Question about Goldstar MV-1501 Microwave Oven
Some numbers don't work
4,5,6,0 defrost & time cook don't work. have tried unplugging and still no luck. it broke just after 1 yr. warranty up!
  • Goldstar Master
  • 9,098 Answers
You have a failed membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 02, 2008
I am not able to get the unit to cook, I have to unplug it and then only the number 1 cook time and the number six cook time work
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 16, 2013 | Emerson Microwave Ovens
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
How do you set the power level? The model number is: JVM1730DM1WW The serial number is: MM901698B
Assuming your touch pad is working properly, press Time Cook (for cooking) or Time Defrost (for defrosting) and then type in the length of time that you want the microwave to operate. Then press Power Level and type in a number from 1-10. Finally press Start. Depending on the GE microwave, the Power Level button may be above 2 or to the left of 0. (I've seen both keypad designs depending on when and where the microwave was manufactured.) If you press Power Level before setting the cooking time, the unit will reset when you press Time Cook or Time Defrost.
GE has the manuals for some of their microwaves on their site. See http://www.geappliances.com/service_and_support/literature/ and enter the model number in the search engine.
I hope this helps.
Mar 02, 2011 | GE Microwave Ovens
The Cook Time I use to work, not it wants a code and if I put in a number it will start. But I can't set a cook time or power level. The Cook Time II works ok, except I can't use the number 1; defrost...
Is it possible that some cleaner got into the controls? That'll kill them quickly.
Hopefully it will dry out on its own. I'd unplug it overnight.
If not, then either there is moisture on the control board (which can be dried or allowed to dry) or in the layers of the membrane keypad.
But the membrane keypad may not be available any longer. It is part number WB27X287 and if it still available, it may take a week or so to get it, it will probably be about $150-180, and you can try to order it from the Pros here, the Sears Parts Direct Web site image-4235112-10659157 or from Encompass here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
We do board repair, so let us know via our site if we can help further.
Dec 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I inherited a 1986 J.C. Penney Microwave and can't figure out how to program most of the features. I need an operating manual or a gnome.
The clock must be set before you can use the microwave. When you plug it in, it should read all zeros. Enter the time, and press "Clock Set." Time is in 12-hour format. There is no daylight saving time.
For basic microwave use:
1. Press "Power."
2. Press the keypad corresponding to the desired amount of power, e.g., "High," or "Defrost." (The numbers on the keypad have little words on them, like "Warm," "Med," and "High".)
3. Press "Time."
4. Enter the desired cooking time, e.g., "1-0-0" will be 1 minute; you could also do "6-0" for 60 seconds. You can do as little as 1 second, up to 99 hours 59 minutes. "1-0-0-0" would be 10 minutes. "2-0-1-2" would be 20 minutes 12 seconds.
5. Press "Start."
NEVER operate the microwave when it is empty. Put at least a glass of water in it. Never put a glass in it empty; make sure the glass has something in it, like water. Be careful when taking out a glass of water that's been heated; the water has been known, in rare instances, to "explode" and severely scald people.
It is okay to use the approved metal rack (it's coated with ceramic to prevent arcing) when using the microwave in microwave mode. Of course, the metal rack is also fine for use in the convection/combination mode.
"Defrost" cycles between microwave and nothing, microwave and nothing, microwave and nothing. You can hear the cycles. If defrost takes too long, try "Low." Try to avoid using "High," as it kills most nutrients in the food. Opt for "Medium" for slightly longer time; it'll be more evenly heated and healthier. Some things, like popcorn, require "high" power.
To stop the microwave in the middle of cooking, simply open the door. (There's no such thing as microwaves escaping the oven and bouncing around the kitchen and zapping you. I have a microwave tester, and the moment you open the door, all microwaves dissipate; the reading at the door is "Zero" once it's opened.) Or, press "Cancel." If you open the door, you may test the food, and if it needs further cooking, you may close the door and press "Start," and it will resume where it left off. If you're all done, just press "Cancel."
There is no way to disable the 5 beeps at the end of the cycle. If the baby is sleeping and you don't want to hear the beeps, simply open the door right before the beeps when the countdown is at zero. Pressing "Cancel" will give you one beep.
If you have the Combination feature, that cycles between microwave and convection heat, giving the best of both worlds (cooking inside with microwaves and outside with convection), for things such as a whole meats.
To use Combination:
1. Press "Combination."
2. Consult the chart on the microwave (below the keypad) and choose a number from 1 to 4, depending on what type of food you're preparing (i.e., lamb, pork, etc.).
3. Press "Time."
4. Enter the desired time, using the method described above.
5. Press "Start."
The Convection feature simply blows hot air across the food, at the temperature and duration that you set. It's a great way to toast slices of bread for the whole family at once, or bake a pizza.
To use the Convection feature:
1. Press "Convection."
2. Choose the temperature (the degrees are printed on the keypad, such as "350 degrees."
3. Press "Time."
4. Enter the length of cook time, using the method described above.
5. Press "Start."
Be sure to cover foods (with a paper towel or suitable plastic cover) that are prone to splattering. Don't let foods explode and get up into the motor. Clean the inside regularly with a soft sponge and mild detergent, NOT harsh or abrasive chemicals like Comet. Then rinse the soap off with a clean sponge.
Be sure to close the door firmly before cooking, but don't slam it. Slamming it will wear out the latching part, but being too gentle in closing the door may cause the safety switch to not engage, and the microwave won't work (it'll count down and the light will turn on but the motor won't run).
Note: the Convection feature uses more wattage than the microwave counterpart. The volts and amps are listed in the door jamb; multiply them together and you get total watts (although the actual amount will vary depending on your "power" settings).
Aug 07, 2010 | Microwave Ovens
I have a GE Spacemaker and used defrost for the first time at Thanksgiving. Now I can't turn it back to normal cooking. Can you please help me?
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If it still doesn't seem to work, I'd consult the owner's manual for a quick refresher. You can find it
here.
If it still fails to cook at full power, I'd say your magnetron is failing.
And if so, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your previous symptoms:
"I have a GE Spacemaker and used defrost for the first time at Thanksgiving. Now I can't turn it back to normal cooking. Can you please help me?"
Nov 28, 2009 | GE Microwave Ovens
The power button is not working,i do not use this button very often, less than 1 time a week. i have had the oven 3-4 years
First try a hard reset.Unplug it a couple of minutes, then plug it back, set the clock, and try again.
A typical key sequence to cook for a minute a 70 percent power would be:
Cook Time (or "Cook") > 1 > 0 > 0 > Power Level (or "Power") > 7 > Start
It varies by brand and model.
If it still doesn't work you may have a failing keypad. If so, please leave it unplugged or leave the door open when it's not in use, and of course please do not leave it running unattended.
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So please reply back directly to me with your brand and full model number from the tag in or on the unit for more help or free do-it-yourself tips or an estimate if required.
William E. Miller
prototech@usa.net
Sep 26, 2009 | Kenmore 63672 Convection/Microwave Oven
Panasonic Dimension 4 microwave switches off
Try resetting it--aka, unplug for about an hour, then plug back in and try again. If that doesn't work, make sure you try a different outlet, and if all else fails, contact Panasonic. They should be able to help you out with a repair/replacement (and if you're still under warranty, usually it'll be free!).
Their phone number (acccording to their website, www.panasonic.com ) is 1-800-211-PANA (7262)
Good luck! :)
Aug 27, 2009 | Microwave Ovens
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | Microwave Ovens
DEMO MODE
how do i change the bulb inside the microwave ge xl 1800
Feb 13, 2008 | GE XL1800 1100 Watts Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
37 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Mike
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
