My Sony STR-DE575 receiver has lost most output in the right front and left surround channels. I have tested all channels with the same speaker and the problem occurs consistently. I have opened up the device and removed the main board looking for obvious issues and checked resistence between a few components, but nothing obvious jumps out.
  • 3 more comments
  • mklumpen Dec 01, 2008
    I did look for obvious burned components or bulging capacitors. I can look more closely at the capacitors this evening. Apart from the buzzing sound I get when I try to use the tuner, the problem is with the low output from 2 of the channels, so I was focusing on what appeared to be the channel specific components.
    There are 10 components (presumably 2 per channel) that I was looking at in particular. Not sure if these are MOSFET or something else. They looked ok, but I wasn't sure how to test. I did test the resistance between all of their terminals and it was consistent. Other possibility I was considering was bad soldering contacts. I repaired my Sony 32" CRT tv a couple of times by resouldering several components.
  • mklumpen Dec 02, 2008
    Double checked and did not find any bulging capacitors.
    I found the following post which mentions some of the components I checked, but they all seemed to have similar resistance measure between their terminals:
    http://www.fixya.com/support/t29795-sony...
  • mklumpen Dec 03, 2008
    Any advice on specific areas that I should investigate?
    How can I see a previously proposed solution? I accidentally re-posted my problem this morning before I had seen that a new solution had been proposed. It contained information about components form the receiver's service manual.
  • mklumpen Dec 05, 2008
    Thanks for the solution. I don't have the service manual, but I did find the parts listed. Although I am not entirely sure how to test these components, I did check the resistance between all terminals and they appeared to be the same as the other working components. I did a factory reset, which did not help, so I re-soldered all of the suspect components and still no change. In my testing I discovered that the left channel, although working, has lower output than the center and left surround channel, so it appears to have problems as well.
    I have spent about as much time on this as I willing to, so am now shopping for a new receiver.
    Thanks.
    Genius:
  • 1,239 Answers
Hi it is better to solder the circuit connections and check whether there is any loose connection within the right speaker..if any burned particles found better to change it............ thank you
Posted on Dec 03, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 05, 2008
    hi did you seen my anwer,,i think it was the actuall problem
  • ABHISHEK.C
    Sounds to me like you have not got the cener speaker working properly. Try another surround mode, then check the speaker by switching it with another known good one just to make sure i the problem is the speaker or the receiver. You can also do the speaker test and make sure the center speaker is set to be turned on in the menu settings.
    Here is a link to the owners/operation manual and you can find any information you need to check your receiver out. If you never are able to get it working, you need to take it to a service center to be checked out.
    Get your manual free here:
    http://books.jvcservice.com/booklist.asp...
    A "FixYa!" rating would be appreciated, and let me know if you need any more help,
  • 10,594 Answers
Please obtain service manual of STR-DE575 and check out put amp area in receiver.
Posted on Dec 01, 2008
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Dec 02, 2008
    Let me know do you have service manual of STR-DE575 as shown below...
    Suspected parts could be Q751-752-753-754 for Right Front amp section and..
    Q651-652-653-654 in Left Surround amp section.
    I would also recommend to perform Factory Reset mode before any part testing / replacement.
    Factory Reset procedure is as follows...
    While pressing "Video" and "2CH" button, press "Power/ Standby" button. unit will go to standby, repeat the same procedure and unit will select factory Default Settings.
    Let me know if you need further info.
    Good Luck.
    Shahid Electronics Dec 03, 2008
    Did you received my previous suggestions?
    I think it was my solution contains info from service manual..right?
    Shahid Electronics Dec 05, 2008
    You can have service manual from Manual Zone and can check / test rest of circuit / parts.
    How about rating information given to you?
    Sergeant:
  • 217 Answers
Any thing looks burnrd out in the boaRD or the capacitors got leaked or buldged up check out this.
Sony STR-DE575 5.1 Channels Receiver I have power to everything but I am getting ZERO sound. Is this something that is fixable or do I just need to replace my receiver?
Have you looked in the manual? Basic speaker setup with test tones will certify the basic hardware. Then onboard FM. Then add the compexity of external and digital sources.
Aug 26, 2011 | Sony STR-DE575 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
When trying to watch a dvd through a blu ray player, the background sound is coming in loud and clear, however when the main actors talk, their voices are not coming through.
If you don't have a center channel you will experience this problem. The center channel is where all dialog is sent to. To fix it, you need the set the receiver to phantom center. Go into the setup menu into speaker setup and tell the receiver that you dont have a center channel installed. Once you do that, it will send dialog the the front left and right speakers.
Good Luck
Jan 07, 2011 | Sony STR-DE575 Receiver
Sony STR-DE875 receiver has no sound from right channel front or back. Checked for loose connections & blew out dust, no change
Hy all. I bought a receiver at last week. But the front speakers not working. The rele is jumping just.
i repaired them ! the rele colour is blue. Three percent . left first -Center, between -Surround, between(right Hand)-Front.
I moved the front channel's rele(right hand) .Katt -it sad. Working, volume is back. Rele specification is (colour Blue) Deg Greatings-Ranger of Hungary.10_26_2012_6_50_16_am.jpg
Aug 23, 2010 | Sony STR-DE875 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Center Channel not working
First of all check that it has not got switched off somehow. After that, what I would do is trace the wires back (inside the unit) from the center speaker connector. This will take you back to the output semi-conductors for that channel. I would suspect these first, you might even see damage! You should anyway be able to look the numbers up on the net. If they are cheap I would replace them anyway. If that doesn't work I suggest you hunt down the service manual, it might have suggestions in it.
Apr 08, 2010 | Sony STR-DE575 Receiver
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
Patio speakers
connect them to the front left and right outputs.connecting them to the sub-woofer will give poor sound because it only pick's up bass sounds during playback
Oct 29, 2007 | Sony STR-DE575 Receiver
71 people viewed this question
 Grubhead
Grubhead
