Question about Kenmore 24032\24036 Top Load Washer
Washer will not rinse
The washer will not finish the rinse cycle.The water stays in the washer.It will not drain out.
    Sergeant:
    Champion:
  • 311 Answers
Check lid switch; you should hear it click when lid closes; if it does there is probably nothing wrong with it. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
Washer will not finish its rinse or spin cycle
Check that water can drain out of the machine
1/ Check that the filter is not blocked
2/ Check drain motor is working (ie. not blocked with coins or hairpins etc)
3/ Check that pipe from tub to filter is not blocked (I had a sock blocking mine)
4/ If there is water in the filter and the drain motor runs then check that waste water hose is not blocked.
Aug 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
ck wiring to motor be sure all conections are tight lid switch is ok since will agitate also ck control bd for connections most likely suspect all ck ok is control bd itself
May 20, 2008 | GE WBB4500EWW Top Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Kenmore 24032\24036 Top Load Washer Logo
Sal De GO PATS
fordexpert
Ed Mac
