Question about Sakar 89379 Digital Camera
Digital camera When I take pictures they seem to have a lot of blue in them. For instance grass is greenish blue instead of green. Is there a way to adjust the color? Without the flash pictures are to dark and if I use the flash inside it washes out faces. When I take the photos into photoshop I can adjust the colors but the washed out faces are still there. Most of the pictures are blurry. Is there a solution for this? Is there a solution for this or do I chalk it up to a cheap camera?
  • 114 Answers
Normally that happen in the cameras when we take out one filter that is fitted between the CCD and the Lens, maybe on that camera is just don´t exist and depending on the light the image changes.
Posted on Jan 23, 2007
Tip
My TV picture has a greenish tint.
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal is often coded in separate colors signal, and a bad cable can cause a green picture when red or magenta (depending on type of signal) are out.
A faulty receiver or DVD player can also send a bad output. Try connecting different devices to TV.
If the cables and receiver are OK there are also internal faults that can cause the same effect.
The fault depends mainly on the model and type of the TV set.
On all TVs a faulty input/output can cause greenish picture.
On all digital TVs the signal is also elaborated on different color channels . Video circuits are often located on digital board.
A fault on digital video processing can cause a green picture.
If you have a rear projection CRT based technology, one of the three CRT may be faulty, or the power board supplying the CRT (red in your case) may have blown.
In that case you will get a greenish picture.
If instead you have a CRT TV, a greenish picture means that the red gun inside the cathode ray tube is not working. The CRT itself must be replaced.
Generally, when the problem is not the video cable , or the connected device, the TV must be inspected and repaired by a technician.
If you have a new digital TV, as an LCD, Plasma, or any non CRT based technology, the problem is usually caused by cables, input output, or connected devices.
Check the cables thoroughly, if that is not the problem, call manufacturer to find the nearest repair service location.
on Oct 23, 2009 | Vizio L32 32 in. LCD HDTV
My camera is saying green mode and the lens will not zoom out what is green mode
http://support.pentaximaging.com/node/23
Please rate this Fixya Answer
Mar 06, 2011 | Pentax Optio M40 Digital Camera
Pictures when taken look green in areas
This is problem of bad ccd imager chip in DSC-T33 that generates greenish distorted image in camera.
Replace ccd imager chip in camera to solve this issue.
If you are handy with electronics stuff repair and can take apart this camera easily with proper tools then let me know to provide you ccd imager chip part number.
Thanks.
Nov 04, 2010 | Sony Cyber-Shot DSC-T33 Digital Camera
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Green output
WHAT HAPPENS WHEN I DOWNLOAD THE PICTURES ONTO THE COMPUTER ,WILL THEY STILL GIVE ME THE SAME COLOUR, GREENSH ONE?
Jul 25, 2008 | Casio QV-R41 Digital Camera
Green waves
http://www.fixya.com/support/t128774-green_screen has the solution. It is probably a CCD burn out, but link exists for free repair (above)
Mar 19, 2007 | Nikon Coolpix 5700 Digital Camera
Saturation of unrealistic color
It is definite CCD chip problem. If you are within warranty period, send it back quick. They probably replace with other unit because the parts are not available for the product. Good luck.
Mar 13, 2007 | Apex Digital 4330z Digital Camera
Display and viewfinder greenish, pictures ok though
ccd is the main suspect. Try cleaning the contacts of the flexible film connectors attached to the CCD or replacement is the only alternative.Sony does not supply the CCD and the whole lens which is expensive has to be replaced. Stay in touch
Aug 27, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Sakar 89379 Digital Camera Logo
83 people viewed this question
Top Sakar Cameras Experts
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Are you a Sakar Camera Expert? Answer questions, earn points and help others
