Question about Maytag Neptune FAV6800AW Top Load Washer
Neptune TL Console Issues
We purchased a Neptune TL washer in 04. We have had issues leading up to the washer completly stopped working now. The diagnosis is that there is a key stuck on the control/option board. We had a tech come take a look and confirm which parts were needed.
I called Wirlpool, and they sent me the peice (led/computer chip) free of charge.. I took the part apart and tried to install it except the last cables that I tried to connect dont fit the new chip.. uuhg.
So in otherwords they sent me the wrong $200 part ten days later.. Is there anyway to disassemble the key pad and try and unstick the keys? Or do I need a new shell?
    Sergeant:
    Champion:
  • 311 Answers
You were apparently sent the wrong part; the serial# is important when ordering these parts. You need to repl the failed part- which I assume is the membrane switch, not the actual machine control. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
Fav6800aww control board and/or keypad gone haywire (for lack of a more technical term) would like to replace quickly and as inexpensively as possible. Note: this is the 2nd time down this road since...
Yep need to put surge suppressor on the Washer 120VAC service outlet. Wonder if you may have grounding issues at the mains. Are you in the country?
Try e-bay for both the Control Board and Console.
P/N for the Control board is 25001001 or 25001217R
Could be a Console issue or something pulling down + 12VDC on the Control Board like corrision issues at the TDS.
Go here if you want to treoubleshoot for free Google ""Neptune TL Washer FAV6800AWW"" post in the Maytag washer forum.
Or maybe someone on this forum can help.
Sep 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Code of od on washer
The Control Board has not see a Washer Lid Open for 3 completed machine cycles.
If you want to DIY this is not the best forum. Google
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky. I have troubleshooting support in that sticky for the FAV6800A and FAV9800A. I speak to troubleshooting the Left Hand Lid lock issues causing the OD error code as well as OP and FL.
Aug 23, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Fav6800aww machine wont stay balanced move the clothes around it starts back up for about one minute then stops code comes up dc thanks earl
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
In that Sticky I discuss what is the cause of DC or UC unbalance errors and the fix.
Apr 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune TL ( purchased in 2005) is grinding during the wash cycle only. Spin cycle is quiet. Once the entire wash/rinse spin completed I opened the washer to retrieve the load and found a piece...
Jose,
I'm an owner of three FAV6800A machines and I'll respond to help because you want to roll up your sleeves and try to save your $1K machine.
1st No direct links Google this Neptune TL Washer FAV6800AWW
Post in that forum your machine Model which I assume is an FAV6800A (LED Console) or FAV9800A (LCD Console)
Include the first two digits of you machines model number. That is the series of your machine.
Give a description of the issue as you did here. I hope the grinding is during wash/agitate if so it may be something as simple as tumbler removal to clear out debris. If the grinding is in Spin Cycle it could be a bit more work like Outer Tub bearing failure.
The Forum in my opinion is geared more toward the DIY owner as I am and as you sound. The forum is free like this and my support is free..........Good Luck D*ick
Mar 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
GETTING DC ERROR CODE WITH A GRINDING SOUND AND THEN IT STOPS COMPLETELY
The DC error code is 9 time out of 10 caused by a Clutch Pulley malfunction. The grinding may ne Outer Tub Bearings but need more info. Open the Washer Lid. Spin the wash basket CCW. Do you hear and grinding noise?
The noise may be coming from under neath the tumblers. Further troubleshooting is required.
Do you have basic DIY mech. skills and do you want to save your $1K machine?
If so Google Neptune TL Washer FAV6800AWW
Good luck.
Mar 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine makes a grinding noise when it is spinning. It drains alright and seems to work ok, but I`m afraid the grinding noise could lead to bigger problems.
Stone,
All owners are heading toward this issue. I feel your FAV6800A or FAV9800A is at the end of service lifew for the Tub Seal
If you open the washer lid and spin the Washer CCW and hear the noise (Outer Tub Bearing noise) then it's time to role up your sleeves.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800A top load machine.
Google this FAV6800A/FAV9800A Outer Tub bearing replacement to see what is involved in doing an Outer Tub Rebuild.
Good Luck
Mar 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Constantly stops with code "DC" even with very
Do you want to DIY the fix?
This is a DIY Appliance repair forum no cost and you can get the Service Manual from this site.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine. At that post I discuss what cause is and the fix.
In that Sticky are other what I find to be common Service Repair notes for issues with the machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air f
Mar 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL washing machine, it runs almost all the way through they cycle but on the last spin cycle it stops and the digital display shows LO. Can you help me?
LO error code:
Locked: Lid has failed to unlock -
the machine has repeatedly tried to
unlock the lid. Push lid closed to
make sure nothing from the inside is
pressing against the lid, preventing
unlocking.
Is that the issue? Have the Lid locks failed to release and you can't open the Lid?
Or have the Lid Locks released so you can open the washer lid but the error code LO remains?
If you want to DIY I will help you.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help. No cost to you for the support..........D*ick
Mar 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer Neptune TL error message: dc stops during spin cycle; leaves water in tub
See my post Clutch Fix but I recommend you go to real DIY forum.
I can't find most of my repair post in this forum. This forum to me is a "Call In a repair tech forum" for this model and that is OK if you can't do basic DIY repairs.
I don't want to put in a direct link to the washer repair forum of my choice so put in your browser this phrase;
Appliance Repair Forums > Appliance Repair Talk > Washers > Maytag/Magic Chef/Admiral/Jenn-Air
This is a true DIY Appliance repair forum.
If you need help open a post in that repair forum and I will try help you through your issue.
Feb 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag will not run a complete cycle. Is there
mgissy
What is your machine model number? Is it a FAV6800A or FAV9800A TL?
If it’s a FAV6800A or FAV9800A TL do you error out in the Spin cycle of the wash cycle with an unbalance error code such as dC or uC? Is the wsh tub banging around during Spin Cycle of the Wash Cycle?
If so see this post Clutch Fix. I have a step by step maintenance/repair process for Clutch Pulley assembly issues related to the above error codes.
Post back if you have questions or concerns………Rich
May 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
