Question about Gateway Computers & Internet
Error message: Windows cannot initialize the device driver for this hardware. (Code 37) *** My disk drive disappears or won't read any disk
    Scholar:
  • 135 Answers
The error means the the driver is not compatible for you Hardware.
you will need to get update driver from net for your device.
To bring back you icons Do the following
Right click on my computer at desktop
select Manage
an application will open
select "disk management" in storage tree menu
you will now see you hard drives in application
Right click on each drive and change the drive letter except you windows drive.
Restart you computer your dives will come back.
Hope this will solve you problem.
Posted on Nov 30, 2008
    Guru:
  • 97 Answers
Your driver may be corrupt so you can try re-installing the drivers for your drive. If you don't already have the drivers then you can download it from you device manufacturers website.
Thanks
Windows cannot initialize the driver for this hardware code 37
Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 37 error, especially if the error is showing up on a device other than a BD/DVD/CD drive.
Important: If a USB device is generating the Code 37 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Note: Correctly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Apr 20, 2013 | Dell Inspiron Computers & Internet
Code 37 error
Try to disconnect the wirless kb & mouse then uninstall completely. Likewise remove all entries of the Logitech wireless kb & mouse in your registry. Reboot your PC and do a complete Disk Cleanup. In your Device Manager, verify that it no longer shows even under the "Show Hidden Devices". Reboot again and reinstall.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 18, 2008 | Computers & Internet
Windows cannot initialize the device driver for this hardware. (Code 37) HDPVR
It means there is a problem with the device driver for the hdpvr. Try uninstalling the drivers, rebooting and then reinstalling the driver for it.
In some cases it can also mean a registry problem, where removing the UpperFilter/LowerFilter entries can help:
http://pcsupport.about.com/od/driverssupport/ht/upperfilters-lowerfilters.htm
Feb 08, 2013 | Hauppauge 1212 Hd Pvr High Definition...
Code 37 on dvd drive
The Code 37 error may occur when the concerned device is not connected to the system correctly and when its driver is faulty. A code 10 error is common when you add or remove USB devices or video & sound cards to and from your PC. When these errors occur, you may receive the error message given below.
To resolve code 37 errors, first ensure that your device is properly connected to your system. For instance, check all the cables of your printer or check that your sound or video adaptor is properly seated in its slot.
Try to remove and reinstall the device, and run the Add New Hardware Wizard from the Control Panel to see if Windows detects and installs it. If this does not resolve the issue, then update the device driver by performing the following steps:
1. Open Control Panel and select System.
2. In the System Properties dialog box, select Hardware tab, and then click on the Device Manager tab.
3. Scroll down the Device Manager window and identify the faulty hardware from the list.
4. Right-click on the hardware and select Update Driver.
5. Follow the screen instructions to resolve the error.
If these steps do not resolve your error, then the problem might be with your device. Get it checked by an authorized technician.
Aug 04, 2009 | Dell DVD-rom DVD Drive
Error code 37
Hi there
Good luck
Jan 14, 2009 | Computers & Internet
I have a gateway M-6841 s/n N3F8481009154 LAPTOP COMPUTER WHICH SAYS CODE 37 for the CD-ROM. Windows cannot initialize he device driver for this hardware.
From the microsoft support page, it suggests to uninstall the driver and and click on scan for hardware changes to re-install or upgrade the driver. Here is the page:
Code 37
Windows cannot initialize the device driver for this hardware. (Code 37) Recommended resolution
The driver returned failure from its DriverEntry routine. Uninstall the driver, and then click Scan for hardware changes to reinstall or upgrade the driver.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Hope this helps,
Good Luck
Jul 21, 2008 | Gateway Computers & Internet
Problem loading win XP-SP2
Don;t know if this is the cause of u're errors, but it might be do to the motherboard chipset drivers (the lack of them in u're windows version). If so, u have to make a copy of u're windows cd with all u're motherboard drivers included, and try to install with that cd. The same problem appears to all new laptops that do not offer XP support and only Vista support . In order to do the new XP cd, u\ll need a little program that u'l find on internet..... (for example: n-lite)
Jan 18, 2008 | ASUS A8N-SLI Deluxe Motherboard
Computers & Internet Logo
73 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
