Question about Maytag Microwave Ovens
CUP HANDLES GET TO HOT WHEN I WARM COFFEE.
MY CUPS GET TO HOT TO HANDLE WHEN I WARM COFFE ON THE AUTO.SET FOR BEVERAGE.COULD YOU HELP.MY CUPS SAY MICRO SAFE. THANK YOU MARGO
It is your cup. The handle density or moisture content of the handle is causing the mwave to heat it. The rest of the cup contains a liquid (coffee?) that is absorbing any heat generated in the body of the cup. Use a different cup!
Posted on Nov 30, 2008
The manual tells me to test the product by heating a cup of water for 30 seconds
Bernard,
I usually will test a cup of water for 60 seconds and it should be hot enough that you would not want to leave you finger in the water more than a couple of seconds. It would not be hot enough for most people to use for coffee or some other hot beverage but it would be hot enough to burn your finger if you leave it in there for very long. If it is still lukewarm after running for 60 seconds you probably have a problem with some of the major components and depending on the age of your microwave it might be cheaper to replace the microwave with a new one. Hope this helps you!
Apr 12, 2015 | Microwave Ovens
My 12 cup coffee maker does not keep the coffee hot after it has been made - whats wrong with it......
The heating element is open on the warming plate, cheaper to replace the coffee maker for a new one.
Feb 27, 2011 | Microwave Ovens
I lost my instructions for my Pasta Boat and I don't know what power to use or how much water.
For elbow, bowtie, ziti, rotini, and penee
1 serving -1/2cup -water level at #1
2 servings -1 cup -water level at #1
3 servings - 1 1/2cups - water level 2
4 servings - 2 cups - water level at 4
6 servings - 3 cups - water level at 6
8 servings - 4 cups - water level at 8
cook times based on serving size ( serving size - minutes)
1 - 17
2 - 18
3 - 21
4 - 23
6 - 25
8 - 27
Stir macaroni once halfway through cooking for al dente; for softer pasta, cook several minutes longer.
and just because I couldn't find this online no matter how hard I tried:
For spaghetti, linguine, angel hair and fettuccini
1 serving - 1/2 the handle - water level 1
2 servings- 1 full handle - water level 2
3 servings- 1 1/2 handles - water level 3
4 servings- 2 full handles - water level 4
6 servings- 3 full handles - water level 6
8 servings- 4 full handles - water level 8
cook time servings/minutes
spaghetti - 1/13-14, 2/15-16, 3/16-18, 4/18-20, 6/20-22, 8/22
thin pasta-1/12-13, 2/13-14, 3/15-16, 4/17-18, 6/19-20, 8/21
angel hair- 1/11-12, 2/12-13, 3/13-14, 4/14-15, 6/15-16, 8/17
Jan 10, 2011 | Microwave Ovens
Inserted K cup and closed machine. Says Brewing but coffee machine only dispenses a few tablespoons of water...tried turning machine off and off, but same amount of water is dispensed each time, no matter...
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 01, 2011 | Microwave Ovens
Pasta boat manual
MicrowavePasta Boat InstructionsFor elbow, bowtie, ziti, rotini, and penne
1 serving -1/2cup -water levelat #1
cook times based on serving ( serving - minutes)
1 - 17
2 - 18
3 - 21
4 - 23
6 - 25
8 - 27
Stir macaroni once halfway through cooking for al dente; for softer pasta, cookseveral minutes longer.
For spaghetti, linguine, angel hair andfettuccini
Cook Time: servings/minutes
angel hair- 1/11-12, 2/12-13, 3/13-14, 4/14-15, 6/15-16, 8/17)
Nov 30, 2010 | Microwave Ovens
How much coffee grounds should I use for 30 cups of coffee made in a west bend 30 cup coffee maker?
!/4 cup of coffee for every 8 cups of water or almost a full cup of coffe for your 30 cup pot...
heatman101
Sep 07, 2010 | Microwave Ovens
GE Microwave, inexpensive model, I place a cup of coffee to warm on the turntable, enter a time, it ends and beeps, I open the door, the coffee cup handle is positioned away. I've gone through many...
Hello BillJohn! I've found that, after many countless hours of precise trial and error testing, that the optimum placement of the cup and a predetermined time entered on the keypad will yield the desired results you're seeking.
By placing the cup on the outer edge of the turntable, with the handle facing to the right side, when looking straight at the cup of water, you would then close the door until it latches and enter in a time of 2:38 onto the timer, (that's 2 minutes and 38 seconds) with a termperature setting of either low or medium, (not the default high).
This will provide you with a warmed up cup of joe, with the handle facing in such a manner that you should be able to grasp it in either your left or right paw without much trouble. However, this will only work approximately 82.5% of the time, the rest of the 17.5% the cup will end up at the 3 or 4 o'clock position (when the handle will be facing the back of the micro).
Otherwise, you'll be destined to have to grasp the cup with your hand and manually rotate it until the handle can be grabbed easily for extraction from the microwave. Of course, it goes without saying that that cup could be quite warm after the timer beeps and signals that the heating/cooking process has been completed.
Please remember that this highly sofisticated kitchen appliance was once only available to the ultra rich, back when the first Amana Radarranges were available for sale. These microwaves once had the unbelievable pricing at around $1200, all so some ultra rich person could reheat their leftover quails eggs and caviar, (along with that peruvian cop of coffee that their butler let go cold).
So be thankful that modern manufacturing technics have been able to harness the atom vibrations that allow for rapid heating and cooking for under $100 these days! Why just today, Home Depot was offering a dal for a small microwave for $19.00 on their Black Friday deals! I would have purchased it, but after seeing your issues with these new fangled devices, I decided that having to rotate my cup after reheating it, was just too much to do, even for the odd 17.5% of the time it happens!
Enjoy that warm cup of Joe and please keep an ongoing log of your actual results of how many times the cup and handle end up in the unaccessible position of 3 and 4 o'clock for the next 30 days.
I'm seeking more real-world data before I publish my statistics on this unusual cup/handle ending position phenomena.
Hope you find this Very Helpful and best regards!
Nov 27, 2009 | GE Microwave Ovens
Inside Microwave is Hot
Hi, What you noticed is perfectly normal...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Feb 26, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
202 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
