Question about Goodman Heating & Cooling
My GOODMAN furnace GMH80703ANAA Starts but quits 5 seconds later
My furnace is only 2 years old. It worked fine untill 2 days ago. Now it tries to start, the ignitor glows to a orange color,then the gas comes on for about 2 seconds and burns then everything stops except the fan and the whole cycle starts again. It will cycle several times like this and then stop for a while and start the prosses over.
Thank you for any help I can get, it's Sunday and cold here in Minnesota.
  • 96 Answers
You have a flame sensor that may just need cleaning take out and take fine sand paper or emery cloth and clean
Posted on Nov 30, 2008
  • 1 more comment
  • wfk1212 Oct 04, 2010
    dwk guru - you da man... I had the same issue and took some cheese cloth, wiped it down and fired it up. Seems to have done the trick. Thank you very much, Truly.
  • mito0 Jan 23, 2011
    great advice, dwkcool!
    a light sanding on the sensor did the trick.
    for those unfamiliar with this part, it looks like a long spark plug hanging down behind the burner on the far left.
    it's held in with a single screw.
    this took 2 minutes and saved me plenty of money on a wasted service call.
    thanks!
  • tdietz09
    tdietz09 Nov 25, 2012
    Worked for me as well. Thanks for the advice.
Furnace begins the process of starting up then 5 seconds later it turns off. It does this repeatedly, sometimes for like an hour then it works fine.
Easy fix. Furnace is not getting confirmation of ignition. Remove the flame sensor and clean it with sand paper. re-install it and retry as seen in this video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 26, 2012 | Goodman Heating & Cooling
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
I have a Goodman GMP125-5 furnace. A year ago, my circuit board was replaced by a repairman. He also replaced the heat exchanger, because he said it was cracked. It worked great until about a month ago....
it would sound like the pressure switch is not working you can take off ther tubes and by hand put a small drill bit in the and clean the switch , some times this works , on some you can jump out the switch and try and fool it in too working
Jan 08, 2011 | Goodman Heating & Cooling
I have a downdraft Goodman furnace. On only some occasions the blower will start, then after a few seconds I will see the igniter light up, but then I do not get the rush of gas and lighting of the...
It sounds like you got a tough one there.When you say the blower starts up and then the igniter comes on are you refering to induced draft motor or main blower. The proper sequence is for the thermostat to call for heat at which point the induced draft motor should come on and run for 30-45 seconds,then the igniter should heat up for a few seconds then gas valve should open and main burner should light. After limit switch reaches set point for fan on ,blower should come on till after heat has reached thermostat setting then burner should go out, and blower run until fan off setting is reached on limit switch. If your furnace is not following this sequence and then not always doing the same thing in the same order,I would recommend that you change out board again. I have had several problems similar to this with Goodman units and all but one time installing new board solved it. That time I did everything I knew to do and talked to factory service techs repeatedly and finally installed new furnace. As far as your question about insulation,. As long as it is fire proof I can't see where it would hurt anything. Sorry I'm not more help. Good luck and thanks.
Nov 12, 2010 | Goodman GDS80904BNA Open Flame Heater
Induction Motor continues to run.
pull the rubber hose off the pressure switch. and blow into the Induced draft motor housing if you cant you can pull the hose off the IDM and try to clear it with a small paper clip. reconnect and try again. you can also get the flash code off the board while the unit is running but not working.
Dec 11, 2008 | Goodman GMS90703BXA Heater
Flame going out!
Take the flame sensor out and clean with fine sand paper or emory cloth
Dec 09, 2008 | Cozy (W352E) Heater
Goodman furnace
sounds like the fan switch in the furnace is coming on and off. This is common for Goodman. or could be the heat anticipator on the t-stat. While there are several reasons this happens these are the most common.
Guy
Oct 29, 2008 | Heating & Cooling
Heating & Cooling Logo
740 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
