Question about KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range
1995 KitchenAid duel fuel KDDT207B error message F-1
Bought new in 1995, we have had just a few minor problems with this range. However,while baking now it is displaying an error message, F-1 and only tells us to call for Service.
I am pretty handy and curious can you help determine the source of this message and repair needed? Could I perform the repair myself?
5 Suggested Answers
SOURCE: Kitchenaid glass top electric range
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
Posted on Mar 06, 2008
SOURCE: Error F7:E0 on Kitchenaid range
http://servicetechhelp.com/Docs/2603.html
Posted on Sep 14, 2008
  • 126 Answers
SOURCE: kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Posted on Jan 02, 2009
SOURCE: I'm looking at a KitchenAide KDDT207B duel-fuel
I have this same oven. It began to intermittently fail when using the oven. The error code suggested it was a problem with the keypad. I suspected it was because the electronics was overheating. The electronics for this model is approximately underneath the right front gas top range. What I found was that the failure occured when both the oven and the right front gas range were being used simultaneously. This caused overheating since the electronics has not fan in this model and the heat radiating down from the pan above the gas range is added to the heat coming from the oven below. The electronics is sandwiched between these two heat sources.
Posted on Apr 03, 2010
Error code FO5...oven dead
Duel fuel? Which one does the self-cleaning? I'd bet electric. If so, the gas mode must not be used, and it may be telling you that.
Apr 10, 2015 | KitchenAid KDRP407HSS Dual Fuel (Electric...
My kitchenaid range touch pad won't work- no errors displayed, can't turn oven on
careful here. The board needs to be replaced and can cost as much as $300 to $500. Half the cost of a new range. They also have been known to turn on the cleaning mode when baking. Then the oven door locks and cannot get in. Then what ever you have in the oven really gets black and starts a fire. This happened to me a while back. Had to shut off the range breaker and wait til the oven cooled of to open door. Really smelled. Had to buy a new oven because we could not get the burned smell out. I would suggest not to use the oven til new board is installed. Or buy new oven. We bought a AQUALIFT clean oven. It cleans at 250 degrees. Not the high temp of 500 degrees plus.
Dec 31, 2014 | KitchenAid Kitchen Ranges
Wolf gourmet gas range/oven 36"--oven lights and
is this a duel fuel unit if so the the electric bake element is open
Sep 19, 2011 | Wolf Range KFS-0-27-SCB-36 Gas Kitchen...
Kitchen Aid dual fuel oven, getting an error message F 02
F2
Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this
happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN
models: check door lock operation.
3. Look for a high resistance connection
or any other cause of high resistance in the oven temperature sensor circuit.
Check sensor, sensor harness and sensor harness connection at sensor and oven
control. Replace sensor if found defective.
Remember: Oven control
(ERC) measures resistance of sensor circuit, not actual oven
temperature.
Jan 02, 2011 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Seimans HD 2515 Oven stopped working
I have this same problem. Any resolution on the others' problem?
Mar 11, 2010 | Siemens HD2515U Stainless Steel Dual Fuel...
Hi ,I have model jgs8850ads,it takes along time to preheat,about 40 min. what could this be? please respond.
is this a duel fuel with an electric oven..... the bake is the bottom and the broil is the top both cycle on and off to preheat the oven.... if ur lower bake element is burnt out then u woould expereicnce the problem u stated..... if u have a gas oven then ur ignitor or glow bar is probably burnt out....... either way it sounds like your bake element or bake ignitor has failed
Jan 31, 2010 | Jenn-Air JGS8850ADS Gas Kitchen Range
I'm looking at a KitchenAide KDDT207B duel-fuel used stove to purchase used from a private party I don't know. Are there reliability concerns?
Nov 16, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
1991 KDDT207B
You can buy one at kitchenaid. Here is there 800 #. 800-541-6390
Or you can call this # for partselectlogo.gif 1-888-895-1535
Good Luck and Please Rate FixYa!
Jan 08, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Kitchen Aid KESA907 Error F2E0 Stuck Key
Turn off the breaker and wait for 5 minutes. the follow these steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Apr 24, 2008 | Whirlpool GERC4110PS Kitchen Range
E1 and f5 error/Door locked
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Dec 22, 2007 | KitchenAid KEBC207 Electric Double Oven
KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range Logo
120 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
