Question about Samsung Dell Latitude D600 14.1 LCD SXGA+ Display - LTN141P4-L01 (LTN141P4L01) CD-ROM Drive
The screen turns off
I have a Dell Latitude D600. When I turn it on for the first 90 seconds everything is fine; however, after that time has elapsed the screen turns off (menaing the screen goes dark). Sometimes, when I turn it on the screen does not light up at all.
I like the laptop and I would like to fix this probelm.
Please help.
  • Anonymous Mar 06, 2009
    I have the same issue, did you find a solution?
  • 561 Answers
Sounds as though your LCD Inverter needs replacing. Try connecting your laptop to an external monitor. Once connected, if you press Fn + F8 keys and transfer your screen image to the external, then replacing the LCD inverter will resolve the issue.
Posted on Dec 30, 2009
  • 558 Answers
REMOVE ALL POWER FROM THE COMPUTER BEFORE YOU ATTEMPT Try this first remove the control plastic panel above the key board,reseat the lcd cable to the motherboard.If no go you may have a loose or bad inverter.Here is how to fix this,REMOVE THE BATTERY,AC CORD.On the front of the display you will see some little rubber covers these cover the screws revove the make sure you put them out of the way,remove the screws remove the bazel.Below the LCD is a little card about six inches called a inverter make sure its snug(CHECK THE WIRE PLUGED INTO IT FROM THE LCD),since you got this apart you might want to look at the rear of the lcd the back panel comes off too but you will have to remove screws as well.THAT CABLE SHOULD BE SNUG AS WELL YOU CAN USE A PIECE OF TAPE TO KEEP IT SECURE.Now thats it for the physical display.Put everything back together and try again.
Good luck
Posted on Sep 10, 2009
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
Nov 05, 2010 | Dell Latitude D600 Notebook
Have a Dell Latitude D600 will not boot. All LED
LEDs indicate a memory error
Reseat RAM and try modules one at a time. If ony 1 module, replace it
Dec 16, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 wont turn on
test power supply- test ram- have cpu tested- test connection from front button to motherboard
Aug 06, 2009 | Dell Latitude D600 Notebook
No screen after the dell startup logo
Thanks-we reinstalled the disc that came with it (it was a used work laptop, no manuel) and it's working fine. Thank you! Lee
Apr 12, 2009 | Dell Latitude D600 Notebook
Sound doesn't work on Latitude D600. Master Mute keeps flashing on screen and the sound turns off
you have to install the sound driver, go to dell webpage, look for download drivers, choose your laptop serial and ur opertating system and download the Audio driver, then install it on ur laptop and everything will be fine.
Best Regards
Mar 24, 2009 | Dell Latitude D600 Notebook
Laptop won't power on Dell latitude 600
step 1. unplug everything (all usbs, extra screens, power supply...EVERYTHING!)
step 2. take your battery out, and leave it out
step 3. Hold down your power button (with the battery still out) and count to 15
step 4. put the battery back in (you can plug everything back in too)
step 5. turn it back on...if this still doesn't work. call Dell
Mar 06, 2009 | Dell Latitude D600 Notebook
Wanted: replacement display screen - Samsung 14.1"
HI
You can buy from any of these.
http://www.google.com/search?rlz=1C1GGLD_enIN307&aq=f&sourceid=chrome&ie=UTF-8&q=D1002+dell
I have got almost 3.
Shopping results for D1002 dell D1002 - Dell Latitude D600 LCD Screen $149.97 - Renwerx Tech DELL D1002 LATITUDE D600 SXGA+ 14.1 DIS $253.75 - codemicro.com Dell D1002 LCD 14.1" TFT SXGA+ LATITUDE D600 $488.75 - eBay
Do let me know if you need further information. Its pleasure to assist you. And let me also inform you that can call Dell Spare Parts Sales and ask them to get this one for you. You get 90 days of warranty as well.
The part number is D1002 for the monitor.
Thank you
Rakesh
Dell Expert
Jan 06, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600
remove the battery and adapter..keep the power button pressed for 10-15 seconds....again plug in the battery\adapter and turn it on...
Feb 08, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
162 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
