Error code 30 'technical fault with channel' every time I switch on Sky TV. Sky helpline keep telling me to turn off and on again, which cures it until I turn on again the next day. Is there a permanent cure?
  • Anonymous Feb 02, 2009
    Technicl fault 30 keeps coming up!!!
  • 9 Answers
SOURCE: lamp burnout?
most probably you have a bad bulb. in most cases you can take the bulb out and you will see it cracked inside the glass mirror.anyway the first approach is to replace the bulb.the part number should be on a label on the bulb.if you can not find it leave a message and i will find it for you.
Posted on Jul 25, 2007
Soulvisitor
  • 1113 Answers
SOURCE: error message
We need to know Brand and model
So you need to tell us you have a HP all in one laser printer/scanner first!
Posted on Nov 19, 2007
Slinteriors
  • 8617 Answers
SOURCE: my tv was working okay,i
Your internal speakers are turned off. What model TV do you have. I may be able to help you.
Posted on Feb 02, 2008
  • 133 Answers
SOURCE: off air digital signal
What brand of tv is it ? You could have a bad tuner or a change in the voltage supply line feeding the tuner . What type of antenna do you have ? outdoor or rabbit ears ? Also does it retain the channel line up or does it clear them as well ?
Posted on Feb 27, 2008
  • 1153 Answers
SOURCE: Mitsubishi mod WS55511, 55" platinum series, power and code problem
Press the menu button for 10 sec on the set
Posted on Mar 24, 2008
I have a Tosumi television connected to standard sky box but every time I turn on television it goes to another channel rather than the connected av channel. Also when I try to use sky controller to...
Always turn on your TV with the Sky box (or any other external device you want to use) turned OFF. When the TV is on, turn on the Sky box by pressing the "Sky" button at the top centre of the remote control. This will ensure that the TV recognises that there is an external input and it will automatically switch to the correct channel. It also ensures that your Sky remote control isn't in TV mode.
If you switch your TV to standby using the Sky remote after watching, the next time you use the Sky remote, it's still in TV mode. This is why your TV channels are jumping around.
Hope this helps.
Oct 21, 2010 | Televison & Video
How do i get the tv on av without using the remote?
push channel down button through the channels, then it will go into av mode(video) by just keeping to press channel down. it will be channel below channel 02. just keep pushing channel down button
Nov 21, 2009 | Beko 324250WN 28" TV
Star box codes
i had the same problem delete all channels on master reset and scan again turn on key emu and all channels should be back on
:D
Jun 25, 2009 | StarTech.com StarView SV211K 2-port KVM...
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Code for TV / Sky+remote
Problem: Need Sony manufactures code for the Sky remote.
Solution: Your TV Code for Sony is 0000
1. Turn on your TV.
2. Ensure that the front of your Sky Navigator is closed.
3. Press "tv”.
4. Hold down "select" and the red button together for about two seconds, until the red LED on the Sky Navigatore flashes twice.
5. Press "tv" again.
6. Key in the four digit code for your brand of TV. The LED on the Sky Navigator will flash twice. If the LED illuminates only once, re-check the code for your brand of TV and start again at step 5.
7. Press the standby button on your Sky Navigator. If your TV switches off, press "select". The LED on the Sky Navigator will flash twice. If your TV does not switch off, press "tv", then press the standby button.
Repeat this (press "tv", then standby button) until your TV turns off,
then press "select".
If you are still experiencing problems, please telephone for technical
assistance. you will find the "Technical Help" telephone number by
pressing "services" and selecting "Telephone Numbers".
The help given is based on information taken.... Hoped this has helpd you
Jan 13, 2009 | Televison & Video
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
Oct 17, 2008 | Philips HDD065 MP3 Player
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
Feb 13, 2008 | Televison & Video
Televison & Video Logo
1,837 people viewed this question
Top Televison & Video Experts
