Question about Maytag MZD2766GES Side by Side Refrigerator
Trying to repair water dispensor
Maytag side by side refrigerator 2 1/2 yrs old. water dispensor just stoped. I took out filter even though light didn't say to be replaced and put in bypass, but still no water. water seems to come up to filter, but can't tell if it goes on.
  • 3 more comments
  • italianstall Dec 02, 2008
    the crushed ice,cubed ice, or the water dose not work.
  • Anonymous Dec 14, 2008
    Water and ice dispensor just stopped working. Ice maker is making ice.
  • superken3136 Feb 01, 2009
    Water dispenser quit working, still gettting ice
  • Anonymous Feb 11, 2009
    my water quit working because the line froze in the fridge i left the door open for 5min. and started working again.
  • reinertl Mar 30, 2009
    I have same problem, but in addition the light is constantly on as long as door is shut. Initially it sounded as an alarm was set, as the light was turned on and off for a few times, and since I have not been able to get ice/water. Switch board seems to work, as I can change between water/ice and I can lock/unlock the switches. It also produces Ice, so no issue with water inlet valve, I think.
  • 231 Answers
Check/clean/replace dual water inlet valve/solenoid.
Posted on Dec 29, 2008
I just replaced the water filter in my Maytag French door refrigerator (2 yrs old) and now the water/ice dispenser will not operate. All other functions on panel are fine (alarm, light, etc.). I tried to...
Hi, there is a micro-switch at the filter which shuts off the supply and operation while the filter is out of the unit. That switch is still open, so the dispenser thinks you are still replacing the filter. Try taking the filter out and putting it back in. Make sure any locking mechanism is fully engaged. In the meantime, I will see if I can find the service manual for your unit.
Jan 09, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
IT IS ABOUT 4 YRS OLD AND THE WATER STARTED TO
I would not advise using bleach. I would disconnect the pipe from both ends and blow down it, either by mouth or air gun to ensure of no blockages. You should poor away at least 10 cups of water after changing filter to ensure clean fresh water.
Dec 15, 2009 | KitchenAid Superba KSRG25FK Side by Side...
My GE Profile side by side refrigerator ice dispensor and water dispensor has quit working. The appliance is less than 4 years old. Wanda
The common connection between the two starts at the water fill valve. I have found also that the filter (water) if clogged, will prevent water flow to both. Change the filter first, cheapest and eaisest.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
I changed the filter for the water dispenser and after purging the water for awhile, the dispenser stopped working. What needs to be done to get the water dispenser to work again
Put the old filter back on , if water was fine . You never change filter just because a light comes on telling you to . The change filter light comes on after time or usage of dispensor .( Good way for manufacturers to make extra money ) . Change the filter only when water flow slows from dispensor .
Aug 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
Icemaker not working after installing new filter
I have a Kenmore 106.56542400 icemaker stoped working ,water line is cleared not getting water to icemaker
Jul 02, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jenn-Air "replace filter" light
each dispensor is a little different, but youll need to hold down a button(perhaps even a combonation of 2) for3 seconds to "reset " the filter indicator.
Mar 19, 2008 | Jenn-Air JSD2789GEW Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
167 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
