Question about OKI C5100n Laser Printer
Putting right the ip address ?
Thank you JEAP for your reply but how do I set the ip address when the Network Menu Is not Acessable and the reset on the card does not print out the MAC address?
  • 624 Answers
Before you proceed you need to know the static IP, Subnet Mask and Gateway address for this printer. Once you have them: -Enter the menu mode by pressing the + button -Press the + button till you come to the Network Menu. -Press the Enter button. You should now see TCP/IP. Make sure it says Enabled which is the default setting. -Press the + button till you come to IP address then press the Enter button. - IP addresses (for now) consist of four octets or four groupings of three numbers such as in this example *192.168.001.123*. Using the + or - buttons (+ counts up 0,1,2,3?.; - counts down 255,254,253?..) you are going to set the number of the first octet or in the case of the example *192*. Once you?ve set it correctly hit the Enter button. -Do the same for the other three octets. Hitting the Enter button after setting the fourth octet will set the new IP and take you back to the TCP/IP menu. - Press the + button till you see Subnet Mask and press the enter button. - Just like the IP address the Subnet Mast consists of four octets. Set the value to you needs just as you did with the IP address. Again when you hit the enter button after setting the fourth octet you will be taken back to the TCP/IP menu. - Again press the + button till you come to Gateway Address and hit enter. Enter the Gateway IP address exactly like you did when setting the IP address. Don?t forget to hit the enter button to set the address. You should now be at the TCP/IP menu again. -To exit the menu press the On-line button on the printer. Your printer should now be configured with you IP address, subnet mask and gateway address. As an added check I would go back into the menu by pressing the + button, going into the Information Menu and printing selecting the Print Menu Map option. Verify the setting we just made with what is printed out at the top of the page. If everything matches you?re ready to go! Let us know how it goes and please don?t forget to rate this posting.
Posted on Jan 23, 2007
HOW TO PUT MY IP.ADDRESS IN
Open the Start Menu, right-click on Network, and select Properties. The Network and Sharing Center opens...click on Manage network connections. Right-click on the network adapter you want to assign an IP address and click Properties. Highlight Internet Protocol Version 4 (TCP/IPv4) then click the Properties button.10 Nov 2013
How to Assign a Static IP Address in Windows 7, 8, 10, XP, or Vista
www.howtogeek.com/howto/.../how-to-assign-a-static-ip-address-in-xp-vista-or-window... HOW TO PUT MY IP ADDRESS IN Google Search
Dec 09, 2016 | Computers & Internet
Tip
Why can't you connect to the Internet?
First check your TCP/IP address - see my earlier tip on checking you are connected to a network. For most recent systems, (not Linux) open a command prompt window (type "cmd" in the RUN window from the start menu) and type ipconfig /all
you should see your network adapter name and IP address, a subnet mask (don't worry) and a default gateway, also a DNS server IP address. If ANY of these are missing, that's your problem, try repairing or resetting the network adapter. WRITE THEM DOWN. You may have more than one adapter, you need to identify which one is used for the Internet connection.
If they are all there, from the SAME window type "ping" followed by the IP address of your default gateway. If this fails, you have no connection to your internet router, find out why!
If this succeeds, type "ping" again, followed by the IP address of your DNS server. If this fails, type "tracert" and then the IP address of your DNS server. The FIRST address that will be reported is your default gateway; followed by your ISP address; if the only address you see is your default gateway, the link to your ISP  is down, give them  a call. If it succeeds, from the same window type "nslookup"
You will see a chevron prompt, type in the name of the site you want to go to, e.g google.com.
You should then see a reply from your DNS server, and an IP address for your required server. If not, then either your DNS server settings are wrong OR the server does not exist. It will be obvious which it is from the reply you receive. If the DNS settings are wrong, you can change them from the Control Panel, Network, Network adapter, Properties, TCP/IP v4 properties menu; try setting DNS server to 8.8.8.8 or 8.8.4.4 and try again.
on Mar 26, 2010 | Computers & Internet
How to assign ip address for laserjet M4345 when it is reset at 0.0.0.0
1 Press MENU.
2 Touch CONFIGURE DEVICE.
3 Touch I/O.
4 Touch EMBEDDED JETDIRECT MENU or EIO JETDIRECT MENU, depending on which type of
network connection you are using.
5 Touch TCP/IP.
6 Touch CONFIG METHOD, and touch MANUAL.
7 Touch MANUAL SETTINGS
8 Touch IP ADDRESS
9 Touch the left arrow or the right arrow to highlight each segment of the IP address.
10 Use the numeric keypad to type the digits in each segment of the IP address.
11 Touch OK to save the IP address.
Sep 16, 2013 | HP LaserJet M4345 MultiFunction Printer
How to put an IP address on the CopyStar CS-1820 printer
putting an ip to 1820, just go to system menu, scroll down look for the network setting, you will find ip address, then fill it up.
Apr 21, 2009 | Copystar CS-1820 Copier
How to reset the NIC to use DHCP
If you press the test button once on the network interface (a small black button near the network port) This should print out the network settings, you can then confirm the IP Address etc set on the printer.
I belive the defult setting on the network card is for DHCP= OFF, so if you default the network card you may not get the result you required.
The netword card can be set to defult by holding down the test button for more than 10 seconds. This should reset the network settings to factory defults.
You can unlock the menu on the 6312 by pressing the MENU and ENTER buttons and keep them held down for 5 to 6 seconds you can then access the menu.
The IP Address, Sub Net Mask and Gateway can be set via the control pannel menu on the pritner.
If the IP Address set in the pritner is valid for the network you should be able to get to the printers web page, you can then make changes to the pritners and network card configurations.
Mar 28, 2009 | TallyGenicom 6312 Matrix Printer
No Network Driver Load When I install Win XP Pro...
please check the IP Address i.e,
go to
Control Panel
Network Connections
Local Area Connection (Right Click On it)
Properties
Internet Protocol(TCP/IP) Properties
See whether the
IP Address,Subnet Mask,Gateway,DNS Server Address
is entered properly or not
if it is entered properly go to Command Prompt type the following
Ping ip address and ping gateway address and DNS address
if both are getting reply then connectivity is there no reply means
either the cable not plugged or else cable not poper i.e, RJ 45 Cable (Network cable)
if still not solved try to get the solution from the vendor or else friends or any computer technician nearby to u r home because until some one has to come over there and understand the problem then only we can solve the problem .
Sorry i thought it was a driver problem so therefore i gave the link for drivers
Aug 19, 2008 | Dell Latitude D510 Notebook
HP LASERJET 3055 Manual IP Address not saving
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
Jul 16, 2008 | HP LaserJet 3055 All-In-One Printer
Presario 700
First, you need 2 make sure if all your LAN devices are installed correctly on your laptop: To do this , right click on "My Computer" then select Manage from the menu that appeared. A window will open. Search and Locate then left-click "Device Manager" in the left colum. The right coloum should now contain many things. These things are all the devices that are installed in your system. To see if one or more of them are not working properly, there would be yellow, black or red exclimation marks (warnings) next or above their icons. If you do not see any exclmarks, then everything is working well.
Next, you'll have to change or edit your a.) IP address, b.) Network ID, c) WORKGROUP.
Inorder for your LT to communicate on a network, your LT must either have a static or an automatic ip address. An static IP means, that you as a user, specify an IP address and an automatic IP address will be "assigned" to you by the "server".
To check if you have an static or an auto IP click on start, then on "My network Places".A new windows should have opened now and 2 your left you should find the "View Network connection" globe icon. If you click on it the Network connections should appear in the right window. Right click on your Lan (Network Adapter) icon and select "Properties". Scroll down in the list 2 the bottom, to reach the "Internet Protocol (TCP/IP)", then click on it once and then click on the "properties" tab to open it. A small window shouls appear, You will see an option that says "Optain IP address automatically" and "use the following Ip address" If you are on a "home network, it would be better 2 use your own... IP: 192.168.0.202 , SN: 255.255.255.0
We shall leave The Gateway box blank for now because that would belong to internet configerations like asdl or idsn.
If you are on a corporate, business Network, then it is most likely an automatic IP address.
Inorder for your LT to communicate on a network, your LT must be member of a "Workgroup" or a "Domain". To check your "member" configerations, right click my computer and select properties, then click on the "computer name" tab. Your OS should indicate: Your Computer desc, your Full computer name and Workgroup. If you are on a home/private little network, each entity in your LAN must have the SAME workgroup but each must have a UNIQUE IP. If you are on a corporate/business network, you will be added to a domain. To change your settings, click on the "Change..." button at the bottom right of the window. A new windows should appear and you can change to the settings you want.
Now, we have to test connectivity and if your IP and LAN are set up. To do this, click on start, click on run, then type in "cmd" without the quotes. A command prompt windows should now appear, so you will type in "Ipconfig". The output should show you your network connections, their MAC addreses and their IP addresses. Next type in the following "ping ::1" or "ping localhost", without the quotes. In this way, we test if OUR network is up. Now we need to check if we can see or info other computers on the network. FInd out another computers IP or Computer name thats on the network. Then type in "ping COMPUTERNAMEORIP" where computername or ip is the computername or the ip of the other computer without the quotes. you will see something like this when successful :
Reply from 176.16.63.80: bytes=32 time<1ms TTL=127
Now you know that your LAN is working.
You will also need to check your firewall settings and if you have file and printer sharing enabled.
Kind Regards
Stef
Apr 17, 2008 | Compaq Presario 700 470024-192 Notebook
Connectivity
ok, clicking repair is a stupid setting that windows puts in as when you click it it immediately returnsyour pc's ip address to a windows default ip address which you router cannot read and therefore disconnects you. Go to your network adapter properties, right click on task bar icon on go to network connections and right click>properties TCP/IP line and click properties again then select if not already 'obtain ip address automatically', then ok it and close windows. If you are connecting through a router you need to get into the set up menu of ypur router by typing the router ip adress in your web browser(refer to manual for the address)and look for the conections menu and ensure your password and username is correct and make sure DHCP is enabled so as to give your pc an automatic ip address
Jun 24, 2007 | NexxTech NPCINIC Network Adapter
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if don´t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
OKI C5100n Laser Printer Logo
816 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
