Question about Electrolux EW1209i Front Load Washer / Dryer
Dryer heater not working
I have a Frigidaire front loading dryer that does not heat up. I have checked the thermistor and it is within specs. I can put it into test mode and the heater works fine but not when in regular mode. According to the technical data sheet, the electronic control is bad. Any ideas?
  • jerrylynwinf Apr 12, 2009
    my fridgedarire leq1442eso dry has no heat. The dryness control selector seems to be not working...is this common and how do you fix it?
    Sergeant:
    Champion:
  • 311 Answers
If heater works in test mode then the only thing keeping it from operating would be the ctrl as you guessed correctly. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
What does error code E56 mean?
That error is an E5b error. This indicates a problem with the heating element, the thermistor or the control board. You'll need to unplug the unit and access the wiring. Inspect the heating coil for breaks. Then test the voltage across the element (should see the line voltage) and check the resistance at the thermistor (should be ~50000 Ohms in a room temperature environment). If the above are okay, your control board is probably bad.
If you post a comment with the model number, I may be able to point you the appropriate parts. If your dryer is under warranty, contact Frigidaire.
I hope this helps.
May 19, 2015 | Frigidaire Dryers
Frigidaire affinity dryer won't heat. Error reads code r11 what is the problem?
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 22, 2015 | Frigidaire Dryers
Our frigidaire gallery dryer won't heat up. It turns fine, and we have tried it on multiple settings.
Hi mommylein...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 17, 2011 | Frigidaire Electric Dryer
Heating element not coming on
Since the heating element turns on when the heater relay on the control board is bypassed, the problem must be the control thermistor. It is the one on the wiring diagram inside a circle and located on the blower housing. The indicated resistance of 50000 ohms is the resistance of the thermistor at room temperature. It goes down as the dryer heats up and when the dryer temperature is too hot and the thermistor resistance is too low, the control board turns off the heater relay.
The problem here must be the control thermistor. Its resistance must be too low or even shorted thereby making the control board "think" the dryer is too hot and therefore does not turn on the heater relay at all. Check the resistance of the control thermistor which must be around 50000 ohms at room temperature. Measure the resistance with the thermistor connected and disconnected. If the resistance is good when disconnected but not when connected, then the wires must be shorted somewhere else since the control board has been replaced. Locate the short circuit or simply replace the wire harness.
Aug 16, 2011 | Frigidaire Dryers
Replace heater coil but no heat when i turn on dryer.
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
This is a FREE answer, Please rate me
Jan 14, 2011 | Frigidaire GLER341A Electric Dryer
I have a newer frigidaire dryer and the drum came off it was makeing a metal to metal noise. I runs fine now but doesnt heat. Do you know what it could be?
Check your Wiring
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
For video and pictures on how to replace the an element go to the following website, it will give you an idea what you are in for:
Jan 02, 2011 | Frigidaire Dryers
Dryer runs but no heat. Stackable set, dryer on top.
More than likely the Thermistors are blown. They are located on the heating element canister inside the dryer, they are kinda oblong shape with two electrical connections. If you have a multimeter you can check for continuity on the thermistors and the heating element just be sure to disconnect one of the electrical connections on the thermistors and the heating element so you don't get a false meter reading, Thermistors can be purchased from most appliance repair businesses for around $30.appliancguru.jpg
Dec 10, 2010 | Frigidaire FGX831CS Top Load Stacked...
Frigidaire crown series gas dryer - heats up and turns, but does not dry clothes. i had someone check the vent and clear it all out - he thinks it is the blower? Can that be fixed?
Try this solution first before checking the blower.
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
For video and pictures on how to replace the element go to the following website:
Dec 07, 2010 | Frigidaire GLER341A Electric Dryer
Frigidaire Dryer not drying clothes properly
TRY DISCONECTING THE VENTING FROM THE BACK OF THE DRYER THEN RUNNING IT .POSSABLE THE OUTSIDE FLAPPER STUCK?IM THINKING NOT THE DRYER. GOOD LUCK!
Jan 16, 2010 | Frigidaire AEQ6000ES Electric Dryer
Dryer problem
check input voltage make sure you have 240 volts red to black and 120 red or black to white. then check heating element. and hi temp cutoff. On Frigidaire built machines (includes some GEs) a temp thermistor on exhaust duct at front of machine is a common problem. 50ohms is normal- less causes problems
May 04, 2008 | Kenmore 93862 Top Load Stacked Washer /...
Electrolux EW1209i Front Load Washer / Dryer Logo
236 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
