Question about Gateway GT5220 PC Desktop
Gateway gt5220 beeping noises, fan on.
My comp has a malfunction in it, and when i turn it on, the fan turns on, but nothing on the monitor shows up. Also, it makes beeping noises every 3 seconds. Is this problem common? Does this mean the motherboard is dieing? help! I've had this comp for 2 years, is that effect the reason why its dying?
  • Anonymous Dec 28, 2008
    same problem but I don't think my fan is running.
What may be happening is that files are corrupt as a result of a HD failure. This is not that uncommon. It has happened to my computers causing strange beeps and often repeated clicking noise coming from the hard drive. HD failure can happen anytime; when booting up, while the computer is running. The only way I've found to fix this is to buy a new hard drive and reinstall the operating system and programs you typically use.
You may be able to recover files from the ailing drive however. After you get the new hard drive working with your newly installed operating system and all is working, you can setup the ailing drive as a slave while setting your new drive as a master. You need to power off the computer and consult the data sheets for jumper settings.
This will allow you to boot up and access your old HD as a spare. If your lucky the data files, pics, music and documents you created will be in a region of the hard drive that isn't corrupted. Be prepared however to expect some unrecoverable files. If there is physical damage to the drive mechanism like a stuck read/write head then you may be totally out of luck. I have in some instances been able to unstick the HD by giving it a sharp rap on it's edge and even opening it to push the head free. Success for such a radical procedure is rare, but when it works, you have enough time to copy files over before enough dust collects on the exposed HD.
Assuming your able to access the old HD as a secondary drive, copy all of your files over to a backup directory on the new HD. I would recommend an expternal backup HD that can be used to automatically save your files before the next failure happens.
Posted on Nov 30, 2008
My desktop turns on but my monitor doesnt come on its plugged in right but my desktop just shows a light that its on
use other monitor..if it would not work listen for beep codes from your cpu.continuous three beeps meaning change your memory cards or check your memory cards..see if your monitor has light
Sep 01, 2012 | Gateway GT5220 PC Desktop
Computer wont boot up
you need to refix the RAM sticks and restart your pc. IF the problem persists change the RAM slots and put RAM sticks one by one in different slots, then restart your pc it will work
Feb 15, 2010 | Gateway GT5220 PC Desktop
When I turn boot up my gt5220 the monitor briefly flashes and then goes into power saving mode- desktop stays on, fans running and all, until turned off by holding power button down or unplugging it.... my...
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Dec 02, 2009 | Gateway GT5220 PC Desktop
No video
change the boot sequence from the BIOS and set the first boot to the Hard disk and check.
Nov 11, 2009 | Gateway GT5220 PC Desktop
Puter will not start
More than likely, a memory chip that is not seated properly. Open the computer case and look at the motherboard. Memory chip slot banks are usually about 2 to 3 inches long, with white clips on each end of the individual slots. Check for a loose one. They must be seated VERY firmly so that the white clips lock down.
Oct 15, 2009 | Gateway GT5220 PC Desktop
Gateway laptop comp. no problem connected to Dell926 printer with new dell cartridges will not turn on was ok before replacement
of course verify all power connectors to printer. If everything is OK there then I suggest reseating the cartridges and trying again.
Sep 11, 2009 | Gateway GT5220 PC Desktop
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
Gateway GT5220 PC Desktop Logo
184 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
