Question about InFocus SC-MANGRY-106H MANUAL PULL DOWN
INFO TO SET UP GE MODEL 27GT630
I DO NOT HAVE A MANUAL
MY GE GUIDE PLUS REMOTE DOES NOT WORK EVEN AFTER I CHANGED THE TWO AAA BATTERIES
I HAVE BEE USING THE STANDARD GE REMOTE FINE OVER THE PAST FIVE YEARS
SOME HOW AFTER I TURNED OFF THE TV YESTERDAY I AM UNABLE TO RETUN IT BACK TO THE CHANNELS
I FOLLOWED THE SET UP DIRECTLY ON THE TV AS THIS IS THE ONLY WAY I COULD FOLLOW AN DENTER THE PROMPTS
WHEN I DID THE AUTO CHANNEL SEARCH AFTER THE SET UP THE FEED BACK PROMPT SAID "NO CHNNELS SELECTED"
INFO ENTERED
ENGLISH
LOCATION CANADA
POSTAL CODE T9K 2G9
CABLE YES
CABLE BOX NO
VCR NO
I DO NOT HAVE MANAL
THANKS
Chunghop E-T908 Does anyone have clear instructions on programming this remote for a TCL HD TV?
Denis, google search instructions for remote, make and model # instructions. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Program an RCA Universal Remote Using Manual Code Search
GE Universal Remote Codes
How to set up universal remote
universal remote instructions Google Search
Jul 19, 2016 | Televison & Video
I want to re-program a GE Universal Remote (with Guide Plus). Lost the manual. Also do not have a "code search" or "set-up" button on remote. What do I do?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 08, 2014 | GE Televison & Video
Remote won't stop lighting up, even with fresh batteries
Check the remote control for its infrared emission. If you wish to get more details about how to check a remote control, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
I have a RCA guide plus gemstar t.v.I have lost the remote.to set up the guide plus in a new area I need to change the zip code.Its a 2003 model 36F53OT.where can I order one or an alternative solution.
you can access guide plus from front panel switches. press menu and select no. 7 or 8 guide plus setup. it asks for zip code type in using another remote using keypad.
Sep 17, 2011 | RCA 36F530T 36" TV
My Model RCV1T-27 remote will go through a set of AAA batteries in 2 weeks. We only use the remote in the evening and then only to turn on the system and set the volume. All the channel changine is done...
If I am lucky, I get 3 days with a brand new set of batteries. Actually, I rarely ever use my system for that very reason. the irony is i chose this model based on the radio frequency feature. . .what a fiasco.
Apr 03, 2011 | Bose 35504 Remote Control
I need the manual, thank
Hello
I've the manual of GE 27GT630 and GE27GT716 with me. Most of the GE & RCA manuals are the same,except in their model numbers. If you want to get it, send me your email address to me, as i cant upload more than 50Kb through this site. Ok
gopakumarg43@ymail.com
Dec 19, 2010 | GE 27GT277 27" TV
How do I remove the guide plus from coming on at power up?
I found the solution!
With the remote, press the Guide button. This should bring up the Guide Plus+ screen. Press the right arrow to move the cursor all the way to set up and it will ask, "What would you like to do?" Arrow down to "Review Options" and press OK.
The first question is, "Guide Plus+ System Auto Display? On / Off"
Arrow down to Off and press OK.
Jan 01, 2009 | GE 32GT740 32" TV
GE 31GT740 TV problem
hit the clear button on the remote and it will clear the guide plus off the screen
Jul 09, 2008 | GE 31GT740 31" TV
Tv code
I HAVE A YEAR 2003 GE TV
MODEL 27GT630
THE MANUFAFACTURERE WAS THOMPSON LTD
I LOST MY SET UP MANUAL
I HAVE A CABLE
MY GUIDE PLUS REMOTE REFUSES TO WORK AS WHEN I PRESS A KEY THE LIGHT ON THE REMOTE DOES NOT GO ON
I HAVE BEEN USING A REGULAR GE REMOTE AND IT WORKED GREAT
SOME HOW WHEN I TURNED IT OFF YESTERDAY I AM UNABLE TO GET BACK THE TV STATIIONS
I HAVE BEEN FOLLOWING THE SET UP GUIDE ON THE TV
LOCATION CANADA
AREA CODE T9K 2G9
CABLE YES
VCR NO
WHEN I PUT ON THE AUTO CHANNEL SEARCH IT GOES THROUGH THE SETTINGS AND THEN SAYS "NO CHANNELS SELECTED"
IT IS A BEAUTIFUL TV AND I DONT WANT TO DITCH IT
HELP ME
May 13, 2008 | Televison & Video
Televison & Video Logo
77 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
