Question about Panasonic SC-HT650 System
Panasonic SC-HT650 When I turn my receiver on F61 pops up on the receiver diplay then shuts itself off. How can I fix this? Is there a way to reset the receiver?
  • itspankaj Nov 28, 2007
    f61 displays and shut down
From what i heard this is a common problem with this unit (mine included). apparently it cost more to fix than buying a new one.
Posted on Mar 08, 2007
Reading code f61
pop cover plug in with med to light pressure on the heat sink press down gently and push one way just a tad , press power , see how long to shut down. do same other direction. what you should find is that the solder connections are bad and need to be redone. this is not the first pan. that has had this problem, some of there other stereos do to.
Apr 21, 2014 | Panasonic SC-HT650 System
When i turn on my receiver f61 code comes on then it shuts off how do i fix it. Panasonic SC-ht650
Many things can cause the error code f61 on a Panasonic.
Most of them need a service tech to repair. Output IC or voltage regulator....
The one thing you may be able to check is the cooling fan, it should turn on hen the power button is pushed. Make sure it spins freely.
Most often it is the output IC
Feb 11, 2011 | Panasonic Audio Players & Recorders
My SC-HT650 system reads F61. I think I need a new transformer. Where do I find that?
Not the transformer. probably needs a voltage ic or output ic. F61 is a voltage error code. if it was the power tranformer it would not power up at all. It also could be just a bad fan. The fan should start as soon as you turn it on.
Jan 26, 2011 | Panasonic SC-HT650 System
Error f61
my CD Stereo System SA-AK18 turns off itself displaying f61 error, what does it means? how can I fix it, plz help me
Oct 16, 2010 | Panasonic SC-AK18 CD Shelf System
When its turned on it says hellow then says f27 then gos to standby
I have a panasonic DVD SA-HT650 it's come's on displays F61, then shut (OFF)
Mar 13, 2010 | Panasonic Home Theater System System
F61? how do i fix it...................everytime i turn my panasonic sc-ak340 on i get a error code that reads f61 and then my system shuts down by itself..can this be fixed?
I've encountered that kind of problem.
f61 appear on the screen then shuts down the unit.
The very common defect is your fan, output ic (rsn series).
First check the fan if it is in good condition (disassembling the component is quite technical it need a lot of care).
sometimes the fan is full of dirt that's why it will not work properly which the system sense and uttered the unit to switch of avoid further damaged.
If you confirm that the fan is working properly I will suggest you to bring your unit to a qualified technician/service center because replacing the output i.c. is more technical.
Dec 13, 2009 | Panasonic SC-AK340 Shelf System
Panasonic SC-HT650
This indicates protect mode. One of the output amp pacs needs to be replaced. It is either part number: STK470-050 ($16) or RSN311W64D ($95)
Dan
Apr 09, 2008 | Panasonic SC-HT930 System
F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Dec 05, 2007 | Panasonic SC-AK78 CD Shelf System
Unit will not turn on.
I think we have the same problem only mine is flashes an F61 on the display then shuts itself off.
Jan 02, 2007 | Panasonic SC-HT650 System
Panasonic SC-HT650 System Logo
241 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
