I have a advent 5311 laptop and i need to know if you can upgrade the ram memory as it only has 1gb can i install a 2gb if so which one do i need to buy?
  • harryb65 Nov 30, 2008
    only 1 ram slot can i put a 2gb chip in there?
  • 52 Answers
The problem listed under Desktop PC, and seems that you have laptop,
please check the back side of your laptop you will see a small cover with screw, check under it if your ram 2 chips or one, and there are a space for other one.
Posted on Nov 30, 2008
How to replace RAM in Satellite M45-S165
http://www.irisvista.com/tech/laptops/ToshibaM45/Satellite_M45_disassembly_1.htm
You can click on any photo to enlarge it.
Step 3 photo shows the Memory Compartment.
Two ram memory (SO-DIMM) can be used. There are two ram memory slots.
1GB however, IS the largest amount for EACH slot.
Regards,
joecoolvette
Apr 14, 2012 | Toshiba Satellite M45-S165 Notebook
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
Samsung n150 plus is expandable to how many memory?
The Samsung N150 Laptop comes installed with 1GB of Memory and can be upgraded to a maximum of 2GB Memory. This computer has 1 (one) SO-DIMM memory slot, so to upgrade to 2GB of RAM, you will need to replace the installed RAM module with a single 2GB PC2-5300 DDR2-667 200pin SDRAM SO-DIMM memory module.
If you find this solution helpful, please leave a positive rating!
Jun 21, 2011 | Samsung N150 Notebook
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
I an looking for a memory stick for an Advent laptop 5311 2GB memory stick can you help please
There are lots of companies who sell this and it is very easy to replace on your laptop too. I would suggest www.ebuyer.com for cheap prices. You need to go into laptop memory section and search for 2GB DDR2 SODIMM memory
May 24, 2010 | Advent Netbook
Having upgraded to 2gb ram on advent 5421 laptop, machine will not boot up with 2gb or re-installed 1gb.
Just make sure it is an original ram and it must also be the right one. Of course it should boot with 2GB. Also insert the ram properply.
Mar 09, 2010 | Computers & Internet
I have a ACEer 5315 model no ICL50 running Windows Vista. To say Vista is **** is an understatement. I want to switch to Windows 7 but guess I will need a lot more RAM for this. Can I upgrade Ram on this...
I recommend that you switch to Windows 7 without upgrading your RAM. Windows 7 is a lot faster, better and uses less RAM than Vista. Recommended RAM for running Windows 7 is 1GB but I have installed them on a Centrino 1.5GHz with 768Mb of RAM and they run perfectly.
So make the upgrade to Windows 7 anyway and if you feel that you need more power then you can get more RAM.
Also, download Windows 7 upgrade advisor to check if your pc is compatible. Download upgrade advisor here.
Feb 06, 2010 | Acer Aspire 5315 Notebook
Laptop memory upgrade
Your Laptop is using DDR2 Memory, just find your nearest retailer that sells memory and go buy you a chip, ur laptop ships with 1024mb of ram as standard, if you want to get a decent boost pretty cheap then i would just buy another 1gig chip and put it in beside the one already there.
Not sure what your system maxes out at but the average is 4gig of ram so you could try a couple of 2 gig chips if you feel you need that much ram
Aug 22, 2008 | Computers & Internet
What kind of ram?
just look for notebook memory type ddr2, ddr2 all have the same amout of pins, you will have to remove one of the sticks of ram and replace with a 1GB or remove both and fit 2 x 1GB sticks.
seee below
http://www.ebuyer.com/store/Components/cat/Memory---Laptop
Nov 23, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
427 people viewed this question
David Payne
David Payne
