Question about Home
Low pressure from the undersink osmosis filtration system
I have an undersink water osmosis system. I have always had low water pressure. On a good day I can get 3 to 4 cups before the pressure dwindles to a trickle. Presently I can barely get a haf cup before it slows down and takes forever. Someone said I need to use a pump to increase pressure in tank. I changed my filters earlier this year, but never changed the 'bladder'. I know this may need replacing now, but is this the problem or do i need to pump up the pressure and if so how. Note I have never really had lots of water pressure but it was alwyas fairly reasonable. Thanks for any suggestions.
  • James Feragola
    James Feragola May 11, 2010
    There are several things that need to be answered before we can get to the low pressure question.
    On your well tank there should be a gauge that should show you the water pressure. Often the gauge can be stuck so you may need to tap the top of it and see if the needle moves at all, record the pressure that is shown.
    Next, open a faucet in the house, doesn't matter which, and return to your well tank. You should see your pressure drop down and then the well pump should activate and the pressure will go back up. The time that elapses will depend on how large the tank itself is but should not be more than a few minutes. Keep an eye on your pressure gauge during this time and record the pressure that your pressure switch activated the pump. If the gauge is not working properly, it may not move at all and will need to be replaced.
    A few questions here, when you pump activated, what was the elapsed time that it was on while it was filling the tank?
    Did it run for 15 seconds or more or did it run for a few seconds and shut off and then start up several seconds later and run for a few seconds and shut off?
    If it ran for a few seconds and shut off only to start a few seconds later, your well tank may have a faulty air bladder. This condition causes the well pump to "Short Cycle" and will result in accelerated wear on the pump itself. Your well tank will need to be replaced. If this is not the case, lets move on to a few more diagnostic questions.
    Does your pump activate when there is no water running in the house? If it does, the check valve on the inlet line may be faulty.
    Finally, what was the pressure that your pump activated initially, and then what was the pressure that it shut off? This is assuming that the pressure gauge is working.
    If the gauge is faulty and you cannot see the pressure and you tank is not "Short cycling" it may be that your pressure switch may need to be adjusted or replaced.
  • 145 Answers
A pump will help you
Posted on Dec 12, 2008
I have a water well, do I need water filtration system?
NGWA (National Ground Water Association) recommends testing well water for nitrates, bacteria, and any local concern contaminants. Well water testing should be considered additionally if there is a change in the water odor, taste, or appearance, family members have recurrent incidents of gastrointestinal illness. You should check with your local department for recommendations and interpreting your water tests - Well Water Filtration System
Jun 15, 2018 | Water Water Heaters
Ge smartwater filtration system has slow moving water
You have to prime air out of new filters. Also if you have a reverse osmosis water system, your water pressure may not be sufficient.
You may have to bypass the filter. Most fridges come with a plug that will fit where the filter goes. good luck
Dec 27, 2013 | GE GXRLQR GE SmartWater Inline Filter...
How does a water purifier work?
A water purifier works through the process of reverse osmosis. Water purifiers cleanse water by passing it through a series of filters. This helps remove large amounts of contaminants and other harmful chemicals
Jul 09, 2012 | Camping, Backpacking & Hiking
I have a 3 filter undersink system that says Reverse Osmosis on the tank. It is a 2 1/2 gal. tank and i get , maybe 2 qts out of it now. I have been replacing the filters as instructed.
The storage tank probably has low air pressure. On a 3 gallon RO tank empty the tank completely of water and adjust tank pressure to 7psi.
RJ
Apr 22, 2011 | Culligan Under Sink Water Filter
How do i unhook the spigot from my undersink reverse osmosis system i cant get the hose connections to release so that i can take the spigot off the sink. i am putting in a new sink
If they are quick connect fittings make sure all the water pressure is off the lines. Turn off the RO tank and valve feeding system, open the faucet and try taking lines off again. If no luck, mark the lines with masking tape and cut them a couple inches below faucet to remove.
RJ
Oct 24, 2010 | Culligan Under Sink Water Filter
Water pressure gets very low . GE GNWH38F FILTRATION SYSTEM. HELP !
This generally indicates the outlet manifold on softener is partially plugged. This needs to be removed and either cleaned or replaced.
RJ
Sep 17, 2010 | General Electric GE SmartWater Household...
Find water demineraliser for use in a steam iron
Any undersink reverse osmosis system will give you the low tds high quality water needed for the steamer. Make sure the ro system does not have a mineral cartridge to add back calcium that it removes from water.
Feb 26, 2010 | Sunbeam Irons
Water leak from front door water supply
IF YOU HAVE IT HOOKED TO A REVERSE OSMOSIS WATER FILTRATION SYSTEM, YOU SHOULD REMOVE THE FILTER CARTRIDGE AND OBTAIN A BYPASS PLUG. IF NO RO UNIT, YOUR WATER VALVE IS MORE THAN LIKELY THE CAUSE. BEFROE CONDEMNING IT THOUGH, MAKE SURE YOU HAVE GOOD WATER SUPPLY AND PRESSURE TO THE REFRIGERATOR AS THE VALVES RELY ON WATER PRESSURE TO SHUT OFF AND SEAL.
Jan 27, 2009 | Frigidaire Refrigerators
ICE MAKER NOT WORKING CORRECTLY
Hello deloreslovat
welcome,
You said ,your ice maker makes the ice but does not drop it into the bucket. It just leave it in the upright position in the ice maker device. It also seems to not be making all of the ice cubes only a portion of them.
Here are somethings to check that may cause this
The ice cubes are hollow or small
NOTE: This is an indication of low water pressure.
Water shutoff valve not fully open? Turn the water shutoff
valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
See “Water Supply Requirements.”
 Questions remain regarding water pressure? Call a
licensed, qualified plumber.
Let me know if this helps.
Huuum
Oct 13, 2008 | Whirlpool GS6NBEXR Side by Side...
Home Logo
401 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
