Question about Lasko Ceramic Heater
Lasko heater beeps too LOUD
I have a Lasko electric space heater. It works great, except whenever you press a button on the unit or the remote, it makes a super loud beep. It is painfully loud and will wake up anyone in the house.
I'd like to disable the speaker. Has anyone had any luck doing this?
It is a Lasko model 6000.
Thanks,
Joe
  • nc_joe Dec 11, 2010
    Thanks for the reply! Just 2 years late. :)
    I actually did the same thing as you last year. I took apart the heater and unsoldiered the speaker from the circuit board. We have 2 different heaters and I did the same to both that day. They've worked fine ever since with no beeping at all.
    Each of the 2 heaters had a couple special screws where hard to get. I think on one I filed down the center of a flat head screw driver to get it to work.
I was cleaning out my Lasko ceramic heater 6000, looking for instructions on how to do so, and came across your comment. After I opened it up and cleaned everything out (really easy, no instructions needed, it is all obvious) I started thinking about how much I hate that beep as well. So I decided as long as I had it opened to try to disable it.
Well, I could tell from plugging and unplugging that it was (unfortunately) mounted on the under side of the green circuit board. You will have to unscrew the circuit board completely (all wires still attached) and (carefully!) move it so you can flip it upside down to get to the other side. Note: there were 7 screws to remove and 1 was under the motor and really hard to get to. The motor looked WAY too complicated to remove so I got the screw started just a little with a precision screw driver and turned it the rest of the way with needle nose pliers.
Once the circuit board is off, the beeper is a little black circular thing (about 1/2 inch in diameter) with a little hole in the middle. It has a serial number on it and a "+" symbol. It looks like it is built in two pieces (upper and lower), so I tried to carefully remove the upper piece with needle nose pliers while leaving the lower piece connected to the circuit board. Well, the whole thing ripped out! I thought two things: 1) It will never beep again, and 2) I hope this didn't break a circuit causing the whole thing to fail.
Well, I put the circuit board back on ( I left off the one difficult screw, as 6 of 7 is more than sufficient to hold it on). Put the whole unit back together, and . . . . IT WORKS FINE!!!!!
Posted on Dec 10, 2010
  • 4 more comments
  • zhensman Dec 10, 2010
    One other comment. I wouldn't exactly recommend ripping out the beeper from the circuit board like I did. I may have been extremely fortunate not to disrupt some other circuitry. I can't guarantee you that you won't damage anything. I think I just lucked out.
  • zhensman Dec 12, 2010
    Yeah, I figured by now you had long since solved it, but hopefully it will help someone else.
  • lucy Nov 17, 2011
    I used this same approximate method on my Lasko 5395 and it worked! I found the same black ring on the top of my circuit board which I pried completely off. On my model I had no issues with getting the screws back on. I will note that there are two triangular "security" screws on the back cover of my heater, which I used normal scissors to unscrew (I don't have any fancy tools and the scissors fit well enough).
  • lucy Nov 17, 2011
    P.S. Thank you so much zhensman for the instruction.
    On a side note to others (an addition to my previous comment), I am posting this immediately after I fixed my space heater of the annoying beep (because I am so happy it still works! and w/o the beep) -- so while it seems to be working great -- I am not sure if this has affected its future longevity or quality.
  • zhensman Nov 22, 2011
    Glad it helped! As far as longevity is concerned, my "modified" Lasko is still working fine.
  • Chris Covington Nov 02, 2014
    Awesome post, the only one I found that provides a solution. Igive credit to you for pulling that circular black speaker out (with hole)...that was risky but has benefitted us all :) Btw I have a Barrington tower heater I bought from Walmart, took the back off (about a dozen small screws) located the circuit board at the top of the unit and UNPLUGGED mine by gently wiggling back and forth. Nothing came apart :) Thanks again for posting Z-man...super helpful.
    New Friend:
This worked like a charm for me. Thanks!
Posted on Oct 18, 2015
    New Friend:
THANK YOU!!! I did the same and it worked! I've had this heater for 2-3 years. I removed the cap by wriggling it out and it popped off with no problems.
My fiance is a light sleeper and he wakes up before 3am, so I don't want to wake him up because I'm trying to stay warm. :/
The top "control board" had screws so I removed it and it was easier you access the circuit board screws.
Thanks so much again!
Posted on Jan 22, 2015
    New Friend:
THANK YOU FOR THIS! We were using the heater in our baby's room, and the loud annoying beeps would wake our baby every time we turned it on/off/adjusted the temp while he was sleeping. I have a different model of the ceramic Lasko heater, but the instructions were adequate for me to find the speaker. I did have to purchase a specialty T10 Security screwdriver (bought it from iFixit.com) in order to remove the back of the unit and access the circuit board.
Posted on Dec 10, 2012
Can I purchase a new remote for an unidentified heater?
Heaters : Target
www.target.com/c/heaters-home.../-/N-5xtuk
Target Corporationheaters buying guide > ... (125) reviews for Lasko Tower Heater with Electric Control ..... (23) reviews for Lasko Digital Ceramic Tower Heater with Remote.
Lifesmart Meduim Room Infrared Heater w/Remote - Space ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Lifesmart Meduim Room Infrared Heater w/Remote - Space Heaters. ... This compact heater also includes a new larger remote control to operate the ... the best heater I have ever owned for my purposes and would definitely buy ...
Heaters - Overstock Shopping - The Best Prices Online
www.overstock.com/Home-Garden/Heaters/.../subcat.html
Overstock.comBuying Electric Heaters: Tower heaters: Tower heaters are ideal for many homes .... Lifesmart Slimline Compact Infrared Heater with Remote Today: $102.99 4.4 (10 .... Dyson AM09 White Hot + Cool Fan (New) Today: $449.00 $499.99 Save: ...
Jan 27, 2016 | Heating & Cooling
LASKO 5624 will not turn on. The red light underneath the clock button is on. How do I reset? Is this broke after 20 uses?
Disconnect power, (unplug); wait for over 20 minutes, (have a cup of coffee); Depress power button before pluggging in to wall socket . (This will let any voltages that are stored in the unit drain off).
Plug in to AC outlet and press power to turn on.
If this doesn't work, Lasko has a 3 year warantee.
CUSTOMER SERVICE:
Toll-Free (800) 233-0268. Email: producthelp@laskoproducts.com
Feb 02, 2015 | Lasko 5624 1500 Watt Convection Heater w/...
I have a ;asko 5141 model space heater and every time we plug it into a different outlet it melts the plug or the end of the plug on the heater. i've only had this heater for a hort time. what is the cause...
Have an electrician check the cord for a short circuit. It unit is under 3 years old it will be covered under Lasko's Warranty. Cord can be replaced, but it takes a special bit to take apart and know how to replace cord. You need a person you know who is Electrically and Mechanically capable for a safe repair.
Jan 04, 2011 | Lasko 5141 Ceramic Electric Heater
Hi, I have the Lasko Ceramic Elements heaters. When I plug it in, the light lights up to show it's plugged in, but when I try to press the POWER button turn it on, it beeps but does not do start heating...
If I am getting this right you just purchased this heater? I would return it and get another one. It sounds like the tip over switch is not made and will only show that power is getting to it but the tip switch is keeping it from heating.
Dec 14, 2010 | Lasko 5540 Ceramic Compact Heater
Need manuall for model 5620 electric baseboard heater
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Jan 04, 2010 | Lasko Under Desk Space-Saving Area Heater...
I have a Lasko Model 5532 electric heater. It has suddenly started shutting off often. I run it through the reset procedure (unplug 5-10 minutes, then restart) and that gets it going again, but then it...
All of these space heaters have thermal protection units in them. They are safety that shuts the unit down if it starts to overheat.If your fan is operating, then it sounds like the thermal protection circuit is faulty, and you'll need to contact Lasko for a replacement. These units do not have parts that can be purchased due to their UL compliance. Check the fan though, it might be obstructed. I have seen that more than once....Rob
Dec 28, 2009 | Lasko 5530 Ceramic Compact Heater
Dont know what buttons mean
hai sir the button which you are confused in is used only for reseting the equipment.please find your equipment seller for a copy of users manual.
Jan 29, 2009 | Lasko 5365 Ceramic Compact Heater
Lasko  Ceramic Heater Logo
4,245 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
