Question about Polaroid A500 Digital Camera
Memory card shutter wont close
The other day my camera was working fine but then for some reason the memory card shutter came open and now i cant get it to close back up
    Genius:
  • 2,985 Answers
Try closing it with the card removed.
If it will will not close shut, this suggests a piece of plastic has broken off.
The quick fix is gaffer tape it shut.
Indeed it is likely the only fix unless the camera is still under warranty, whereupon it will be replaced
Posted on Dec 01, 2008
Shutter-release button doesn't work
The manual only can give two reasons why the camera would not take pictures.
One, there is no memory card placed.
Two, the memory card is full.
You are sure you have placed a working empty memory card.
If you did save all the pictures on the memory card to a computer, try formatting the card in the camera.
When you are pressing the shutter release button half, does the camera say it is focused correct? light bottom corner of the display.
Your camera has a setting to take pictures with a remote control. Did you put the camera in that setting? Read page 76 of the manual.
success
Jan 16, 2014 | Konica Minolta DiMAGE A200 Digital Camera
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
Black screen when i turn camera on have changed the memory card, menu works and all my pictures are still there when i go to preview on old memory card, have changed the batteries also. Kodak...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 19, 2010 | Kodak EasyShare C913 Digital Camera
Memory card error
Bet you have a bent flash card pin. Remove the card and look in the slot for a bent pin. If so, remain calm as you might be able to fix it. Remove the camera batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Jul 20, 2008 | Canon PowerShot A85 Digital Camera
When i insert the memory card the camera freezes.
It sounds as if either the file allocation table or some data on the card has become corrupted.
Have you got access to another camera (friends or family) that you could try it in?
Have you got a card reader on your PC? If so, you should be able to re-format the card using Windows. (Go to My Computer, right-click on the card reader icon and select format)
Hopefully this will cure the problem. If not, you should be able to change it if it is new.
Matt
Feb 27, 2008 | HP R967 Digital Camera
The shutter wont engage.
Preliminary searching leads me to believe that this camera won't take anything larger than a 1GB memory card.
Nov 11, 2007 | Kodak EasyShare C315 Digital Camera
Canon A310 Won't Power Up.
Try checking this... on the battery door (the outside door) along the top edge (over the CF card pointer embossed in the back of the door) you should see a little plastic piece that pokes out... tis is supposed to push a small switch located in a slot over the battery compartment. It's the sensor that tells if the battery door is open or closed.. if the plastic part breaks off or gets chipped it wont push the button and the camera will not turn on when the shutter door is opened.
Jun 09, 2007 | Canon PowerShot A310 Digital Camera
Camera wont take pictures
Contact the Tech Support site if the manual does not cover the problem.
May 23, 2007 | Konica Minolta DiMAGE E500 Digital Camera
Shutter won't close on Nikon D70s
Format the card. I have same problem with mine ---requires a new shutter assembly.$40.00 item and they want $300.00 to fix it at Henry`s cameras. Ouch .Better to buy a new camera.
Nov 19, 2006 | Nikon D70s Digital Camera
Polaroid A500 Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
