Question about Sony PlayStation Portable (PSP) Console
My "select" Button will not work
Everything works on my PSP but the select button. I haven't dropped my PSP once and this is the only thing on the PSP that doesn't seem to want to work. I can't play Midnight Club LA Edition on my PSP and I just got the game.
  • 579 Answers
The entire row of buttons on the bottom are on the same strip under the cover. This strip plugs into the power board and it can be checked out with a continuity tester, just look for the 2 pins that show cont when the pad is pushed on the strip. You can get new strips on the internet for a few bucks. Easy to replace if you can get the cover off, just 6 screws but youll void any warranty you may have on it as 2 of the screws are under a tamper proof sticker in the battery compartment.
Posted on Dec 01, 2008
X triangle square circle button not responding everything else works my brother said he dropped but im sure he did more than that (so i am not really sure what happen ) help please --i cleaned the buttons...
That means the button pad connector might be disconnected to the main board inside that PSP.
Better bring it to your technician to check on it. To access that area your PSP will be open up, the connector is behind the LCD screen.
Hope FixYa helps you out!
Aug 15, 2011 | Sony PlayStation Portable (PSP) Slim...
My son dropped his psp at the barbershop he says the only thing it does know is play music.
  1. I would try removing the battery for a full minute and then reinsert the battery and light reset it.
  2. Should that not work I would try a different game and see how that responds, maybe the game itself might have suffered damage.
  3. If that reset does not work then a hard factory reset can be tried. This will erase all stats and everything and restore it to new out of the box status. Save any data on a USB drive before doing this if you want to keep it. The steps for this are -
  • Power off the game for at least 5 seconds.
  • Now hold down these buttons "select,start, the "square" button, and the "triangle" button all at the same time and then start the PSP up (while still holding them 4 buttons down.
  • At this time the screen will be black for a few seconds while it resets. This is normal, wait for the PSP to light up.
  • When the PSP lights up the hard reset has been performed.
If non of this helps the PSP come to normal then I recommend contacting Sony as it would be possible, at this point, that the PSP has suffered internal damage.
Regards, Tony
May 01, 2011 | Sony Video Game Consoles & Games
How do you fix the select button on a psp
how do you knw that the select button is not working?in most psp games the select button has no function even in the xmb menu there is no function for it.maybe youor select button is stil good.
Mar 08, 2010 | Sony PlayStation Portable (PSP) Console
Ok,I dropped my PSP and evertime I turn it on,it goes to the "Sony Entertainment"thing,then goes to the moving wave background and stays that way.I have to remove the battery to turn it off.
Pull out the battery again and before you put it back on press and hold the select button. While holding the select button, go ahead and turn it on. Still hold the select button say 45 seconds after switching on.
Regards
Feb 24, 2010 | Sony PSP (Piano Black)
The middle button does not work. i cannot select anything. everything else works perfectly fine. i have a case and never dropped it once. please help thank you thank you.
Try resetting the iPod. To do this, turn on the iPod and hold down the middle (select) button and the play button at the same time. Hold buttons down until the screen turns off then back on. NOTE: This will NOT delete your iPod content.
Dec 28, 2009 | Apple iPod classic MP3 Player
Select Button Seems To Be Jammed Through Software
downgrade your psp if u can do it yourself ...... if not then try upgrading it again
Aug 28, 2009 | Video Game Consoles & Games
On my psp, everything seems fine except that when I put in a UMD disk to play a game, nothing happens! It's not the disk as this works on another psp. The problem started after I downloaded the latest...
turn on ur psp press the select button and then select reset device it will bring the default setting of your PSP
now chek if still UMD doesnot open then ur new firm ware is corrupt and try reinstaling the firmware from the sony website www.us.playstation.com/PSP/Downloads/systemupdate
update after u reset the device once
Jul 03, 2009 | Sony PlayStation Portable (PSP) Console
PSP start button and select button not work
  1. Connect the PSP to your PC with a USB cable. (about $10: buy a USB cable for your PSP)
  2. Press the "home" button on the PSP (it's a tiny button to the lower left of the screen) then use the left-right directional buttons to find "Settings", then the up-down buttons to find "USB Connection" on the PSP.
  3. Press the "X" button (you got it, the round button with the "X" on it) and your PSP should display "USB Connection".
  4. In a moment or two your computer should tell you that a new USB device has been connected, then show you a new generic hard drive, usually E: or F:
  5. Click on the drive letter that corresponds to the PSP unit.
  6. Now create a new folder on that drive and name it "psp".
  7. Within the new "psp" folder create another folder, and name it "music".
  8. Copy your desired mp3 files into the new "music" folder.
  9. When you're done copying your desired music tracks, press the "O" button on the PSP to get out of USB connect mode.
Jul 16, 2008 | Sony PlayStation Portable (PSP) Console
My R button is my hold button
Acutally is not like R=hold, the fact is, your R button is more likely to be semi-automatic or fully automatic now. Even on a fully working psp, when you press select or home button while you holding the L button or R button, the same thing will appear as your own psp.
Let you know a temporary solution, hold the R or L button or both firmly for a minute, your psp might come back to normal for a few seconds or something.
Look for some professional repair service to get your L or R repaired.
Let me know if this works.
Dec 23, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
