Single sided sound from my RCA/Phono leads
Help!
I have a problem with (one sided) sound coming through my phono leads.
I replaced the suspect leads with a new set and was left with the same problem?
It has nothing to do with...the replacement leads or my soldering skills...the cartridge or its wiring...the channel on my mixer or my amplifier! (my whole set up is Technics!)
I have owned both turntables from new,so it's not like they've been abused (they've never left the house)
I have a feeling that it may be a faulty circuit board?
If I did decide to send it off for repair who can you suggest,bearing in mind
I'm from the UK...
Peace from the east, Hopkirk.
hi, i have a vintage panasonic rd 3500 turntable that i cant get any sound from one side? what is the best place to start checking? i channged out my receiver first to make sure it wasnt the problem. so i know it is either in the turntable or leads.any good ideas? where to start? what to check? sounds good on the one channel.thanks in advance
  • dlundin67 Dec 05, 2008
    i have the same prob with these damn things its not my mixer,cables,cartridge, needles its the ttable, i had 2 of these do it in 1 week, and i took em back, then a month after another one, i put it away and havnt used it, now ithe last one of that set sound went low and i want to throw them at tech suports window, ive tried to find a solution from stanton and cant get one. thanks alot
    dlx
    ps if someone knows the secret please contact me dlundin67@yahoo.com
  • Anonymous Feb 20, 2009
    I have a turn table Numark 1910 that plays only the Right side. I have tried replacing the output cables and also different amp. what could be the cause?
    my e-mail: iverybrooks@gmail.com
  • 42 Answers
Your query not complete. Please resubmit.
Posted on Jan 25, 2009
2 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Single sided sound from my RCA/Phono leads
If you are certain the new leads/RCA cables and the soldering work was done properly, and you've determined that the issue is from the turntable and not your mixer.
Then there are 2 other factors that could be causing this issue:
1) Bad Tonearm - look inside the tonearm, where the cartridge/headshell mounts. You'll see 4 prongs. Make sure those prongs are protruding and they all look even. They must also be a nice shiny brass color. If they are dull and/or black, try cleaning them out with an contact cleaner (CAIG Lab DE-OXIT works good) made for electronic components. If any of the prongs appear to be pressed in, try to see if you can get it to bounce back. Those prongs are spring loaded, and sometimes the springs get misaligned. Of course, they also tend to dislodge. If that's the case, then you will need to replace the tonearm altogether.
2) Faulty Cartridge / Headshell - Make sure your cartridge & headshell work properly. The easiest way to do this, is to swap your cartridge with a working one. If you have 2 turntables, just swap them out, and see if that changes anything.
I am going to say, it's more than likely a tonearm issue. There really isn't anything else, other than the Tonearm and RCA's which would cause sound issues. The Circuit board will not affect your sound, unless you burned it, or damaged it in some other fashion when replacing the RCA cables.
As for a Service Center in the UK, not sure of any, but you can contact Panasonic, which is the parent company of Technics - www.panasonic.co.uk - go to the Support Section for a list of auth service centers in your area.
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Posted on Dec 01, 2007
Im trying to hook my denon stereo to my tv... can you help me??
What inputs does the TV have?
Otherwise experiment with these options:
DENON---------->>-------TV
Stereo jackplug phones out->>-RCA phono inputs.
RCA phono outputs->>-RCA phono inputs.
Stereo jackplug->>-AV.RF converter RCA phono inputs->>-ANT.in.
RCA phono outputs->>-AV.RF converter RCA phono inputs->>-ANT.in.
Nov 29, 2017 | Denon Audio Players & Recorders
Can I use a JX-S900 Y/C separated I/O to run two subwoofers out of same reciever??
Yes, on two conditions:
1) the JX-S900 needs to be a proper matrix switcher. It has to have the ability to route 1 input to more than one output.
2) the sub signals need to be low level RCA/phono, and not high level speaker wire connections. That's not just about the type of connector. It's about the signal going through those wires. A low level RCA/phono sub connection conducts a maximum 0.7 Volt. A speaker wire connection can transmit 30 Volts! If you put 30 Volts in to a line level switching device such as the JX0S900 you'll fry it.
Provided that the above two criteriia are both met, then yes it will work.
  • Connect the AV receiver's sub out to Source 1 - white RCA phono.
  • Connect the two subs mono LFE Left input (white RCA) or the single black RCA/phono inputs to the JVC's outputs 1 and 2 - white RCA/phono.
  • Set the source routing: input 1 goes to output 1 and 2
Sep 17, 2014 | Audio Players & Recorders
Looking for manual for pioneer sw200 powered subwoofer
Most subwoofer have a left and right phono/RCA sockets. The amp should have a sub out phono/RCA plug. The sub should have come with a phono/RCA lead that will connect these - one plug to two plugs.
Apart from the mains plug that's all there is really. You may have to switch the sub socket on the amp on.
Or you can get one of the cables from places like below:
http://www.custom-cable.co.uk/hifi-cables/subwoofer-cables/
Sep 13, 2014 | Pioneer Audio Players & Recorders
How can i connect my laptop to a db790 amplifier?
All you need is a 3.5mm Stereo Mini jack to two RCA jacks. Connect this to the line or speaker out of the laptop into anything but the phono input on your sony. The phono input will be over driven and sound bad and possibly damage something in the system. Try using any other unused device input on the receiver.
Feb 16, 2012 | Sony STR-DB790 Receiver
Hi, Can I plug my TV unit to the LG unit using phono leads for the sound. I have 'audio ou't from my tv, in the form on phono sockets, but I need to know if the LG unit will accept this for...
Hello
If your LG unit to which you wish to give the audio output of your TV has an input [Audio In] socket, you cah connect it with using phono leads. In most cases, the audio equipements will have audio IN sockets with them; some have an RCA socet, otheres have stereo type sockets which accept external audio signals. Look keelnly on the back side of your audio equipment and find out which type is there, and buy a phono chord to suit the need. If there is no audio IN on your audio equipement, there is no way to connect. OK.
May 19, 2011 | Televison & Video
I have a LG 47 inch flatscreen.i cant find any audio output plugs to hook it up to surround sound.how are you supposed to hook it up.
this is from the LG website about that TV.
- Rear,
2 x Composite video/audio input (RCA phono x 3) - Side,
2 x S-Video input (4 pin mini-DIN),
1 x USB (4 pin USB Type A),
1 x Audio line-out (RCA phono x 2),
2 x Component video input (RCA phono x 3),
2 x Audio line-in (RCA phono x 2),
1 x Digital audio output (optical) (TOSLINK),
1 x Digital audio output (coaxial) (RCA phono),
3 x HDMI input (19 pin HDMI Type A),
1 x RGB input (15 pin HD D-Sub (HD-15)),
1 x Audio line-in (Mini-phone stereo 3.5 mm),
1 x Serial (9 pin D-Sub),
1 x Remote control (Mini-phone 3.5 mm)
Mar 20, 2011 | LG 47LC7DF 47 in. LCD HDTV
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
Audio Leads
you need 2 rca phono to 2 rca phono link the set top box to hifi using aufio output on set top and aux on hifi
Dec 28, 2008 | Panasonic SC-AK640 Shelf System
No sound out of deck
If you've already replaced the RCA /Phono cables, then the only other item that would cause this kind of problem is your tonearm, and it will need to be replaced.
- OPTiC
DJ Turntable Repair Expert
A DJ Pro Audio Co.
Dec 05, 2008 | Technics SL-1200 Turntable
- TWEAK AV LAB
Nov 30, 2007 | Technics SL-1210 Turntable
299 people viewed this question
 Grubhead
Grubhead
