Home | Philips | 51PW9363 51 in. Rear Projection HDT... | Phillips model 51p...
Philips 51PW9363 51 in. Rear Projection HDTV-Ready Television
Problem for Philips 51PW9363 51 in. Rear Projection HDTV-Ready...
Phillips model 51pw9363 Convergence Problem
By theatch on Nov 30, 2008
I have a convergence problem with my phillips model 51pw9363 51 in projection tv. Can someone tell me 1. Are these things something I can do myself? 2. What are the item numbers I need to order? and 3.Will I need other items than just the convergence IC units?
Same Problem
Mar 21, 2009
-   We have replaced both ic chips but the red one is shot again. How do we know which ic chip controls the red or do we have to replace both again?-   jdsdn
Feb 10, 2009
-   I have the same exact problem as the original poster. -   JimFa
Best Solution
posted on Feb 12, 2009
Very Helpful)
Ecollier2012
Rank: Guru  Philips Expert
Rating: 93%, 540 votes
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #2
posted on Jan 13, 2009
Helpful)
daniel719
Rank: Wiz
Rating: 83%, 143 votes
lets see.
you have an up grade for this unit.
replace original ICs with STK 392-120
if you can soldier and clean heat sink of and replace heat sink you can replace thes parts no problem.
serch for them on line cost is from 14$ to 30 each.
hope this helps you
and please give me a godd rating for this advice.
i pay $160 a month for my info and this sigt pays nothing.
thanks.
daniel.
Was this helpful?
Yes
No
11 people thought this was helpful
Solution #3
posted on Jun 29, 2009
Not Rated)
owkosf
Rank: Apprentice
Rating: 75%, 2 votes
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Was this helpful?
Yes
No
Popular Solutions for Philips 51PW9363 51 in. Rear
Questions and Unsolved Problems for Philips 51PW9363 51 in. Rear
Do you recommend Philips 51PW9363 51 in. Rear Projection HDTV-Ready Television?
Answer
Answer
I have a Philips rear projection tv and when I had turned off the tv then turned it back on there... (More)
Answer
i have a popping sound coming from one of the projector
Answer
The wiggly lines are across the screen...not like the pictures you displayed in the convergence... (More)
Answer
The screen is black when we turn the tv on but there is sound, what should i do to get it fixed is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 51PW9363 51 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
