I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
    Sergeant:
    Champion:
  • 274 Answers
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Posted on Nov 30, 2008
I have a Dell A940 connected to my old Dell desktop, which I want to keep. How can I get it to print from my new laptop? I cannot find any USB ports on the printer to connect.
Specs state that it is USB - probably a "USB-B" connector. Anyway, how is it connected to your desktop? Surely you can take the USB lead from the printer out of the back of your desktop and plug it in your laptop? Am I missing something here? Specs don't say it is a "parallel" connector (unless it has both). If it has both (and you are using the parallel connection (big plug with many pins) on your desktop then there should be a USB-B socket on printer next to the big parallel socket.
Sep 10, 2009 | Dell A940 All-In-One InkJet Printer
Vista will not print to HP Laserjet 5p
I purchased a Dynex USB to Parallel Converter Cable from Best Buy and tried to connect but had no success. I then sent an email to Dynex customer service and received a reply in about 24 hours. The rep provided spot on instructions which I was able to follow to a tee. My 14 year old HP Laserjet 5P is now ready to run until it blows up.
I spent hours searching web forums and only received overcomplicated replies by people who think they are techies, none of which worked. I am 63 years old and not a techie, so if I can do it, anyone can. I have saved the email and will forward this straightforward simple fix to anyone who needs it. My net cost was $36.00 for the cable.
Sep 05, 2009 | HP LaserJet 5p Printer
Need to use HP Deskjet5550 to print off laptop
Since Hp have Vista driver to your printer...to install the driver...do not plug the printer...install the driver that you downloaded (run the program as Administrator)..after you install, if the installation ask for restart..restart your computer...after restart and the whole system finish his task on loading driver and dll ..then plug in your printer...it will pop up message found new hardware. click next and choose automatic find the driver.
what Cable are you using to connect?
USB a and b?
parallel port to USB? if this you need to download the driver too.
Good Lock
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
Problems with Samsung SCX-4216F All-In-One Laser Printer?
SCX-4216F could receive fax, but didn't print out faxes. Can anybody help me with this?
Mar 03, 2009 | Samsung SCX-4216F All-In-One Laser Printer
HP laserjet 4L parallel to usb vista Jumbled font on test page
You mentioned parallel usb. The HP4L only has parallel. Make sure you specify LPT1 as the port you want. Try reinstalling the driver. It should be in the list of drivers.
Feb 21, 2009 | HP LaserJet 4L Printer
Samsung 4216f doesnt print landscape, Vista 64
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Lexmark Optra C720 Laser Printer
Canon bjc 50 printer
You are correct on your deduction.
It is the USB to Parrallel adpter. They are not reliable in the XP/Vista enviroment. I have run into this several times.
Oct 07, 2008 | Canon Office Equipment & Supplies
HP LaserJet II p Plus will not print
I am assuming that you are using Vista. Based on your post/description:
1. the HP Compaq 6710b has no parallel port;
2. the HP LaserJet IIP Plus is only capable of either serial or parallel connection;
3. hence you're attempting a USB to Parallel interface;
4. the printer is installed in your notebook and is set to USB port;
5. from the printer a test print can be performed but not from the Printer Properties in your notebook;
6. all printing jobs initiated from the notebook results in an "Error".
With the above in mind, may I point/suggest that:
a. Windows Vista driver will only enable your HP LaserJet IIP Plus' basic functions to work. It is not 100% compatible;
b. alternately, you can try using the XP installation CD/drivers of the printer;
c. the compatibility issue may be compounded by the USB to parallel interface;
d. the USB to parallel interface may be hampered by a known Vista USB issue;
e. you can try patching/updating the Vista USB driver. Since this has been a recognized issue with Vista, Microsoft has posted a fix for this here or here.
f. verify that the printer does not display a 22 or 40 Error.
If the printing concern has not been rectified after completion of the above procedures, you may need to:
i. download and install HP Universal PostScript Print Driver; or
ii. consider using a wireless print server connected to the parallel port of the printer; or
iii.consider replacing your printer. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | HP LaserJet IIp plus Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
116 people viewed this question
k24674
jasbo
jasbo
