Question about Acer Aspire 5600 Series 5630-6951 Laptop
I am trying to reboot my acer laptop
Unfortunately, it keeps going over and over the 3rd configuration and shuts down and restarts, starting at the 3rd configuration, showing 0% and then shuts down/restarts
  • saqer500 Dec 03, 2008
    I want driver acer aspire 5600
  • mitch stein May 11, 2010
    what is the title of the 3rd configuration?
    Scholar:
  • 113 Answers
Have you tried configuring the BIOS to its default setting or setting it to its optimized default. and then restart. if still doesn't work out change the CMOS battery. if you need driver try this website  www.driver.com
Posted on Jan 22, 2009
When I go to start menu to shut down and press shut down it will just reboot and will ot shut down
Step 1:
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Feb 20, 2013 | Acer TravelMate 2300 Notebook
ACER LAPTOP KEEPS FREEZING
Sounds like your system needs a anti-virus issue. Restart the system hitting the F8 key as it begins to start until it the system gives you option of how to start the system scroll down to "LAST GOOD CONFIGURATION THAT WORKED" click on that. The system should start as normal, once it has go to your anti-virus and run that - then go and do a system restore to a point before it began having the freezing problem. This usually comes from movie sites with pop ups do not click on pop up only go to sites you initiate.
Jan 13, 2013 | Acer Aspire 5610 Notebook
What button to press to reboot laptop acer aspire 2930
You turn it off ...then back on to reboot.
click the start button - select turn off computer
Mar 24, 2010 | Acer Aspire 2930-4661 Notebook
My laptop will not load at all i boot up the fan will go on then the laptop shuts down reboots shut down reboot shut down and will not load anything just keeps rebooting how can i fix this with out losing...
press F8 immedialty after switcing on...try to load the option "Load last good system that worked b.....etc etc" else...
shut down restart press F8 select Safe Mode...
if it starts in Safe mode and u can get to Desktop...
get Tuneup Utiltiy from my website
www.sureshayyar.110mb.com
clean ur registry and try to start in normal mode...
Jan 04, 2010 | Acer Aspire 5520-5908 Notebook
Acer5920 stuck in configuring updates.
This is generally caused by bad blocks in the Master Boot Record(Table). The drive itself is probably not salvagable. You'll need a reputable reapir person to slave your drive to another system to get the data off.
Good Luck
Mar 21, 2009 | Acer Aspire 5920-6727 Notebook
Hi from london, have new acer aspire 1 zg5 new keeps shutting down after boot can u hlp pls?
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your keyboard. When the Windows Options menu appears select the "Safe mode" then press Enter.
Once you managed to boot to Safe mode, change the computer startup and recovery settings by right-clicking "My Computer" then select Properties. Select Advanced tab. Under Startup and Recovery, click Settings. Uncheck the box for "Automatically restart" under System Failure.
Reboot again normally, see if it will reboot again by itself. If you managed to make the system boot normally, proceed to Events Viewer to find out what is the caused.
If the system failed to boot normally after doing the above, you might want to boot the system to "Last known good configuration"
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
Acer 5630
reload the operating system
Nov 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Update Loop
only thing you can do sit restore the operating system, unfortunately sometimes this happens with updates like this, and the only solution is to restore it.
Jul 19, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
My computer keeps restarting itself
  1. Start laptop
  2. When the laptops Logo page closes, start to press F8
  3. You should get a Windows Start screen
  4. If you get a Windows Logo page (the kind you normally get when Windows loads, then reset it and start again.
  5. On the Windows Start page select "Last known good configuration" and press enter twice
Hope that solves it for you =)
Apr 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5600 Series 5630-6951 Laptop Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
