Question about Philips GoGear SA3245/37 Digital Media Player
MP4 GoGear won't connect to PC
The minute I connect the usb to the PC, the MP4 (GoGear Philips SA3027/55) shuts down. I've tried in another PC and it worked just fine. Seems that in mine, I need a driver or something. Please help me...
Thanks.
  • 8,596 Answers
Make sure the hold/lock switch is not engaged. If you are running Windows Vista, you need to get the upgraded software from Philips website. If all else fails:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jan 07, 2009
Connect mp4 player to usb
USB ports on car stereos are not designed to be universal, regardless of what the USB acronym implies. They are typically designed for a specific product, either iPhone, Android, Blackberry, or a combination of those. They usually work with a blank flash drive (no operating system on it). That would be my recommendation: Buy a flash drive. $5-$10 invested will probably get you more storage than the GoGear and will work with USB.
The reason USB sounds better than the auxiliary input is because with auxiliary, the D-to-A (Digital to Analog) conversion is done by the GoGear, while with USB it is being done by the car stereo.
Dec 20, 2013 | JVC Car Audio & Video
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
Philips gogear 8gb mp3 file system error
m8 that happens to minebut i cant fiqure it out
Oct 22, 2011 | Philips GOGEAR SA6045 MP3 Player
When I got my GoGear Vibe 4GB MP3, I download videos, which it said i was able to on the back label. I cannot watch the video's I've downloaded AT ALL as they do not show. The video which was...
Check the specification of your MP3 player to determine thetype of video file format it uses. Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is an incompatiblevideo file format, then you need to convert that video file to a format thatyour MP3 player uses. Click on this link for instructions on converting videofiles for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
Aug 24, 2011 | Philips GOGEAR SA6045 MP3 Player
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
My Phillips GoGear MP4 player stopped updating at 99% and will not continue.
1. Launch Philips Songbird program from Windows start menu. The program can be found on GoGear Accessories disk, or you can download it from:
http://www.userdrivers.com/MP3-Player/Philips-Songbird-1-7-2-Build-1667-for-Windows-XP-Vista-7/
2. Reset your GoGear player while holding Volume+ key and immediately connect it to computer. (You should do it before "Udating at ..." message appears.)
3. From Songbird menu choose Tools -> Repair my GoGear Vibe.
4. Follow the instructions.
Oct 09, 2010 | Philips GoGear ViBE SA1VBE08K MP3 Player
My mp4 doesnt turns on when I connect ir to the pc, not recongin
Have you tried with different USB slot in your PC ? If you have tried and still not working then you need to check the hardware settings in your PC .
Go to control panel->add hardware -&check, whether it is getting detected .
The above step is for OS xp.
If you are using any other OS ,let me know .I will provide you the steps for it .
Hope this helps .
Thanks for using Fixya.
Dec 08, 2009 | Philips GOGEAR SA6045 MP3 Player
MP4GoGear Won't connect to PC
Nov 30, 2008 | Philips GoGear SA3245/37 Digital Media...
Philips GoGear SA3245/37  Digital Media Player Logo
414 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
