn ON
Jul 05, 2009 | Pioneer CDJ-800 Turntable
Blown fuse cdj200
It is hopefully just the fuse. To get at the fust you have to remove the casing (there are screws on the under side). Once removed you will find a little glass tube fuse located where the power comes into the unit. The fuse just pops out and you can get a replacement from any electronics shop.
Sep 22, 2008 | Pioneer CDJ-200 CD Player
Pioneer cdj 200
the fuse was blown inside!!
Aug 11, 2008 | Pioneer CDJ-200 CD Player
Pioneer CDJ-200 CD Player Logo
405 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
